UF18JC23-BWHR4
UF18JC23-BWHR4
    MECHATRONICSFANGROUP(机电一体化)
    FAN AXIAL 180X90MM 230VAC WIRE
UF18JC23-BWHR4 数据手册
0.23 (6) 8- Ø 0.22 (8- Ø 5.5 ±0.1) 1.2 STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF18JC-4 series Ø 6.23 (Ø160) (180 x 180 x 90 mm) 7.09 x 7.09 x 3.54 inches 1.0 .60 .40 .20 3.54 ±0.02 (90 ±0.5) 6.01 ±0.01 (152.7 ±0.3) 7.09 ±0.02 (180 ±0.5) H .80 0 100 200 300 400 500 AIR FLOW (CFM) Operating voltage: 115 or 230 VAC Construction: aluminum die cast frame; UL94V-0 PBT impeller Bearing option: ball bearing Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume Max. Static Sound Weight Pressure (H2 0) Noise Motor: permanent split capacitor V HZ W A A RPM MM INCH dbA kg Air Flow: exhaust over struts UF18JC12 -__H 115 60 72 0.63 2.01 3,400 13 460 27 1.06 59 2.20 Connection: terminal or 22 AWG lead wires UF18JC23 -__H 230 60 72 0.31 1.01 3,400 13 460 27 1.06 59 2.20 Protection: thermal Options: dual voltage 115/130VAC, tachometer output w w w.mechatronic s.com 11.30.15 Model No. E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM 800-453-4569 Cooling Simplified
UF18JC23-BWHR4 价格&库存
很抱歉,暂时无法提供与“UF18JC23-BWHR4”相匹配的价格&库存,您可以联系我们找货
