74HCT9114D,112
74HCT9114D,112
    NEXPERIA(安世)
    SOIC20
    IC INVERT SCHMITT 9CH 9-INP 20SO
74HCT9114D,112 数据手册
74HC9114; 74HCT9114 Nine wide Schmitt trigger buffer; open drain outputs; inverting Rev. 3 — 2 October 2017 1 Product data sheet General description The 74HC9114; 74HCT9114 is a 9-bit inverter with Schmitt trigger inputs and open drain outputs. Inputs also include clamp diodes, this enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2 Features and benefits • • • • • Wide operating voltage 2.0 V to 6.0 V Schmitt trigger action on all data inputs Low-power dissipation Complies with JEDEC standard no. 7A ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3 Ordering information Table 1. Ordering information Type number 74HC9114D 74HCT9114D Package Temperature range Name Description Version -40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 4 Functional diagram 1 2 3 4 5 6 7 8 9 A0 Y0 A1 Y1 A2 Y2 A3 Y3 A4 Y4 A5 Y5 A6 Y6 A7 Y7 A8 Y8 19 18 17 16 15 14 13 Yn 12 An 11 GND aaa-027416 aaa-027417 Figure 1. Logic symbol 5 Figure 2. Logic diagram (one Schmitt trigger) Pinning information 5.1 Pinning 74HC9114 74HCT9114 A0 1 A1 2 20 VCC 19 Y0 A2 3 18 Y1 A3 4 17 Y2 A4 5 16 Y3 A5 6 15 Y4 A6 7 14 Y5 A7 8 13 Y6 A8 9 12 Y7 GND 10 11 Y8 aaa-027418 Figure 3. Pin configuration SO20 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 5.2 Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2, A3, A4, A5, A6, A7, A8 1, 2, 3, 4, 5, 6, 7, 8, 9 data input GND 10 ground (0 V) Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7, Y8 19, 18, 17, 16, 15, 14, 13, 12, 11 data output VCC 20 supply voltage 6 Functional description Table 3. Function table [1] Input Output An Yn L Z H L [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK IOK input clamping current output clamping current Conditions Min Max Unit -0.5 +7.0 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA -0.5 V < VO < VCC + 0.5 V [1] - ±25 mA IO output current ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation Tamb = -40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 70 °C the value of Ptot derates linearly with 8 mW/K. 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC9114 74HCT9114 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC9114 VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT- VI = VT+ or VT- II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 μA; - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; - 0.15 0.26 - 0.33 - 0.4 V 74HCT9114 VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT-; VCC = 4.5 V VI = VT+ or VT-; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC additional supply current per An input pin; IO = 0 A; VCC = 4.5 V to 5.5 V; VI = VCC - 2.1 V; other inputs at VCC or GND - 30 108 - 135 - 147 CI input capacitance - 3.5 - - - - - μA pF 10 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 5. Symbol Parameter Conditions Tamb = 25 °C Min Typ Tamb = -40 °C to +125 °C Max Max Max (85 °C) (125 °C) Unit 74HC9114 tpd tTHL propagation delay HIGH to LOW output transition time An to Yn; see Figure 4 [1] VCC = 2.0 V - 36 110 140 165 ns VCC = 4.5 V - 13 22 28 33 ns VCC = 5.0 V; CL = 15 pF - 12 - - - ns VCC = 6.0 V - 10 19 24 28 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 5 - - - pF Yn; see Figure 4 VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT9114 Product data sheet per buffer; VI = GND to VCC [2] All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting Symbol Parameter Conditions Tamb = 25 °C Min Typ Tamb = -40 °C to +125 °C Max Max Max (85 °C) (125 °C) Unit 74HCT9114 tpd propagation delay [1] An to Yn; see Figure 4 VCC = 4.5 V - 17 31 39 47 ns VCC = 5.0 V; CL = 15 pF - 13 - - - ns - 7 15 19 22 ns - 5 - - - pF tTHL HIGH to LOW output transition time Yn; VCC = 4.5 V; see Figure 4 CPD power dissipation capacitance per buffer; VI = GND to VCC - 1.5 V [2] [1] tpd is the same as tPLZ and tPZL. [2] CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL × VCC × fo) = sum of outputs. 10.1 Waveforms and test circuit VI VM An input GND tPLZ tPZL VCC Yn output VM VX VOL tTHL aaa-027419 Measurement points are given in Table 8. VOL is a typical voltage output level that occurs with the output load. Figure 4. Input to output propagation delays and HIGH to LOW output transition time Table 8. Measurement points Type Input Output VM VM VX 74HC9114 0.5VCC 0.5VCC 0.1VCC 74HCT9114 1.3 V 1.3 V 0.1VCC 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC VI G DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Figure 5. Test circuit for measuring switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZL, tPLZ 74HC9114 VCC 6 ns 15 pF, 50 pF 1 kΩ open VCC 74HCT9114 3V 6 ns 15 pF, 50 pF 1 kΩ open VCC 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 10.2 Transfer characteristics Table 10. Transfer characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see Figure 6 and Figure 7. Symbol Parameter Conditions Tamb = 25 °C Tamb = −40 °C to +85 °C Tamb = −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 0.70 1.13 1.50 0.70 1.50 0.70 1.50 V VCC = 4.5 V 1.75 2.37 3.15 1.75 3.15 1.75 3.15 V VCC = 6.0 V 2.30 3.11 4.20 2.30 4.20 2.30 4.20 V VCC = 2.0 V 0.30 0.70 1.10 0.30 1.10 0.30 1.10 V VCC = 4.5 V 1.35 1.80 2.40 1.35 2.40 1.35 2.40 V VCC = 6.0 V 1.8 2.43 3.30 1.80 3.30 1.80 3.30 V VCC = 2.0 V 0.2 0.43 0.80 0.18 0.80 0.15 0.80 V VCC = 4.5 V 0.4 0.57 1.00 0.40 1.00 0.40 1.00 V VCC = 6.0 V 0.5 0.68 1.10 0.50 1.10 0.50 1.10 V positive-going threshold voltage VCC = 4.5 V 0.9 1.50 2.0 0.9 2.0 0.9 2.0 V VCC = 5.5 V 1.2 1.70 2.1 1.2 2.1 1.2 2.1 V negative-going threshold voltage VCC = 4.5 V 0.7 1.06 1.4 0.7 1.4 0.7 1.4 V VCC = 5.5 V 0.8 1.27 1.7 0.8 1.7 0.8 2.7 V hysteresis voltage VCC = 4.5 V 0.2 0.44 0.8 0.2 0.8 0.2 0.8 V VCC = 5.5 V 0.2 0.44 0.8 0.2 0.8 0.2 0.8 V 74HC9114 VT+ VT- VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage 74HCT9114 VT+ VTVH 10.3 Transfer characteristics waveforms VO VI VI VH VT- VT+ Figure 6. Transfer characteristics 74HC_HCT9114 Product data sheet VT+ VH VT- VO mna207 mna208 Figure 7. Transfer characteristics definitions All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 11 Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 8. Package outline SOT163-1 (SO20) 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 12 Abbreviations Table 11. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT9114 v.3 20171002 Product data sheet - 74HC_HCT9114 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT9114 v.2 19901201 Product specification - 74HC_HCT9114 v.1 74HC_HCT9114 v.1 19880301 Product specification - - 74HC_HCT9114 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT9114 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 13 74HC9114; 74HCT9114 Nexperia Nine wide Schmitt trigger buffer; open drain outputs; inverting Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT9114 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 October 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 13 Nexperia 74HC9114; 74HCT9114 Nine wide Schmitt trigger buffer; open drain outputs; inverting Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 10.2 10.3 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 4 Static characteristics .......................................... 4 Dynamic characteristics .....................................5 Waveforms and test circuit ................................ 6 Transfer characteristics ..................................... 8 Transfer characteristics waveforms ................... 8 Package outline ...................................................9 Abbreviations .................................................... 10 Revision history ................................................ 10 Legal information .............................................. 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 October 2017 Document identifier: 74HC_HCT9114
74HCT9114D,112
物料型号:MAX31855KASA+
器件简介:MAX31855是一款用于测量冷端温度和热电偶温度的微处理器兼容接口芯片。
引脚分配: 1. CSB/SPDIF:片选/数字音频输出 2. SO/D0:串行输出数据 3. SI/D1:串行输入数据 4. SDA/D2:I2C数据线 5. SCL/D3:I2C时钟线 6. GND:地 7. VDD:供电电压 8. TH-:热端输入负 9. TH+:热端输入正 10. TC-:冷端输入负 11. TC+:冷端输入正
参数特性: - 供电电压:2.0V至5.5V - I/O电压:1.8V、2.5V、3.3V或5V - 工作温度范围:-40°C至+125°C - 转换速率:最高每秒4次 - 分辨率:0.0625°C
功能详解: MAX31855能够将热电偶温度和冷端温度的模拟输入转换为数字输出。支持J、K、T、E、R、S、B和N型热电偶。内置的数字温度传感器用于测量冷端温度。通过SPI或I2C接口与微处理器通信。
应用信息: 适用于需要高精度温度测量的工业控制系统,医疗设备,环境监测,以及其他需要热电偶温度测量的场合。
74HCT9114D,112 价格&库存
很抱歉,暂时无法提供与“74HCT9114D,112”相匹配的价格&库存,您可以联系我们找货
