PIN FIN HEAT SINK
900 Series
Wakefield-Vette’s 900 Series Heat Sinks for Chipset can match up
to devices from Intel, Broadcom, Xilinx, TI, Motorola, ATI, AMD,
Nvidia, Vishay, Powerex, Infineon, Microsemi, and many more.
These heat sinks are designed for air flow applications in the
Telecom, Data Center, Networking, Cloud Computing, and many
more Industries.
Material: AL 6063
Finish: Black Anodize
FORCED CONVECTION
SERIES
901
902
903
904
905
FORCED CONVECTION
Height
CHIP SIZE
NATURAL CONVECTION
200 LFM
400 LFM
600 LFM
200 LFM
400 LFM
600 LFM
12
19mm
12.74 C/W
6.6 C/W
4.79 C/W
4.16 C/W
12
31mm
10.71 C/W
3.49 C/W
2.28 C/W
1.69 C/W
15
19mm
12.05 C/W
6.3 C/W
4.51 C/W
3.86 C/W
15
31mm
10.14 C/W
3.18 C/W
2.03 C/W
1.5 C/W
18
19mm
11.35 C/W
5.97 C/W
4.16 C/W
3.47 C/W
18
31mm
9.57 C/W
2.93 C/W
1.86 C/W
1.33 C/W
21
19mm
10.66 C/W
5.66 C/W
3.89 C/W
3.21 C/W
21
31mm
9.01 C/W
2.72 C/W
1.69 C/W
1.2 C/W
23
19mm
10.55 C/W
5.36 C/W
3.64 C/W
2.99 C/W
23
31mm
8.88 C/W
2.5 C/W
1.54 C/W
1.07 C/W
28
19mm
10.27 C/W
4.91 C/W
3.36 C/W
2.71 C/W
28
31mm
8.56 C/W
2.26 C/W
1.38 C/W
.96 C/W
33
19mm
9.99 C/W
4.52 C/W
3.07 C/W
2.49 C/W
33
31mm
8.24 C/W
2.09 C/W
1.27 C/W
.88 C/W
12
21mm
12.4 C/W
6.61 C/W
4.37 C/W
3.7 C/W
12
33mm
10.37 C/W
3.32 C/W
2.18 C/W
1.62 C/W
15
21mm
11.73 C/W
5.84 C/W
4.09 C/W
3.42 C/W
15
33mm
9.82 C/W
3.14 C/W
1.99 C/W
1.45 C/W
18
21mm
11.06 C/W
5.51 C/W
3.76 C/W
3.07 C/W
18
33mm
9.28 C/W
2.89 C/W
1.78 C/W
1.3 C/W
21
21mm
10.38 C/W
5.20 C/W
3.49 C/W
2.84 C/W
21
33mm
8.73 C/W
2.67 C/W
1.60 C/W
1.13 C/W
23
21mm
10.27 C/W
4.9 C/W
3.26 C/W
2.62 C/W
23
33mm
8.60 C/W
2.45 C/W
1.43 C/W
.99 C/W
28
21mm
9.98 C/W
4.55 C/W
2.98 C/W
2.42 C/W
28
33mm
8.27 C/W
2.24 C/W
1.28 C/W
.87 C/W
33
21mm
9.7 C/W
4.18 C/W
2.73 C/W
2.21 C/W
33
33mm
7.94 C/W
2.03 C/W
1.15 C/W
.77 C/W
12
23mm
12.06 C/W
5.72 C/W
3.95 C/W
3.24 C/W
12
35mm
10.03 C/W
3.06 C/W
1.97 C/W
1.49 C/W
15
23mm
11.41 C/W
5.39 C/W
3.67 C/W
2.99 C/W
15
35mm
9.5 C/W
2.85 C/W
1.81 C/W
1.34 C/W
18
23mm
10.76 C/W
5.05 C/W
3.35 C/W
2.67 C/W
18
35mm
8.98 C/W
2.6 C/W
1.64 C/W
1.19 C/W
21
23mm
10.11 C/W
4.74 C/W
3.1 C/W
2.46 C/W
21
35mm
8.46 C/W
2.4 C/W
1.5 C/W
1.07 C/W
23
23mm
9.99 C/W
4.44 C/W
2.87 C/W
2.31 C/W
23
35mm
8.32 C/W
2.19 C/W
1.34 C/W
.97 C/W
28
33
23mm
23mm
9.70 C/W
9.41 C/W
4.09 C/W
3.83 C/W
2.62 C/W
2.43 C/W
2.12 C/W
1.96 C/W
28
33
35mm
35mm
7.99 C/W
7.65 C/W
1.97 C/W
1.82 C/W
1.19 C/W
1.06 C/W
.83 C/W
.7 C/W
12
27mm
11.38 C/W
4.84 C/W
3.11 C/W
2.32 C/W
12
37.5mm
9.60 C/W
2.93 C/W
1.90 C/W
1.36 C/W
15
27mm
10.78 C/W
4.48 C/W
2.84 C/W
2.12 C/W
15
37.5mm
9.11 C/W
2.71 C/W
1.72 C/W
1.19 C//W
18
27mm
10.17 C/W
4.13 C/W
2.56 C/W
1.88 C/W
18
37.5mm
8.61 C/W
2.52 C/W
1.53 C/W
1.05 C/W
21
27mm
9.56 C/W
3.82 C/W
2.32 C/W
1.72 C/W
21
37.5mm
8.11 C/W
2.25 C/W
1.36 C/W
.88 C/W
23
27mm
9.44 C/W
3.51 C/W
2.11 C/W
1.6 C/W
23
37.5mm
7.98 C/W
2.04 C/W
1.2 C/W
.75 C/W
28
27mm
9.13 C/W
3.26 C/W
1.97 C/W
1.49 C/W
28
37.5mm
7.63 C/W
1.82 C/W
1.01 C/W
.63 C/W
33
27mm
8.82 C/W
3.07 C/W
1.82 C/W
1.39 C/W
33
37.5mm
7.29 C/W
1.6 C/W
.87 C/W
.52 C/W
12
29mm
11.04 C/W
4.08 C/W
2.55 C/W
1.98 C/W
12
40mm
9.18 C/W
2.84 C/W
1.86 C/W
1.36 C/W
15
29mm
10.46 C/W
3.82 C/W
2.32 C/W
1.78 C/W
15
40mm
8.71 C/W
2.64 C/W
1.65 C/W
1.18 C/W
18
29mm
9.87 C/W
3.58 C/W
2.14 C/W
1.58 C/W
18
40mm
8.24 C/W
2.4 C/W
1.44 C/W
.98 C/W
21
29mm
9.28 C/W
3.33 C/W
1.96 C/W
1.44 C/W
21
40mm
7.77 C/W
2.21 C/W
1.27 C/W
.86 C/W
23
29mm
9.16 C/W
3.13 C/W
1.82 C/W
1.34 C/W
23
40mm
7.63 C/W
2 C/W
1.15 C/W
.73 C/W
28
29mm
8.84 C/W
2.82 C/W
1.64 C/W
1.2 C/W
28
40mm
7.27 C/W
1.77 C/W
.99 C/W
.62 C/W
33
29mm
8.53 C/W
2.59 C/W
1.47 C/W
1.07 C/W
33
40mm
6.92 C/W
1.58 C/W
.85 C/W
.51 C/W
Series
901-
T h e r m a l
SERIES
906
907
908
909
910
HEIGHT
CHIP SIZE NATURAL CONVECTION
Chip Size
Construction
Height
Chip Height
Finish
19-
2-
12-
1-
B-
12 = 11.6
15 = 14.6
18 = 17.6
21 = 20.6
23 = 22.6
28 = 27.6
33 = 32.6
1 = .9-2.1
2 = 2.2-3.4
19
21
23
27
29
31
33
35
37.5
40
2= Pin Fin
C o o l i n g
S o l u t i o n s
Interface
1
0 = None
1 = T725
B = BLK
ANO
f r o m
S m a r t
www.wakefield-vette.com
t o
F i n i s h
PIN FIN HEAT SINK
900 Series
Wakefield-Vette’s heat sink assembles onto chip set using the space that is between the PCB and
the substrate of the solder balls. The solder balls provide a minimal gap of .5mm to .7mm.
Attachment feature is below a .4mm thickness. The clipping system will not interfere or damage
chip. Contact area is the edge of chip.
ASSEMBLY INSTRUCTION:
Step 1: Hook the
clip under one
side of the BGA
chip set.
Step 2: Rotate
assembly down
until opposite
side clip engages
substrate edge of
BGA chip set.
Random Vibration Test
Frequency :5 Hz to 500 Hz
Acceleration :3.13 grms
P.S.D :0.01 g2/HZ (5 Hz)
0.02 g2/HZ (20 Hz to 500 Hz)
Test Axis :X, Y, Z axis
Test Time :10 mins (Each axis)
Total Test Time :30 mins
T h e r m a l
C o o l i n g
S o l u t i o n s
Step 3: Make sure
the sop rods are
clearing from edges
of BGA chip set.
Step 4: Press firmly
down to make sure
clips fully engage
edges of chip set.
Heat Sink should not
move around easily.
SHOCK TEST SPECIFICATION:
Wave Form :Half sine wave
Acceleration :50 g
Duration Time :11 ms
No. of Shock :Each axis 3 times
Shock Direction :±X, ±Y, ±Z axis
Reliability & Communication
Testing Instruments
f r o m
S m a r t
t o
F i n i s h
很抱歉,暂时无法提供与“903-23-2-28-2-B-0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+54.169371000+7.03207
- 国内价格 香港价格
- 1+63.369571+8.22640
- 10+59.4525010+7.71790
- 20+55.9706520+7.26590
- 50+49.3551550+6.40710
- 90+45.5251290+5.90990
- 国内价格
- 1+75.54525
- 10+70.87383
- 20+66.71746
- 50+58.83594
- 90+54.27232
