06020SA-24M-EA-00
06020SA-24M-EA-00
    NMBTECHNOLOGIESCORPORATION
    FAN24VDC60X20MM2WR
06020SA-24M-EA-00 数据手册
06020SA-24x (60 X 20L) 10%7&&20 Characteristic Curves General Specifications Motor Protection: P−Q CURVE (in H2O) (Pa) .24 60 .20 50 Insulation Resistance: 5000 N 0 Ÿ RU RYHU ZLWK D '&9 0HJJHU Static Pressure Ps $&9VRU$&9PLQ Allowable Ambient Temperature Range: ƒ&aƒ& 2SHUDWLQJ ƒ&aƒ& 6WRUDJH QRQFRQGHQVLQJ HQYLURQPHQW Failure Rate: 10% +RXUV $$($ .16 40 .12 30 .08 20 3500 K 3000 J 2500 2000 .04 10 0 0 Material K 1500 N 1000 L 500 J 0.2 0.3 0.4 0.5 0.6 0.7 0 0 0 .1 0 3.53 7.06 10.59 14.12 17.65 21.18 24.71 (m3/min) (CFM) Air Flow Q Outline Min 300 (11.82) &DVLQJ 3ODVWLF %ODFN 8/9 ,PSHOOHU 3ODVWLF %ODFN 8/9 %HDULQJ %DOO%HDULQJ /HDG:LUH 8/$:*5HG%ODFN Panel Cut-Outs 4-ø4.3 ±0.2 (0.169) Rotation 0 5. ) φ6 2.56 ( 50.0 (1.97) 0 5. ) φ6 .56 (2 AIR NAME PLATE (1.97) 50.0. ±0.3 (.169) (2.36) 4 – φ4.3 (.169) 58.0 (2.28) 4 – φ4.3 60.0. ±0.5 8QLWVPP LQFK 58.0 (2.28) 50.0 (1.97) 4000 L M Expected Life 4500 M DC Axial Fans Dielectric Withstand Voltage: ƒ& (min-1) SPEED CURVE Speed N $XWR5HVWDUW3RODULW\3URWHFWLRQ REF 4.0 50.0. ±0.3 20.0 ±0.5 (0.78) (1.97) 60.0. ±0.5 50.0 (1.97) (2.36) 50.0 (1.97) 58.0 (2.28) ***Outline is (Rib) Type 58.0 (2.28) INLET SIDE Name Plate OUTLET SIDE FACTORY ID. 7:CHINA C:JAPAN U : CAMBODIA LOT NO. 7 ******* MODEL 24V (A) DC (B) A EP Specifications Ƒ = Casing Form - - - A: Rib Type, MODEL 6$. $ Ƒ 6$/Ƒ$ 6$0Ƒ$ 6$1Ƒ$ (0.157) 00 MADE IN +:RED,-:BLACK (A) (B) Model Name Current 06020SA-24J-□A 0.05 06020SA-24K-□A 0.06 06020SA-24L-□A 0.07 06020SA-24M-□A 0.09 06020SA-24N-□A 0.10 R VDE C 94518 CE MARK VDE MARK US CHINA or JAPAN or CAMBODIA □ = Casing Form - - - A : Rib Type, cULus MARK E : F lange Type E: F lange Type Rated Operating 9oltage 9oltage Current Input Speed  9  9  $  :      a 0.0  Power Max. 0D[ Static $LU Flow Pressure  PLQ *1  PPLQ Noise 0DVV (LQ+2)  G%  J                   4400 20. 0.58 0.2  30.5   $YHUDJH 9DOXHV LQ )UHH Air Note: PWM/Locked Rotor/Tach Available
06020SA-24M-EA-00 价格&库存
很抱歉,暂时无法提供与“06020SA-24M-EA-00”相匹配的价格&库存,您可以联系我们找货
