06020SA-24x (60 X 20L)
10%7&&20
Characteristic Curves
General Specifications
Motor Protection:
P−Q CURVE
(in H2O)
(Pa)
.24
60
.20
50
Insulation Resistance:
5000
N
0 RU RYHU ZLWK D '&9 0HJJHU
Static Pressure Ps
$&9VRU$&9PLQ
Allowable Ambient Temperature Range:
&a&2SHUDWLQJ
&a&6WRUDJH
QRQFRQGHQVLQJ HQYLURQPHQW
Failure Rate: 10%
+RXUV$$($
.16
40
.12
30
.08
K
3000
J
2500
2000
.04
10
Material
K
1500
N
1000
L
500
J
0.2
0.3
0.4
0.5
0.6
0.7
3.53 7.06 10.59 14.12 17.65 21.18 24.71
(m3/min)
(CFM)
Air Flow Q
Outline
Min 300
(11.82)
&DVLQJ 3ODVWLF%ODFN8/9
,PSHOOHU 3ODVWLF%ODFN8/9
%HDULQJ %DOO%HDULQJ
/HDG:LUH 8/$:*5HG%ODFN
Panel Cut-Outs
4-ø4.3 ±0.2
(0.169)
Rotation
φ6 2.56
50.0
(1.97)
φ6 .56
(2
AIR
NAME
PLATE
(1.97)
50.0. ±0.3
(.169)
(2.36)
4 – φ4.3
(.169)
58.0
(2.28)
4 – φ4.3
60.0. ±0.5
8QLWVPPLQFK
58.0
(2.28)
50.0
(1.97)
4000
L
M
Expected Life
4500
M
DC Axial Fans
Dielectric Withstand Voltage:
(min-1)
SPEED CURVE
Speed N
$XWR5HVWDUW3RODULW\3URWHFWLRQ
REF 4.0
50.0. ±0.3
20.0 ±0.5
(0.78)
(1.97)
60.0. ±0.5
50.0
(1.97)
(2.36)
50.0
(1.97)
58.0
(2.28)
***Outline is (Rib) Type
58.0
(2.28)
INLET SIDE
Name Plate
OUTLET SIDE
FACTORY ID. 7:CHINA
C:JAPAN
U : CAMBODIA
LOT NO.
7
MODEL
24V
(A)
DC
(B) A
EP
Specifications
Ƒ = Casing Form - - - A: Rib Type,
MODEL
6$. $
Ƒ
6$/Ƒ$
6$0Ƒ$
6$1Ƒ$
(0.157)
00
MADE IN
+:RED,-:BLACK
(A)
(B)
Model Name
Current
06020SA-24J-□A
0.05
06020SA-24K-□A
0.06
06020SA-24L-□A
0.07
06020SA-24M-□A
0.09
06020SA-24N-□A
0.10
R
VDE
C
94518
CE MARK
VDE MARK
US
CHINA or JAPAN or CAMBODIA □ = Casing Form - - - A : Rib Type,
cULus MARK
E : F lange Type
E: F lange Type
Rated
Operating
9oltage
9oltage
Current
Input
Speed
9
9
a
0.0
Power
Max.
0D[ Static
$LU Flow
Pressure
PLQ*1 PPLQ
Noise
0DVV
(LQ+2) G%
J
4400
20.
0.58
0.2
30.5
$YHUDJH 9DOXHV LQ )UHH Air
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“06020SA-24M-AA-00”相匹配的价格&库存,您可以联系我们找货
