4715TS-22T-B5A-B00
4715TS-22T-B5A-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 220VAC TERM
4715TS-22T-B5A-B00 数据手册
11938TB (119 X 38L) NMBTC.COM / 818.341.3355 General Specifications Legacy Part No. 4715TS Metal Blades/Standard Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: B5A Class : Thermal Protection Insulation Resistance: .48 .40 10M Ω or over with a DC500V Megger .32 Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .16 .08 (m3 /min) Failure Rate: 10% 25°C 90,000 Hours 35 Material Casing Impeller Bearing Lead Wire or Terminal DC AC Axial Fans Expected Life 70 106 141 CFM Outline : Aluminum (Black Painting) : Steel : Ball Bearings : AWG22, UL3266 : Faston #110 or equivalent .169 8 – ( 4.3) ROTATION 3.11 (7.9) inch Units: (mm) 4.13 (105 0.3 ) 4.69 (119 0.5 ) Panel Cut-Outs 4.13 (105) ( (115) 4.53 5. 3 13 5 6) .169 4 – ( 4.3) 4.13 (105 0.3 ) 4.69 (119 0.5 ) 1.49 (38 0.5 ) 4.13 (105) 4.53 (115) INLET SIDE / OUTLET SIDE Specifications LEGACY P/N MODEL (V) Max. Max. Static Noise Mass Air Flow Pressure (V) (A)*1 100 11938TB-A0N-NP-00 4715TS-10T-B5A-B00 100 50 65 0.450 20.0 2600 98.84 2.80 0.352 88.0 46 60 65 0.340 17.0 3100 116.49 3.30 0.400 100.0 50 610 11938TB-A1N-NP-00 4715TS-12T-B5A-A00 115 50 75 0.390 21.0 2600 2.80 0.352 88.0 46 610 115 60 75 0.300 17.0 3100 116.49 3.30 0.400 100.0 50 610 ** 11938TB-B0N-NP-00 4715TS-20T-B5A-B00 200 50 130 0.220 21.0 2600 2.80 0.352 88.0 46 610 200 60 130 0.170 17.0 3100 116.49 3.30 0.400 100.0 50 610 ** 11938TB-B2N-NP-00 4715TS-22T-B5A-B00 220 50 145 0.200 20.0 2600 2.80 0.352 88.0 46 610 220 60 145 0.150 17.0 3100 116.49 3.30 0.400 100.0 50 610 11938TB-B3N-NP-00 4715TS-23T-B5A-A00 230 50 175 0.190 21.0 2600 2.80 0.352 88.0 46 610 ** Rated Frequency Starting Current Input Speed Voltage Voltage Power (Hz) ** (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 98.84 98.84 98.84 98.84 (g) 610 230 60 175 0.140 17.0 3100 116.49 3.30 0.400 100.0 50 610 240 11938TB-B4N-NP-00 4715TS-24T-B5A-A00 240 50 175 0.180 20.0 2600 98.84 2.80 0.352 88.0 46 610 60 175 0.140 17.0 3100 116.49 3.30 0.400 100.0 50 610 Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air
4715TS-22T-B5A-B00 价格&库存
很抱歉,暂时无法提供与“4715TS-22T-B5A-B00”相匹配的价格&库存,您可以联系我们找货
