06020SA-12x (60 X 20L)
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
P−Q CURVE
(in H2O)
(Pa)
.24
60
.20
50
Insulation Resistance:
5000
N
10M Ω or over with a DC500V Megger
Allowable Ambient Temperature Range:
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
.16
40
.12
30
.08
K
3000
J
2500
2000
M
Expected Life
Failure Rate: 10%
.04
10
40,000 Hours (AA/EA)
Material
K
1500
N
1000
L
500
J
0.2
0.3
0.4
0.5
0.6
0.7
3.53 7.06 10.59 14.12 17.65 21.18 24.71
(m3/min)
(CFM)
Air Flow Q
Outline
Min 300
(11.82)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
Panel Cut-Outs
4-ø4.3 ±0.2
(0.169)
Rotation
φ6 2.56
50.0
(1.97)
φ6 .56
(2
AIR
NAME
PLATE
(1.97)
50.0. ±0.3
(.169)
(2.36)
4 – φ4.3
(.169)
58.0
(2.28)
4 – φ4.3
60.0. ±0.5
Units: mm (inch)
58.0
(2.28)
50.0
(1.97)
4000
L
Static Pressure Ps
AC 700V 1s or AC 500V 1min
4500
M
REF 4.0
50.0. ±0.3
20.0 ±0.5
(0.78)
(1.97)
60.0. ±0.5
50.0
(1.97)
(2.36)
50.0
(1.97)
58.0
(2.28)
***Outline is A (Rib) Type
58.0
(2.28)
INLET SIDE
Name Plate
OUTLET SIDE
FACTORY ID. 7:CHINA
C:JAPAN
U : CAMBODIA
LOT NO.
7
MODEL
12V
(A)
DC
(B) A
EP
00
Specifications
□ = Casing Form - - - A: Rib Type,
MODEL
06020SA-12K- A-00
06020SA-12L-□A-00
06020SA-12M-□A-00
06020SA-12N-□A-00
(0.157)
MADE IN
+:RED,-:BLACK
(A)
(B)
Model Name
Current
06020SA-12J-□A
0.08
06020SA-12K-□A
0.08
06020SA-12L-□A
0.09
06020SA-12M-□A
0.11
0.14
06020SA-12N-□A
R
VDE
C
US
CHINA or JAPAN or CAMBODIA
94518
CE MARK
VDE MARK
□ = Casing Form - - - A : Rib Type,
E : F lange Type
cULus MARK
E: F lange Type
Current
Input
Speed
Noise
Mass
(dB)*1
(g)
21.2
21.5
56
27.6
23.5
56
34.7
26.0
56
0.17
42.6
28.5
56
0.21
52.1
30.5
56
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
12
6.0 ~ 13.8
0.05
2800
0.36
0.09
12
6.0 ~ 13.8
0.05
3200
0.41
0.11
12
6.0 ~ 13.8
0.06
0.72
3600
0.47
0.14
12
6.0 ~ 13.8
0.08
0.96
4000
0.52
12
6.0 ~ 13.8
0.09
1.08
4400
20.48
0.58
Power
Max.
Max. Static
Air Flow
Pressure
(min-1)*1
(m3/min)
*1: Average Values in Free Air
(in H2O)
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage:
60°C
(min-1)
SPEED CURVE
Speed N
Auto Restart/Polarity Protection
很抱歉,暂时无法提供与“06020SA-12J-AA-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+115.036701+14.91100
- 10+97.1536010+12.59300
- 25+88.5534025+11.47820
- 50+83.4747050+10.81990
