FBL09A24U1A
FBL09A24U1A
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 92X25.5MM 24VDC WIRE
FBL09A24U1A 数据手册
FBL09A (92 X 25.5L) EMINEBEA.COM THIS MODEL IS NO LONGER AVAILABLE FOR NEW DESIGNS See other models available in this frame size here - 3610KL Allowable Ambient Temperature Range: Failure Rate: 10% -10°C ~ +70°C (65%RH) (Operating) -40°C ~ +75°C (65%RH) (Storage) (non-condensing environment) 50,000 Hours (40°C, 65%RH) inch Units: (mm) outlet inlet Static Pressure 3.25 (82.5) 3.62 (92) 1.00 (25.5) NAME PLATE Ps .157 (4) 3.25 (82.5) 3.62 (92) °ÓÎ 60 °£™ 50 °£x 40 °££ 30 °äÇ 20 °äÎ 10 12V(24V)-H 12V(24V)-M 12V(24V)-L N (m3/min) - Pin + Pin 0 0.2 0.4 0.6 0.8 1.2 1.4 1.6 1.8 1 2 ­ ® FLOW £ä Óä Îä {ä xä Èä Çä Air Flow .185 4 – (f4.7) Bearing: Hydro Wave Bearing 4 (f1 .09 04 ) 3.54 (90) 3.25 (82.5) (min - 1 ) ˜ÊÓ" (Pa) ROTATION Normal Speed .177 4 – (f4.5) 3.25 (82.5) 3.54 (90) OUTLET SIDE Rated Operating Voltage Voltage (V) (V) FBL09A 12L 12 7.0 ~ 13.8 FBL09A 12M 12 7.0 ~ 13.8 FBL09A 12H 12 7.0 ~ 13.8 MODEL Current Power Rated Speed (W)*1 (min-1)*1 110 1.32 2200 42.7 1.21 .10 150 1.80 2450 48.0 1.36 .11 255 2.70 2950 56.8 1.61 .16 42.1 (A)*1 Input Max. Air Flow Max. Static Noise Mass (dB)*1 (g) 25.5 27.0 110 29.4 30.0 110 35.0 110 110 Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 FBL09A 24L 24 14.0 ~ 27.6 80 1.92 2200 42.7 1.21 .10 25.5 27.0 FBL09A 24M 24 14.0 ~ 27.6 110 2.64 2450 48.0 1.36 .11 29.4 30.0 110 FBL09A 24H 24 14.0 ~ 27.6 140 3.36 2950 56.8 1.61 .16 42.1 35.0 110 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air
FBL09A24U1A 价格&库存
很抱歉,暂时无法提供与“FBL09A24U1A”相匹配的价格&库存,您可以联系我们找货
