06020SA-24N-AL-00
06020SA-24N-AL-00
    NMBTECHNOLOGIESCORPORATION
    FAN24VDC60X20MM3WR
06020SA-24N-AL-00 数据手册
06020SA (60 X 20L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P−Q CURVE Auto Restart/Polarity Protection In H2O (Pa) .24 60 Insulation Resistance: 5000 N 10M Ω or over with a DC500V Megger .20 50 4500 M 4000 Static Pressure L -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life .16 40 .12 30 .08 20 3500 K 3000 J 2500 2000 M Failure Rate: 10% DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: 60°C SPEED CURVE .04 10 0 0 40,000 Hours (AA/EA) Material K 1500 N 1000 L 500 J 0.2 0.3 0.4 0.5 0.6 0.7 0 0 0 .1 0 3.53 7.06 10.59 14.12 17.65 21.18 24.71 (m3/min) CFM Air Flow Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black Outline 11.82 Min 300 Panel Cut-Outs inch Units: (mm) 1.97 (50.0) 1.97± 0.3 (50.0. ± 0.3) 56 2. .0) 65 (φ 0.169 4-(ø4.3 ± 0.2) Rotation 2.36± 0.3 (60.0. ± 0.5) 56 2. .0) 65 (φ 2.28 (58.0) 1.97 (50.0) .169 (4 –φ4.3 ) 2.28 (58.0) 1.97 (50.0) .169 (4 – φ4.3 ) 1.97 (50.0) 2.28 (58.0) 0.157 (4.0 ± 0.5) 1.97± 0.3 (50.0. ± 0.3) 2.28 (58.0) INLET SIDE AIR NAME PLATE 0.78 (20. ± 0.5) 2.36± 0.3 (60.0. ± 0.5) OUTLET SIDE Specifications Rated Operating Voltage Voltage (V) (V) 06020SA-12J-AA-00 12 6.0 ~ 13.8 0.05 0.58 2800 12.7 0.36 06020SA-12K-AA-00 12 6.0 ~ 13.8 0.05 0.58 3200 14.5 0.41 06020SA-12L-AA-00 12 6.0 ~ 13.8 0.06 0.72 3600 16.6 MODEL Current Input Speed Power (A)*1 (W)*1 Max. Max. Static Air Flow Pressure (min-1)*1 CFM*1 (m3/min)*1 in H2O Noise Mass (Pa)*1 (dB)*1 (g) 0.09 21.2 21.5 0.11 27.6 23.5 56 0.47 0.14 34.7 26.0 56 56 56 06020SA-12M-AA-00 12 6.0 ~ 13.8 0.08 0.96 4000 18.4 0.52 0.17 42.6 28.5 06020SA-12N-AA-00 12 6.0 ~ 13.8 0.09 1.08 4400 20.5 0.58 0.21 52.1 30.5 56 06020SA-24L-AA-00 24 9.0 ~ 27.6 0.05 1.20 3600 16.6 0.47 0.14 34.4 26.0 56 06020SA-24M-AA-00 24 9.0 ~ 27.6 0.06 1.44 4000 18.4 0.52 0.16 40.0 28.5 56 06020SA-24N-AA-00 24 9.0 ~ 27.6 0.07 1.68 4400 20.5 0.58 0.20 49.1 30.5 56 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
06020SA-24N-AL-00 价格&库存
很抱歉,暂时无法提供与“06020SA-24N-AL-00”相匹配的价格&库存,您可以联系我们找货
06020SA-24N-AL-00
    库存:480
