Additional Resources:
Product Page
date
06/18/2021
page
1 of 7
SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN
60 x 60 mm frame
high fan speed for greater air flow
dual ball bearing construction
auto restart protection standard on all models
MODEL
input
voltage
input
current
range
(Vdc)
CFM-6010-13*
12
6~13.8
CFM-6015-13*
12
6~13.8
CFM-6025-13*
12
6~13.8
rated
speed
air
flow1
static
pressure2
noise
typ
(A)
max
(A)
max
(W)
typ
(RPM)
(CFM)
(inch H2O)
max
(dBA)
0.20
0.26
3.12
5,500
24.18
0.22
41.4
0.17
0.22
2.64
5,100
27.50
0.23
39.0
0.32
0.4
4.8
7,000
36.25
0.67
49.0
1. At 0 inch H20 static pressure.
2. At 0 CFM airflow.
*. Discontinued CFM-6015-13-20, CFM-6015-13-22. CFM-6025-13-10, CFM-6025-13-11, CFM-6025-13-20, CFM-6025-13-22 and CFM-6010-13-22 models.
PART NUMBER KEY
N
Notes:
input
power
TI
rated
(Vdc)
N
U
ED
FEATURES
Reserved for Custom
Configurations
IS
C
Base Number
O
CFM-60 XX - 13 - XX - CXX
Depth
10 = 10 mm
15 = 15 mm
25 = 25 mm
D
Fan Signals
10 = no signals
11 = rotation detector signal
20 = tachometer signal
22 = tachometer signal / PWM control signal
cuidevices.com
Product Page
CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN
date 06/18/2021 │ page 2 of 7
INPUT
conditions/description
current
CFM-6010 models
CFM-6015 models
CFM-6025 models
power
CFM-6010 models
CFM-6015 models
CFM-6025 models
starting voltage
at 25°C
min
typ
max
units
6
12
13.8
Vdc
0.20
0.17
0.32
0.26
0.22
0.4
A
A
A
2.40
2.04
3.84
3.12
2.64
4.8
W
W
W
6
PERFORMANCE
rated speed
at 25°C, after 10 minutes
CFM-6010 models
CFM-6015 models
CFM-6025 models
air flow
at 0 inch H2O, see performance curves
CFM-6010 models
CFM-6015 models
CFM-6025 models
static pressure
at 0 CFM, see performance curves
CFM-6010 models
CFM-6015 models
CFM-6025 models
noise
at 1 m
CFM-6010 models
CFM-6015 models
CFM-6025 models
N
TI
available on all models
rotation detector
available on “11” models
Vdc
typ
max
units
5,500
5,100
7,000
6,050
5,610
7,700
RPM
RPM
RPM
24.18
27.50
36.25
CFM
CFM
CFM
0.22
0.23
0.67
inch H2O
inch H2O
inch H2O
40.0
37.5
48.0
41.4
39.0
49.0
dBA
dBA
dBA
min
typ
max
units
min
typ
max
units
O
parameter
PWM control signal
4,950
4,590
6,300
N
PROTECTIONS / SIGNALS1
available on “20” and “22” models
available on “22” models
1. See application notes for details.
IS
C
Notes:
min
U
parameter
tachometer signal
ED
parameter
operating input voltage
SAFETY & COMPLIANCE
parameter
at 500 Vdc between frame and positive terminal
dielectric strength
at 500 Vac, 60 Hz, 1 minute between frame and
positive terminal
safety approvals
UL/cUL 507, TUV (EN 62368-1)
EMI/EMC
EN 55022:2010+AC:2011 Class B, EN 61000-32:2014, EN 61000-3-3:2013, EN 55024:2010
life expectancy
at 45°C, 15~65% RH
RoHS
yes
D
insulation resistance of frame
10
MΩ
5
70,000
cuidevices.com
mA
hours
Product Page
date 06/18/2021 │ page 3 of 7
ENVIRONMENTAL
min
storage temperature
max
units
-10
70
°C
-40
70
°C
operating humidity
non-condensing
5
storage humidity
non-condensing
5
PERFORMANCE CURVES
0.19
5.00
0.22
0.17
0.09
0.11
2.00
U
6.00
4.00
3.00
2.00
0.06
1.00
0.00
0.00
5.00
10.00
15.00
20.00
25.00
30.00 (CFM)
N
0.00
95
7.00
TI
3.00
0.00
5.00
4.00
0.14
0.05
(mm H 2O)
(Inch H2O)
0.28
6.00
90
N
0.24
CFM-6015
(mm H 2O)
(Inch H2O)
CFM-6010
typ
ED
parameter
operating temperature
1.00
0.00
0.00
5.00
10.00
15.00
20.00
25.00
30.00 (CFM)
(CMM)
0.34
0.51
0.68
0.85
IS
C
(mm H 2O)
CFM-6025
(Inch H2O)
0.17
O
0.00
0.71
18.00
16.00
0.57
14.00
12.00
0.43
0.28
10.00
8.00
6.00
4.00
D
0.14
2.00
0.00
0.00
0.00
10.00
20.00
30.00
40.00 (CFM)
(CMM)
0.00
0.23
0.45
0.68
0.91
1.13
cuidevices.com
(CMM)
0.00
0.17
0.34
0.51
0.68
0.85
Product Page
date 06/18/2021 │ page 4 of 7
MECHANICAL
4 pole DC brushless
min
bearing system
ball bearing
direction of rotation
counter-clockwise viewed from front of fan blade
dimensions
CFM-6010 models: 60 x 60 x 10.6
CFM-6015 models: 60 x 60 x 15.4
CFM-6025 models: 60 x 60 x 25.4
material
PBT (UL94V-0)
weight
CFM-6010 models
CFM-6015 models
CFM-6025 models
U
28.0
40.2
73.0
units: mm [inch]
N
CFM-6010
wire: UL 1061, 26 AWG
Function
Red
+Vin
FG Signal
1
RD Signal
PWM
Blue1
ōŢţŦŭ
O
Yellow
White
-Vin
1
N
Black
TI
WIRE CONNECTIONS
IS
C
CFM-6015
WIRE CONNECTIONS
Wire Color
Function
Red
+Vin
Black
-Vin
1
FG Signal
White1
RD Signal
Blue1
PWM
D
Yellow
Note:
max
units
mm
mm
mm
MECHANICAL DRAWING
Wire Color
typ
ED
parameter
motor
ōŢţŦŭ
1. Wires only present on versions with output signals.
cuidevices.com
g
g
g
Product Page
date 06/18/2021 │ page 5 of 7
MECHANICAL DRAWING (CONTINUED)
units: mm [inch]
ED
CFM-6025
wire: UL 1007, 24 AWG
WIRE CONNECTIONS
Wire Color
Function
Red
+Vin
FG Signal
1
RD Signal
Yellow
White
-Vin
1
U
Black
ōŢţŦŭ
PWM
D
IS
C
O
N
TI
N
Blue1
Note:
cuidevices.com
Product Page
date 06/18/2021 │ page 6 of 7
APPLICATION NOTES
N
U
Figure 1 Current Limit Protection
ED
Auto Restart Protection/Current Limit Protection
When the fan motor is locked, the device will cut off the drive current within two to six seconds and restart automatically
after a few seconds. If the lock situation is continued, the device will work on a repeated cycle of cut-off and restart until
the lock is released. (See Figure 1 below).
TI
Lock Sensor/Rotation Detector
Lock Sensor is used to detect if the fan motor is operating or stopped. Alarm High: the output will be logical low when fan
is operating and be logical high when fan motor is locked. (See Figures 2~3 below).
Figure 3 RD Signal Output Circuit:
Open Collector
Ic=5mA max
N
Figure 2 Alarm High
Output Waveform
O
Pulse Sensor/Tachometer Signal/FG
Pulse Sensor is for detecting the rotational speed of the fan motor. At locked rotor condition, the signal stops cycling and
the output is fixed at VoH or VoL (See Figures 4~5 below).
Figure 5 FG Signal Output Circuit:
Open Collector
IS
C
Figure 4 Output Waveform
Ic=10mA max
D
PMW Control Signal
A speed control lead can be provided that will accept a PWM signal from the customer circuit to vary the speed of the fan.
The change in speed is linear by changing the Duty-Cycle of the PWM. Open collector type and pull-up voltage is changed
by maximum operating voltage and sink current by consuming current. (See Figure 6 below).
Figure 6 Duty Cycle
Vs=4~5 V
cuidevices.com
Product Page
date 06/18/2021 │ page 7 of 7
REVISION HISTORY
rev.
description
date
08/15/2016
initial release
updated datasheet
1.02
discontinued CFM-6025-13-10, CFM-6025-13-11, CFM-6025-13-20,
and CFM-6025-13-22 models
01/29/2018
1.03
updated to be certified to EN 62368-1 safety standard
07/09/2019
1.04
brand update
1.05
discontinued CFM-6015-13-20 and CFM-6015-13-22 models
04/28/2021
discontinued CFM-6010-13-22
06/18/2021
07/27/2017
02/10/2020
U
1.06
ED
1.0
1.01
D
IS
C
O
N
TI
N
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CFM-6010-13-20”相匹配的价格&库存,您可以联系我们找货
