0.23
(6)
8- Ø 0.22
(8- Ø 5.5 ±0.1)
1.2
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF18JC-4 series
Ø 6.23
(Ø160)
(180 x 180 x 90 mm)
7.09 x 7.09 x 3.54 inches
1.0
.60
.40
.20
3.54 ±0.02
(90 ±0.5)
6.01 ±0.01
(152.7 ±0.3)
7.09 ±0.02
(180 ±0.5)
H
.80
200
300
400
500
AIR FLOW (CFM)
Operating voltage: 115 or 230 VAC
Construction:
aluminum die cast frame;
UL94V-0 PBT impeller
Bearing option:
ball bearing
Rated Freq. Input Rated Locked Speed
Voltage
Power Cur.
Cur.
Air Volume
Max. Static Sound Weight
Pressure (H2 0) Noise
Motor:
permanent split capacitor
V
HZ
W
A
A
RPM
MM
INCH
dbA
kg
Air Flow:
exhaust over struts
UF18JC12 -__H
115
60
72
0.63
2.01
3,400
13
460
27
1.06
59
2.20
Connection:
terminal or 22 AWG lead wires
UF18JC23 -__H
230
60
72
0.31
1.01
3,400
13
460
27
1.06
59
2.20
Protection:
thermal
Options:
dual voltage 115/130VAC,
tachometer output
w w w.mechatronic s.com
11.30.15
Model No.
E - mail: S ales @ M echatronic s.com
Fa x : 425 -2 2 2- 515 5
Tel: 425 -2 2 2- 5 9 0 0
M³/Min. CFM
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF18JC12-BWHR4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+999.386031+128.92336
