4715HS-10T-B5A-B00
4715HS-10T-B5A-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 100VAC TERM
4715HS-10T-B5A-B00 数据手册
11938SB (119 X 38L) Legacy Part No. 4715HS Plastic Blades/Standard NMBTC.COM / 818.341.3355 General Specifications Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: Thermal Protection Insulation Resistance: In H2O (Pa) .48 .40 10M Ω or over with a DC500V Megger .32 Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 -10°C ~ +65°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .16 .08 (m 3/min) Failure Rate: 10% 25°C 100,000 Hours 35 70 106 141 CFM Outline Material Casing Impeller Lead Wire or Terminal DC AC Axial Fans Expected Life : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : AWG22, UL3266 : Faston #110 or equivalent .169 8 – ( 4.3) ROTATION 3.11 (7.9) inch Units: (mm) 4.13 (105 0.3 ) 4.69 (119 0.5 ) Panel Cut-Outs 4.13 (105) ( (115) 4.53 5. 3 13 5 6) .169 4 – ( 4.3) 4.13 (105) 4.53 (115) 4.13 (105 0.3 ) 4.69 (119 0.5 ) 1.49 (38 0.5 ) INLET SIDE / OUTLET SIDE Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) (Hz) (V) (A)*1 Max. Max. Static Noise Mass Air Flow Pressure (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 (g) 100 11938SB-A0N-NP-00 4715HS-10T-B5A-B00 100 50 65 0.370 18.0 2600 91.8 2.60 0.380 94.0 40 60 65 0.290 15.5 3100 105.9 3.00 0.400 100.0 44 570 11938SB-A1N-NP-00 4715HS-12T-B5A-A00 115 50 75 0.320 18.0 2600 91.8 2.60 0.380 94.0 40 570 115 60 75 0.250 15.5 3100 105.9 3.00 0.400 100.0 44 570 ** 11938SB-B0N-NP-00 4715HS-20T-B5A-B00 200 50 130 0.180 18.0 2600 91.8 2.60 0.380 94.0 40 570 200 60 130 0.150 15.5 3100 105.9 3.00 0.400 100.0 44 570 ** 11938SB-B2N-NP-00 4715HS-22T-B5A-B00 220 50 145 0.160 18.0 2600 91.8 2.60 0.380 94.0 40 570 220 60 145 0.130 15.5 3100 105.9 3.00 0.400 100.0 44 570 11938SB-B3N-NP-00 4715HS-23T-B5A-A00 230 50 175 0.160 18.0 2600 91.8 2.60 0.380 94.0 40 570 ** ** 570 230 60 175 0.120 15.5 3100 105.9 3.00 0.400 100.0 44 570 240 11938SB-B4N-NP-00 4715HS-24T-B5A-A00 240 50 175 0.150 18.0 2600 91.8 2.60 0.380 94.0 40 570 60 175 0.120 15.5 3100 105.9 3.00 0.400 100.0 44 570 Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air
4715HS-10T-B5A-B00 价格&库存
很抱歉,暂时无法提供与“4715HS-10T-B5A-B00”相匹配的价格&库存,您可以联系我们找货
