15038PB (5915PC)
AC Axial Fan / Metal Blades
150X Ф172X38L
■ General Specifications
Motor Structure
Capacitor-Run Induction Motor
Motor Protection Thermal Protection
Insulation Resistance Min 100MΩ by DC 500V Megger
Dielectric Withstand Voltage:AC1800V 3s
Allowable Ambient: 10℃ ~ + 60℃ (Operating)
Temperature Range 40℃ ~ + 70℃ (Storage)
non-condensing environment
■ Expected Life
min 300(FROM CAPACITOR COVER)
※ Failure Rate: 10%(L10 Life)
25℃ 100,000 (Hours)
■ Panel Out-cuts
EARTH TAP:M4
(Inlet Side)/ (Outlet Side)
(0.5mm)
EARTH TAP:M4
162.0 ±0.2
AIR
NAME
PLATE
(6)
146.0
2 – φ4.3
2 – φ4.3
.0
52
φ1
172.0 ±1.0
2 – φ4.3
162.0
(7.9)
■ Outline
(6)
38.0 ±0.2
150.0 ±0.5
* Only flange type casing is available.
■ Characteristic Curves
■ Material
AC FAN
180
50Hz
60Hz
AC FAN
Static Pressure
160
Ps
(Pa)
Casing
Impeller
Bearing
Terminal
140
120
100
:Aluminum (Black Painting)
:Steel
:Ball Bearing
:Faston #110 or Equiv
80
60
* Please inquire regarding the potting type (dust & oil-proof type).
40
Lead Wire type is also available.
:SPT-1 2X0.824mm2 AWG18
Lead Wire
1.0 2.0 3.0 4.0 5.0 6.0 7.0
Air Flow
Q (m3/min)
■ Specifications
Model
Product No.
15038PB-A0L-EPS-
15038PB-A1L-EPS-
15038PB-B0L-EPS-
15038PB-B2L-EPS-
15038PB-B3L-EPS-
15038PB-B4L-EPS-
Rating Voltage Frequency Starting Voltage
(V)
(Hz)
(V)
50
100
65
60
50
115
75
60
50
200
130
60
50
220
145
60
50
230
150
60
50
240
155
60
Rotation: Counterclockwise as seen from the label side
Airflow Outlet: Label side
Current
(A)*2
0.530
0.450
0.450
0.400
0.250
0.230
0.250
0.230
0.220
0.200
0.200
0.200
Input Power
+10%
(W) –20%
42.0
40.0
40.0
38.0
42.0
40.0
42.0
40.0
42.0
40.0
39.0
39.0
Speed
(min-1)*3
2650
3150
2650
3150
2650
3150
2650
3150
2650
3150
2650
3150
Max.Air Flow
(m3/min)*3 (CFM)*3
5.30
189.3
6.30
225.0
5.30
189.3
6.30
225.0
5.30
189.3
6.30
225.0
5.30
189.3
6.30
225.0
5.30
189.3
6.30
225.0
5.30
189.3
6.30
225.0
Max. Static Pressure
(Pa)*1 (In H2O)*1
127.5
0.51
163.8
0.66
127.5
0.51
163.8
0.66
127.5
0.51
163.8
0.66
127.5
0.51
163.8
0.66
127.5
0.51
163.8
0.66
127.5
0.51
163.8
0.66
Noise
(dB)*1
48.0
53.0
48.0
53.0
48.0
53.0
48.0
53.0
48.0
53.0
48.0
53.0
Mass
(g)
900
*1: Average Values in Free Air
*2: Maximum Values in Free Air
*3: Minimum Values in Free Air
15038PB (5915PC)
150X Ф172X38L
AC Axial Fan / Plastic Blades ■ General Specifications
Motor Structure
Motor Protection
Thermal Protection
Allowable Ambient : 10℃ ~ + 70℃ (Operating)
■ Expected Life
※ Failure Rate: 10% (L10 Life)
25℃ 100,000 (Hours)
(7.9)
■ Outline
■ Panel Out-cuts
EARTH TAP:M4
(0.5mm)
162.0 ±0.2
AIR
NAME
PLATE
(6)
146.0
2 – φ4.3
2 – φ4.3
.0
52
φ1
162.0
EARTH TAP:M4
172.0 ±1.0
2 – φ4.3
(6)
38.0 ±0.2
150.0 ±0.5
Ps
(Pa)
50Hz
60Hz
AC FAN
Static Pressure
250
■ Material
:Plastic (Black) UL94V-0
:Ball Bearing
150
Casing
Impeller
Bearing
Terminal
100
* Potting type (dust & water-proof type) is also available.
200
Lead Wire
50
AC FAN
Q (m3/min)
Air Flow
■ Specifications
Model
Product No.
15038PB-A0L-EP-
00
15038PB-A1L-EP-
00
15038PB-B0L-EP-
00
15038PB-B2L-EP-
00
15038PB-B3L-EP-
00
15038PB-B4L-EP-
00
(V)
(Hz)
(V)
50
100
65
60
50
115
75
60
50
200
130
60
50
220
145
60
50
230
145
60
50
240
155
60
Current
(A)*2
0.470
0.440
0.380
0.360
0.230
0.210
0.210
0.180
0.190
0.180
0.180
0.170
Input Power
+10%
(W)–20%
37.0
33.0
35.0
32.0
34.0
33.0
40.0
38.0
35.0
35.0
34.0
34.0
Speed
(min-1)*3
2700
3200
2700
3200
2700
3200
2700
3200
2700
3200
2700
3200
Max.Air Flow
(m3/min)*3 (CFM)*3
5.00
178.6
6.00
214.3
5.00
178.6
6.00
214.3
5.00
178.6
6.00
214.3
5.00
178.6
6.00
214.3
5.00
178.6
6.00
214.3
5.00
178.6
6.00
214.3
(Pa)*3 (In H2O)*3
156.9
0.63
215.8
0.86
156.9
0.63
215.8
0.86
156.8
0.63
215.6
0.86
156.9
0.63
215.8
0.86
157.0
0.63
215.8
0.86
0.63
156.9
215.7
0.86
Noise
(dB)*1
52.0
56.0
52.0
56.0
52.0
56.0
52.0
56.0
52.0
56.0
52.0
56.0
Mass
(g)
800
很抱歉,暂时无法提供与“15038PB-B0L-AP-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+996.6469330+129.02457
