11938MB-A0N-EP-00
11938MB-A0N-EP-00
    NMBTECHNOLOGIESCORPORATION
    FAN100VAC119X38MMTERM
11938MB-A0N-EP-00 数据手册
Part Numbering System NMBTC.COM / 818.341.3355 New Part Numbering System 0 8 0 2 5 S A 1 2 M A A 0 0 1 1. Size 2 3 Part # Thickness (mm) Part # 25 025 10 10 30 030 15 15 35 035 20 20 40 040 25 25 50 050 28 28 52 052 32 32 55 055 38 38 60 060 50 50 80 080 56 56 92 092 76 76 119 119 100 A0 127 127 210 B1 150 150 172 172 6. Speed Current 5 DC Fan AC Fan 0 H 1 J 2 K 3 L 4 M 5 N 6 P 7 Q 8 R 9 S A T Rib Flange Terminal Single Flange Special Rib Type N/A A Coating B Potting C N/A E Coating F Potting G N/A N Coating P Potting Q N/A S Coating T Potting U N/A W Coating Y Potting Z Flange Type 3 Through Hole One Side Flange Type Steel A B B Steel Ceramic C D Other Div. A Other Div. Other Div. B Other Div. DC Fan AC Fan CL C FS F Stainless Stainless E F FB D Other Div. H Stainless Ceramic G J EL/WB E BG/BM/Motorized G Other Div. H I MS Sleeve S M Rational Sleeve M O HSB Type Sleeve H I PC/PS P JL J HS S KL K TS T GL/ML/NL/SL M Other Div. W 5. Rating Voltage DC FAN AC FAN PL P Rating Voltage BT Q 5V 05 100V A0 RL R 6V 06 115V A1 SB S 9V 09 200V B0 FT/JT T 12V 12 220V B2 VL V 24V 24 230V B3 Other Div. W 36V 36 240V B4 48V 48 3X0V CX 4X0V DX 5X0V EX Part # Flange T 4mm +L/W N/A A Flange T 6mm +L/W Flange T 6mm +T Type Single Flange Special Model Ball Bearing DC Fan Supporter Flange T 4mm +T Type Part # 8. Output Signal, Speed Control & Protect Function Casing Type One Side Rib Type Steel Part # Coating B Potting C N/A E Coating F Potting G N/A J Coating K Single/ Two Phase Three-Phase Output Signal Speed Control Open Closed Open Closed Standard Constant A C E 1 None-SI Variable B D F 2 Lock Constant L N G 3 or Life-S Variable M P H 4 Constant T V J 5 Variable U W K 6 TACHO Potting L N/A N Coating P Function Output Signal Potting Q N/A A N/A S Impedance Protect Yes B Coating T Impedance Protet - Fuse N/A F Yes G Potting U N/A W Coating Y Potting Z 9. Individual Specifications Through Hole A Series AC Fan Part # Part # Bearing Part # O Supporter 9 8 Out Ring Series DC Fan Casing 7 4. Bearing 7. Termination & Supporter Part # 6 3. Series 2. Thickness Size (mm) 4 Part # Standard 00 Custom 01-99 Fan Blade 1 Digit OEM 1 Digit AC Fan Thermal Protection Thermal + Fuse 2 Voltages 2 Voltages + Fuse Part # PX4 N/A QX4 RX4 SX4 N/A U Yes V N/A W Yes Y
11938MB-A0N-EP-00
1. 物料型号:文档提供了NMB风扇的型号编号系统,包括尺寸、厚度、系列、轴承类型、额定电压、转速、端子和支撑、输出信号、速度控制和保护功能等。
2. 器件简介:文档没有提供具体的器件简介,但型号编号系统为用户识别和选择风扇型号提供了详细的指导。
3. 引脚分配:文档中没有直接提到引脚分配,但型号编号系统中的某些部分可能与电气特性相关,如输出信号和速度控制。
4. 参数特性:文档详细列出了风扇的尺寸、厚度、系列、轴承类型、额定电压、转速等参数,以及对应的型号编号。
5. 功能详解:文档解释了型号编号系统中的每个部分,如尺寸、厚度、系列、轴承、额定电压、转速、端子和支撑、输出信号等。
6. 应用信息:文档没有提供具体的应用案例,但型号编号系统有助于用户根据需要选择合适的风扇型号。
7. 封装信息:文档中没有直接提到封装信息,但尺寸和厚度参数可以间接提供有关封装的一些信息。
11938MB-A0N-EP-00 价格&库存
很抱歉,暂时无法提供与“11938MB-A0N-EP-00”相匹配的价格&库存,您可以联系我们找货
