15038PB-A0J-GA-00
15038PB-A0J-GA-00
    NMBTECHNOLOGIESCORPORATION
    FAN 100VAC 150X38MM TERM
15038PB-A0J-GA-00 数据手册
15038PB (5915PC) AC Axial Fan / Metal Blades 150X Ф172X38L ■ General Specifications Motor Structure Capacitor-Run Induction Motor Motor Protection Thermal Protection Insulation Resistance Min 100MΩ by DC 500V Megger Dielectric Withstand Voltage:AC1800V 3s Allowable Ambient:­ 10℃ ~ + 60℃ (Operating) Temperature Range ­ 40℃ ~ + 70℃ (Storage) non-condensing environment ■ Expected Life min 300(FROM CAPACITOR COVER) ※ Failure Rate: 10%(L10 Life) 25℃ 100,000 (Hours) ■ Panel Out-cuts EARTH TAP:M4 (Inlet Side)/ (Outlet Side) (0.5mm) EARTH TAP:M4 162.0 ±0.2 AIR NAME PLATE (6) 146.0 2 – φ4.3 2 – φ4.3 .0 52 φ1 172.0 ±1.0 2 – φ4.3 162.0 (7.9) ■ Outline (6) 38.0 ±0.2 150.0 ±0.5 * Only flange type casing is available. ■ Characteristic Curves ■ Material AC FAN 180 50Hz 60Hz AC FAN Static Pressure 160 Ps (Pa) Casing Impeller Bearing Terminal 140 120 100 :Aluminum (Black Painting) :Steel :Ball Bearing :Faston #110 or Equiv 80 60 * Please inquire regarding the potting type (dust & oil-proof type). 40 20 0 0 Lead Wire type is also available. :SPT-1 2X0.824mm2 AWG18 Lead Wire 1.0 2.0 3.0 4.0 5.0 6.0 7.0 Air Flow Q (m3/min) ■ Specifications Model Product No. 15038PB-A0L-EPS- 0 15038PB-A1L-EPS- 0 15038PB-B0L-EPS- 0 15038PB-B2L-EPS- 0 15038PB-B3L-EPS- 0 15038PB-B4L-EPS- 0 Rating Voltage Frequency Starting Voltage (V) (Hz) (V) 50 100 65 60 50 115 75 60 50 200 130 60 50 220 145 60 50 230 150 60 50 240 155 60  Rotation: Counterclockwise as seen from the label side  Airflow Outlet: Label side Current (A)*2 0.530 0.450 0.450 0.400 0.250 0.230 0.250 0.230 0.220 0.200 0.200 0.200 Input Power +10% (W) –20% 42.0 40.0 40.0 38.0 42.0 40.0 42.0 40.0 42.0 40.0 39.0 39.0 Speed (min-1)*3 2650 3150 2650 3150 2650 3150 2650 3150 2650 3150 2650 3150 Max.Air Flow (m3/min)*3 (CFM)*3 5.30 189.3 6.30 225.0 5.30 189.3 6.30 225.0 5.30 189.3 6.30 225.0 5.30 189.3 6.30 225.0 5.30 189.3 6.30 225.0 5.30 189.3 6.30 225.0 Max. Static Pressure (Pa)*1 (In H2O)*1 127.5 0.51 163.8 0.66 127.5 0.51 163.8 0.66 127.5 0.51 163.8 0.66 127.5 0.51 163.8 0.66 127.5 0.51 163.8 0.66 127.5 0.51 163.8 0.66 Noise (dB)*1 48.0 53.0 48.0 53.0 48.0 53.0 48.0 53.0 48.0 53.0 48.0 53.0 Mass (g) 900 *1: Average Values in Free Air *2: Maximum Values in Free Air *3: Minimum Values in Free Air 15038PB (5915PC) 150X Ф172X38L AC Axial Fan / Plastic Blades ■ General Specifications Motor Structure Capacitor-Run Induction Motor Motor Protection Thermal Protection Insulation Resistance Min 100MΩ by DC 500V Megger Dielectric Withstand Voltage:AC1800V 3s Allowable Ambient :­ 10℃ ~ + 70℃ (Operating) Temperature Range ­ 40℃ ~ + 70℃ (Storage) non-condensing environment ■ Expected Life min 300(FROM CAPACITOR COVER) ※ Failure Rate: 10% (L10 Life) 25℃ 100,000 (Hours) (7.9) ■ Outline ■ Panel Out-cuts EARTH TAP:M4 (Inlet Side)/ (Outlet Side) (0.5mm) 162.0 ±0.2 AIR NAME PLATE (6) 146.0 2 – φ4.3 2 – φ4.3 .0 52 φ1 162.0 EARTH TAP:M4 172.0 ±1.0 2 – φ4.3 (6) 38.0 ±0.2 150.0 ±0.5 * Only flange type casing is available. Ps (Pa) 50Hz 60Hz AC FAN Static Pressure 250 ■ Material :Aluminum (Black Painting) :Plastic (Black) UL94V-0 :Ball Bearing :Faston #110 or Equiv 150 Casing Impeller Bearing Terminal 100 * Potting type (dust & water-proof type) is also available. 200 Lead Wire type is also available. Lead Wire :SPT-1 2X0.824mm2 AWG18 50 0 AC FAN ■ Characteristic Curves 0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 Q (m3/min) Air Flow ■ Specifications Model Product No. 15038PB-A0L-EP- 00 15038PB-A1L-EP- 00 15038PB-B0L-EP- 00 15038PB-B2L-EP- 00 15038PB-B3L-EP- 00 15038PB-B4L-EP- 00 Rating Voltage Frequency Starting Voltage (V) (Hz) (V) 50 100 65 60 50 115 75 60 50 200 130 60 50 220 145 60 50 230 145 60 50 240 155 60 Rotation: Counterclockwise as seen from the label side  Airflow Outlet: Label side Current (A)*2 0.470 0.440 0.380 0.360 0.230 0.210 0.210 0.180 0.190 0.180 0.180 0.170 Input Power +10% (W)–20% 37.0 33.0 35.0 32.0 34.0 33.0 40.0 38.0 35.0 35.0 34.0 34.0 Speed (min-1)*3 2700 3200 2700 3200 2700 3200 2700 3200 2700 3200 2700 3200 Max.Air Flow (m3/min)*3 (CFM)*3 5.00 178.6 6.00 214.3 5.00 178.6 6.00 214.3 5.00 178.6 6.00 214.3 5.00 178.6 6.00 214.3 5.00 178.6 6.00 214.3 5.00 178.6 6.00 214.3 Max. Static Pressure (Pa)*3 (In H2O)*3 156.9 0.63 215.8 0.86 156.9 0.63 215.8 0.86 156.8 0.63 215.6 0.86 156.9 0.63 215.8 0.86 157.0 0.63 215.8 0.86 0.63 156.9 215.7 0.86 Noise (dB)*1 52.0 56.0 52.0 56.0 52.0 56.0 52.0 56.0 52.0 56.0 52.0 56.0 Mass (g) 800 *1: Average Values in Free Air *2: Maximum Values in Free Air *3: Minimum Values in Free Air
15038PB-A0J-GA-00 价格&库存
很抱歉,暂时无法提供与“15038PB-A0J-GA-00”相匹配的价格&库存,您可以联系我们找货
