5915PC-22T-B30-BM0
5915PC-22T-B30-BM0
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 172X38MM 220VAC TERM
5915PC-22T-B30-BM0 数据手册
5915PC (150 X 172 X 38L) EMINEBEA.COM -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 25°C 50,000 Hours Motor Structure: Capacitor-Run Induction Motor Motor Protection: Impedance Protection inch Units: (mm) ROTATION Static Pressure (Pa) In H2O 300 .12 AIR NAME PLATE Ps 60Hz 50Hz B30 .8 200 .4 100 B20 B10 0 0 2 4 6 (m3/min) CFM 70 Flange Type .169 2 – (�4.3 ± 0.2) 6.375 (162) 5 (� .94 15 5 1) 5.75 (146) INLET SIDE / OUTLET SIDE 141 212 Air Flow Casing Impeller Bearing Terminal : Aluminum : Polycarbonate (Glass Fiber-Containing) : Ball Bearings : Faston #110 or equivalent 5915PC (150 X 172 X 38L) EMINEBEA.COM Rated MODEL (V) 5915PC-10T-B30-B00 5915PC-22T-B30-B00 5915PC-23T-B30-A00 5915PC-24T-B30-A00 5915PC-10T-B20-B00 5915PC-22T-B20-B00 5915PC-23T-B20-A00 5915PC-24T-B20-A00 5915PC-10T-B10-B00 5915PC-22T-B10-B00 5915PC-23T-B10-A00 5915PC-24T-B10-A00 (Hz) (V) Input Speed Power (A)*1 +10% (W)-20% (min-1)*2 Max. Max. Static Air Flow Pressure CFM*2 (m3/min)*2 in H2O (Pa)*2 Noise Mass (dB)*2 (g) 50 65 0.470 37.0 2700 176.5 5.00 .629 156.8 52.0 800 60 65 0.440 33.0 3200 212.0 6.00 .865 215.6 56.0 800 115 50 75 0.380 35.0 2700 176.5 5.00 .629 156.8 52.0 800 115 60 75 0.360 32.0 3200 212.0 6.00 .865 215.6 56.0 800 200 50 130 0.236 34.0 2700 176.5 5.00 .629 156.8 52.0 800 200 60 130 0.210 33.0 3200 212.0 6.00 .865 215.6 56.0 800 220 50 145 0.210 40.0 2700 176.5 5.00 .629 156.8 52.0 800 220 60 145 0.180 38.0 3200 212.0 6.00 .865 215.6 56.0 800 230 50 145 0.180 35.0 2700 176.5 5.00 .629 156.8 52.0 800 230 60 145 0.190 35.0 3200 212.0 6.00 .865 215.6 56.0 800 240 50 155 0.180 34.0 2700 176.5 5.00 .629 156.8 52.0 800 240 60 155 0.170 34.0 3200 212.0 6.00 .865 215.6 56.0 800 100 50 65 0.250 22.0 2200 141.2 4.00 .393 98.0 46.0 800 100 60 65 0.230 23.0 2600 166.0 4.70 .472 117.6 50.0 800 115 50 75 0.200 21.0 2200 141.2 4.00 .393 98.0 46.0 800 115 60 75 0.210 22.0 2600 166.0 4.70 .472 117.6 50.0 800 200 50 130 0.120 22.0 2200 141.2 4.00 .393 98.0 46.0 800 200 60 130 0.140 23.0 2600 166.0 4.70 .472 117.6 50.0 800 220 50 145 0.110 23.0 2200 141.2 4.00 .393 98.0 46.0 800 220 60 145 0.130 26.0 2600 166.0 4.70 .472 117.6 50.0 800 230 50 145 0.120 23.0 2200 141.2 4.00 .393 98.0 46.0 800 230 60 145 0.140 26.0 2600 166.0 4.70 .472 117.6 50.0 800 240 50 145 0.100 22.0 2200 141.2 4.00 .393 98.0 46.0 800 240 60 145 0.110 26.0 2600 166.0 4.70 .472 117.6 50.0 800 100 50 65 0.170 16.0 1400 84.7 2.40 .173 43.1 35.0 800 100 60 65 0.020 18.0 1650 102.3 2.90 .243 60.7 38.0 800 5915PC-12T-B10-A00 5915PC-20T-B10-B00 Current Voltage 100 5915PC-12T-B20-A00 5915PC-20T-B20-B00 Starting 100 5915PC-12T-B30-A00 5915PC-20T-B30-B00 Frequency Voltage 115 50 75 0.160 16.0 1400 84.7 2.40 .173 43.1 35.0 800 115 60 75 0.190 18.0 1650 102.3 2.90 .243 60.7 38.0 800 200 50 130 0.110 16.0 1400 84.7 2.40 .169 42.1 35.0 800 200 60 130 0.130 18.0 1650 102.3 2.90 .243 60.7 38.0 800 220 50 130 0.100 16.0 1400 84.7 2.40 .169 42.1 35.0 800 220 60 130 0.120 18.0 1650 102.3 2.90 .243 60.7 38.0 800 230 50 145 0.090 16.0 1400 84.7 2.40 .169 43.1 35.0 800 230 60 145 0.110 18.0 1650 102.3 2.90 .243 60.7 38.0 800 240 50 145 0.090 16.0 1400 84.7 2.40 .169 42.1 35.0 800 240 60 145 0.110 18.0 1650 102.3 2.90 .243 60.7 38.0 800 Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air
5915PC-22T-B30-BM0 价格&库存
很抱歉,暂时无法提供与“5915PC-22T-B30-BM0”相匹配的价格&库存,您可以联系我们找货
