2410SB-04W-B20-E00
2410SB-04W-B20-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 60X25MM 12VDC WIRE
2410SB-04W-B20-E00 数据手册
06025SA (60 X 25L) Legacy Part No. 2410SB NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: Auto Restart/Polarity Protection (Pa) 0.80 180 0.72 160 0.64 140 P-Q Curve Speed Curve 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life Failure Rate: 10% 40,000 Hours (AA/EA) 0.56 120 0.48 100 0.40 80 0.32 60 0.24 40 0.16 20 0.00 0 8000 T S 7000 R 6000 P 5000 4000 N L 3000 M 2000 K K 0.0 0.0 0.1 0.2 L M N P 0.4 0.5 0.6 0.3 7.06 DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: 9000 Speed Insulation Resistance: 60°C In H2O 14.12 Q S R 0.7 21.18 1000 T 0 0.8 0.9 28.24 1.0 1.1 35.3 (m3/min) CFM Air Flow Material 11.8 Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black min. (300) Outline ROTATION Panel Cut-Outs 1.97 50 ±0.3 2.36 56 ) 2. 5.0 6 ( 2.28 (58.0) 1.97 (50.0) 2.28 (58.0) 1.97 (50.0) 56 ) 2. 5.0 6 ( 4.3 ±0.2 .169 (4 – φ4.3) .169 (4 – φ4.3) 60 ±0.5 inch Units: (mm) 0.169 8- AIR NAME PLATE 1.97 1.97 (50.0) 2.28 (58.0) 1.97 (50.0) 2.28 (58.0) INLET SIDE OUTLET SIDE (50 ±0.3) .157 .157 (4 ±0.2) (4 ±0.2) 2.36 .98 (60 ±0.5) (25 ±0.5) Specifications Rated MODEL LEGACY P/N Voltage Operating Current Voltage Input Speed Power (V) (V) (A)*1 (W)*1 (min-1)*1 Max. Max. Static Air Flow Pressure CFM*1 (m3/min)*1 in H2O Noise (Pa)*1 (dB)*1 Mass (g) 2410SB-04W-B20-B00 12 6.0 ~ 13.8 0.06 0.72 3000 14.5 0.41 0.10 26 17.0 56 06025SA-12L-AA-D0 2410SB-04W-B30-B00 12 6.0 ~ 13.8 0.08 0.96 3500 16.9 0.48 0.14 35 22.5 56 06025SA-12M-AA-D0 2410SB-04W-B40-B00 12 6.0 ~ 13.8 0.10 1.20 4000 19.8 0.56 0.18 46 26.5 56 06025SA-12N-AA-D0 2410SB-04W-B50-B00 12 6.0 ~ 13.8 0.15 1.80 4700 23.3 0.66 0.25 63 32.0 56 06025SA-12P-AA-D0 2410SB-04W-B60-B00 12 6.0 ~ 13.8 0.17 2.04 4900 24.0 0.68 0.27 68 33.0 56 06025SA-12Q-AA-D0 2410SB-04W-B70-B00 12 6.0 ~ 13.2 0.20 2.40 5300 26.8 0.76 0.32 80 35.0 56 06025SA-12R-AA-D0 2410SB-04W-B80-B00 12 10.8 ~ 13.2 0.23 2.76 6000 30.0 0.85 0.41 101 38.5 56 06025SA-12S-AA-D0 2410SB-04W-B90-B00 12 7.0 ~ 13.2 0.34 4.08 7000 35.7 1.01 0.55 138 42.5 56 06025SA-12T-AA-D0 2410SB-04W-BA0-B00 12 10.8 ~ 13.2 0.43 5.16 7500 37.8 1.07 0.63 158 47.0 56 06025SA-12K-AA-D0 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air PWM/Locked Rotor/Tach Available 06025SA (60 X 25L) Legacy Part No. 2410SB NMBTC.COM / 248.919.2250 Specifications Rated MODEL LEGACY P/N Voltage Operating Current Voltage Input Speed Power Max. Max. Static Air Flow Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 06025SA-24K-AA-D0 2410SB-05W-B20-B00 24 12.0 ~ 27.6 0.03 0.72 3000 14.5 0.41 0.10 26 17.0 06025SA-24L-AA-D0 2410SB-05W-B30-B00 24 12.0 ~ 27.6 0.04 0.96 3500 16.9 0.48 0.14 35 22.5 56 06025SA-24M-AA-D0 2410SB-05W-B40-B00 24 12.0 ~ 27.6 0.06 1.44 4000 19.8 0.56 0.18 46 26.5 56 06025SA-24N-AA-D0 2410SB-05W-B50-B00 24 12.0 ~ 27.6 0.08 1.92 4700 23.3 0.56 0.25 63 32.0 56 06025SA-24P-AA-D0 2410SB-05W-B60-B00 24 12.0 ~ 27.6 0.07 1.68 4900 24.0 0.68 0.27 68 33.0 56 06025SA-24Q-AA-D0 2410SB-05W-B70-B00 24 12.0 ~ 27.6 0.10 2.40 5300 26.8 0.76 0.32 80 35.0 56 06025SA-24R-AA-D0 2410SB-05W-B80-B00 24 12.0 ~ 27.6 0.10 2.40 6000 30.0 0.85 0.41 101 38.5 56 06025SA-24S-AA-D0 2410SB-05W-B90-B00 24 12.0 ~ 27.6 0.17 4.08 7000 35.7 1.01 0.55 138 42.5 56 06025SA-24T-AA-D0 2410SB-05W-BA0-B00 24 10.0 ~ 26.4 0.18 4.32 7500 37.8 1.07 0.64 159 47.0 56 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air 56 PWM/Locked Rotor/Tach Available DCAxial AxialFans Fans DC (V) (V) (A)*1 (W)*1 (min-1)*1 Noise
2410SB-04W-B20-E00 价格&库存
很抱歉,暂时无法提供与“2410SB-04W-B20-E00”相匹配的价格&库存,您可以联系我们找货
