06025SA (60 X 25L)
Legacy Part No. 2410SB
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
Auto Restart/Polarity Protection
(Pa)
0.80
180
0.72
160
0.64
140
P-Q Curve
Speed Curve
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
Failure Rate: 10%
40,000 Hours (AA/EA)
0.56
120
0.48
100
0.40
80
0.32
60
0.24
40
0.16
T
S
7000
R
6000
P
5000
4000
N
L
3000
M
2000
K
K
0.0
0.0
0.1
0.2
L M
N
P
0.4
0.5
0.6
0.3
7.06
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
9000
Speed
Insulation Resistance:
60°C
In H2O
14.12
Q
S
R
0.7
21.18
1000
T
0.9
28.24
1.0
1.1
35.3
(m3/min)
CFM
Air Flow
Material
11.8
Casing : Plastic (Black) 94V-0
Impeller : Plastic (Black) 94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
min. (300)
Outline
ROTATION
Panel Cut-Outs
1.97
50 ±0.3
2.36
56 )
2. 5.0
6
2.28
(58.0)
1.97
(50.0)
2.28
(58.0)
1.97
(50.0)
56 )
2. 5.0
6
4.3 ±0.2
.169
(4 – φ4.3)
.169
(4 – φ4.3)
60 ±0.5
inch
Units: (mm)
0.169
8-
AIR
NAME
PLATE
1.97
1.97
(50.0)
2.28
(58.0)
1.97
(50.0)
2.28
(58.0)
INLET SIDE
OUTLET SIDE
(50 ±0.3)
.157
.157
(4 ±0.2)
(4 ±0.2)
2.36
.98
(60 ±0.5)
(25 ±0.5)
Specifications
Rated
MODEL
LEGACY P/N
Voltage
Operating Current
Voltage
Input
Speed
Power
(V) (V) (A)*1 (W)*1 (min-1)*1
Max.
Max. Static
Air Flow
Pressure
CFM*1 (m3/min)*1 in H2O
Noise
(Pa)*1 (dB)*1
Mass
(g)
2410SB-04W-B20-B00
12
6.0 ~ 13.8
0.06
0.72
3000
14.5
0.41
0.10
26
17.0
56
06025SA-12L-AA-D0
2410SB-04W-B30-B00
12
6.0 ~ 13.8
0.08
0.96
3500
16.9
0.48
0.14
35
22.5
56
06025SA-12M-AA-D0
2410SB-04W-B40-B00
12
6.0 ~ 13.8
0.10
1.20
4000
19.8
0.56
0.18
46
26.5
56
06025SA-12N-AA-D0
2410SB-04W-B50-B00
12
6.0 ~ 13.8
0.15
1.80
4700
23.3
0.66
0.25
63
32.0
56
06025SA-12P-AA-D0
2410SB-04W-B60-B00
12
6.0 ~ 13.8
0.17
2.04
4900
24.0
0.68
0.27
68
33.0
56
06025SA-12Q-AA-D0
2410SB-04W-B70-B00
12
6.0 ~ 13.2
0.20
2.40
5300
26.8
0.76
0.32
80
35.0
56
06025SA-12R-AA-D0
2410SB-04W-B80-B00
12
10.8 ~ 13.2
0.23
2.76
6000
30.0
0.85
0.41
101
38.5
56
06025SA-12S-AA-D0
2410SB-04W-B90-B00
12
7.0 ~ 13.2
0.34
4.08
7000
35.7
1.01
0.55
138
42.5
56
06025SA-12T-AA-D0
2410SB-04W-BA0-B00
12
10.8 ~ 13.2
0.43
5.16
7500
37.8
1.07
0.63
158
47.0
56
06025SA-12K-AA-D0
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
PWM/Locked Rotor/Tach Available
06025SA (60 X 25L)
Specifications
Rated
MODEL
LEGACY P/N
Voltage
Operating Current
Voltage
Input
Speed
Power
Max.
Max. Static
Air Flow
Pressure
(Pa)*1 (dB)*1
Mass
(g)
06025SA-24K-AA-D0
2410SB-05W-B20-B00
24
12.0 ~ 27.6
0.03
0.72
3000
14.5
0.41
0.10
26
17.0
06025SA-24L-AA-D0
2410SB-05W-B30-B00
24
12.0 ~ 27.6
0.04
0.96
3500
16.9
0.48
0.14
35
22.5
56
06025SA-24M-AA-D0
2410SB-05W-B40-B00
24
12.0 ~ 27.6
0.06
1.44
4000
19.8
0.56
0.18
46
26.5
56
06025SA-24N-AA-D0
2410SB-05W-B50-B00
24
12.0 ~ 27.6
0.08
1.92
4700
23.3
0.56
0.25
63
32.0
56
06025SA-24P-AA-D0
2410SB-05W-B60-B00
24
12.0 ~ 27.6
0.07
1.68
4900
24.0
0.68
0.27
68
33.0
56
06025SA-24Q-AA-D0
2410SB-05W-B70-B00
24
12.0 ~ 27.6
0.10
2.40
5300
26.8
0.76
0.32
80
35.0
56
06025SA-24R-AA-D0
2410SB-05W-B80-B00
24
12.0 ~ 27.6
0.10
2.40
6000
30.0
0.85
0.41
101
38.5
56
06025SA-24S-AA-D0
2410SB-05W-B90-B00
24
12.0 ~ 27.6
0.17
4.08
7000
35.7
1.01
0.55
138
42.5
56
06025SA-24T-AA-D0
2410SB-05W-BA0-B00
24
10.0 ~ 26.4
0.18
4.32
7500
37.8
1.07
0.64
159
47.0
56
Rotation: Clockwise
56
DCAxial
AxialFans
Fans
DC
Noise
很抱歉,暂时无法提供与“2410SB-04W-B49-E00”相匹配的价格&库存,您可以联系我们找货
