Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
74ALVCH16827
20-bit buffer/line driver, non-inverting
(3-State)
Product specification
IC24 Data Handbook
1998 Jul 27
20-bit buffer/line driver, non-inverting (3-State)
FEATURES
74ALVCH16827
DESCRIPTION
• Wide supply voltage range of 1.2V to 3.6V
• Complies with JEDEC standard no. 8-1A
• CMOS low power consumption
• Direct interface with TTL levels
• Universal bus transceiver with D-type latches and D-type flip-flops
The 74ALVCH16827 is a 20-bit non-inverting buffer/driver with
3-State outputs for bus oriented applications.
The 74ALVCH16827 consists of two 10-bit sections with separate
output enable signals. For either 10-bit buffer section, the two output
enable (1OE1 and 1OE2 or 2OE1 and 2OE2) inputs must both be
active. If either output enable input is high, the outputs of that 10-bit
buffer section are in high impedance state.
The 74ALVCH16827 has active bus hold circuitry which is provided
to hold unused or floating data inputs at a valid logic level. This
feature eliminates the need for external pull-up or pull-down
resistors.
capable of operating in transparent, latched, clocked or
clocked-enabled mode.
• MULTIBYTETM flow-through standard pin-out architecture
• Low inductance multiple VCC and GND pins for minimum noise
and ground bounce
• Current drive ±24 mA at 3.0 V
• All inputs have bus hold circuitry
• Output drive capability 50Ω transmission lines @ 85°C
• 3-State non-inverting outputs for bus oriented applications
QUICK REFERENCE DATA
GND = 0V; Tamb = 25°C; tr = tf = 2.5ns
SYMBOL
PARAMETER
Propagation delay
tPHL/tPLH
CP to Qn
CI
Input capacitance
CPD
CONDITIONS
VCC = 2.5V, CL = 30pF
VCC = 3.3V, CL = 50pF
Output enabled
Output disabled
VI = GND to VCC1
Power dissipation
dissi ation capacitance
ca acitance per
er latch
TYPICAL
2.0
2.0
5
UNIT
ns
pF
pF
F
NOTES:
1. CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD × VCC2 × fi + (CL × VCC2 × fo) where:
fi = input frequency in MHz; CL = output load capacity in pF;
fo = output frequency in MHz; VCC = supply voltage in V;
(CL × VCC2 × fo) = sum of outputs.
ORDERING INFORMATION
PACKAGES
TEMPERATURE RANGE
OUTSIDE NORTH AMERICA
NORTH AMERICA
DWG NUMBER
–40°C to +85°C
74ALVCH16827 DGG
ACH16827 DGG
SOT364-1
56-Pin Plastic TSSOP Type II
PIN DESCRIPTION
PIN NUMBER
SYMBOL
55, 54, 52, 51, 49, 48, 47, 45, 44, 43,
42, 41, 40, 38, 37, 36, 34, 33, 31, 30
1A0 - 1A9
2A0 - 2A9
Data inputs
2, 3, 5, 6, 8, 9, 10, 12, 13, 14,
15, 16, 17, 19, 20, 21, 23, 24, 26, 27
1Y0 - 1Y9
2Y0 - 2Y9
Data outputs
1, 56,
28, 29
1OE0, 1OE1
2OE0, 2OE1
4, 11, 18, 25, 32, 39, 46, 53
GND
Ground (0V)
7, 22, 35, 50
VCC
Positive supply voltage
1998 Jul 27
FUNCTION
Output enable inputs (active-Low)
2
853-2096 19785
PIN CONFIGURATION
LOGIC SYMBOL (IEEE/IEC)
1OE1
1
56
1OE2
1Y0
2
55
1A0
1Y1
3
54
1A1
GND
4
53
GND
1Y2
5
52
1A2
1Y3
6
51
1A3
VCC
7
1Y4
50
8
1Y5
74ALVCH16827
49
9
48
1OE1
1OE2
10
47
1Y0
1Y1
52
5
1Y2
51
6
1Y3
49
8
1Y4
48
9
1Y5
47
10
1Y6
45
12
1Y7
44
13
1A9
43
14
1Y9
2A0
42
15
2Y0
2A1
41
16
2Y1
2A2
40
17
2Y2
1A3
1A5
11
46
55
3
1A2
1A4
EN2
2
1A1
VCC
29
54
1A0
1A6
1A5
GND
EN1
56
2OE1 28
2OE2
1A4
1Y6
1
GND
1A6
1∇
1
1Y7
12
45
1A7
1Y8
13
44
1A8
1Y9
14
43
1A9
2Y0
15
42
2A0
2Y1
16
41
2A1
2Y2
17
40
2A2
GND
18
39
GND
2A3
38
19
2Y3
2Y3
19
38
2A3
2A4
37
2Y4
2Y4
2A4
2A5
36
21
2Y5
21
36
2A5
2A6
34
23
2Y6
VCC
22
35
VCC
2A7
33
24
2Y7
2Y6
23
34
2A6
2A8
31
26
2Y8
2Y7
24
33
2A7
2A9
30
27
2Y9
GND
25
32
GND
2Y8
26
31
2A8
2Y9
27
30
2A9
2OE1
28
29
2OE2
1A7
1A8
2∇
1
1Y8
2Y5
SH00012
SH00010
LOGIC SYMBOL
55
54
52
51
49
48
47
45
44
FUNCTION TABLE
43
INPUTS
1A0 1A1 1A2 1A3 1A4 1A5 1A6
1
1OE1
56
1OE2
1Y0 1Y1 1Y2 1Y3 1Y4 1Y5 1Y6
2
42
3
41
5
40
6
38
8
37
9
36
10
34
2A0 2A1 2A2 2A3 2A4 2A5 2A6
1A7 1A8
1Y7 1Y8
12
33
13
31
1A9
30
2A9
2Y0 2Y1 2Y2 2Y3 2Y4 2Y5 2Y6
2Y7 2Y8
2Y9
15
24
27
2OE1
29
2OE2
16
17
19
23
26
SH00011
1998 Jul 27
nOE2
L
L
L
L
L
L
H
H
H
H
X
Z
X
Z
14
2A7 2A8
28
nOE1
1Y9
H
L
X
Z
3
OUTPUTS
X
H
High voltage level
Low voltage level
Don’t care
High impedance “off” state
A
Y
74ALVCH16827
LOGIC DIAGRAM
nA0
nA1
nA2
nA3
nA4
nA5
nA6
nA7
nA8
nA9
nY0
nY1
nY2
nY3
nY4
nY5
nY6
nY7
nY8
nY9
nOE1
nOE2
SH00013
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
PARAMETER
CONDITIONS
MIN
MAX
DC supply voltage 2.5V range (for max. speed
performance @ 30 pF output load)
2.3
2.7
DC supply voltage 3.3V range (for max. speed
performance @ 50 pF output load)
3.0
3.6
UNIT
V
VI
DC Input voltage range
VCC
V
VO
DC output voltage range
VCC
V
–40
+85
°C
ns/V
Tamb
Operating free-air temperature range
tr, tf
Input rise and fall times
VCC = 2.3 to 3.0V
VCC = 3.0 to 3.6V
ABSOLUTE MAXIMUM RATINGS1
In accordance with the Absolute Maximum Rating System (IEC 134)
Voltages are referenced to GND (ground = 0V)
SYMBOL
VCC
IIK
PARAMETER
CONDITIONS
DC supply voltage
DC input diode current
VI 0
–50
mA
–0.5 to VCC +0.5
DC output diode current
VO VCC or VO 0
VO
DC output voltage
Note 2
IO
DC output source or sink current
VO = 0 to VCC
DC VCC or GND current
Storage temperature range
Power dissipation per package
–plastic medium-shrink (SSOP)
–plastic thin-medium-shrink (TSSOP)
V
For data inputs2
IOK
PTOT
–0.5 to +4.6
–0.5 to +4.6
DC in
input
ut voltage
Tstg
UNIT
For control pins2
VI
IGND, ICC
RATING
For temperature range: –40 to +125 °C
above +55°C derate linearly with 11.3 mW/K
above +55°C derate linearly with 8 mW/K
V
50
mA
–0.5 to VCC +0.5
V
50
mA
100
mA
–65 to +150
°C
850
600
mW
NOTE:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
1998 Jul 27
4
74ALVCH16827
DC ELECTRICAL CHARACTERISTICS
Over recommended operating conditions. Voltage are referenced to GND (ground = 0 V).
LIMITS
SYMBOL
PARAMETER
VIH
HIGH level Input voltage
VIL
LOW level Input voltage
VOH
O
HIGH level output voltage
TEST CONDITIONS
Temp = -40°C to +85°C
MIN
TYP1
VCC = 2.3 to 2.7V
1.7
1.2
VCC = 2.7 to 3.6V
2.0
1.5
UNIT
MAX
V
VCC = 2.3 to 2.7V
1.2
0.7
VCC = 2.7 to 3.6V
1.5
0.8
V
3 to 3
6V; VI = VIH or VIL; IO = –100µA
100µA
VCC = 2
2.3
3.6V;
02
VCC0.2
VCC
VCC = 2.3V; VI = VIH or VIL; IO = –6mA
VCC0.3
VCC0.08
VCC = 2.3V; VI = VIH or VIL; IO = –12mA
VCC0.6
VCC0.26
VCC = 2.7V; VI = VIH or VIL; IO = –12mA
VCC0.5
VCC0.14
VCC = 3.0V; VI = VIH or VIL; IO = –12mA
VCC0.6
VCC0.09
VCC = 3.0V; VI = VIH or VIL; IO = –24mA
VCC1.0
VCC0.28
V
VCC = 2
2.3
3 to 3
3.6V;
6V; VI = VIH or VIL; IO = 100µA
GND
0 20
0.20
V
VCC = 2.3V; VI = VIH or VIL; IO = 6mA
0.07
0.40
V
VCC = 2.3V; VI = VIH or VIL; IO = 12mA
0.15
0.70
VCC = 2.7V; VI = VIH or VIL; IO = 12mA
0.14
0.40
VCC = 3.0V; VI = VIH or VIL; IO = 24mA
0.27
0.55
Input leakage
g current
VCC = 2
2.3
3 to 3
3.6V;
6V;
VI = VCC or GND
0.1
5
µA
µ
IOZ
3-State output OFF-state current
VCC = 2.3 to 3.6V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
µA
ICC
Quiescent supply current
VCC = 2.3 to 3.6V; VI = VCC or GND; IO = 0
0.2
40
µA
∆ICC
Additional quiescent supply current
VCC = 2.3V to 3.6V; VI = VCC – 0.6V; IO = 0
150
750
µA
IBHL2
Bus hold LOW sustaining current
IBHH2
Bus hold HIGH sustaining current
IBHLO2
IBHHO2
VOL
II
LOW level output voltage
VCC = 2.3V; VI = 0.7V
45
VCC = 3.0V; VI = 0.8V
75
150
VCC = 2.3V; VI = 1.7V
–45
VCC = 3.0V; VI = 2.0V
–75
Bus hold LOW overdrive current
VCC = 3.6V
500
µA
Bus hold HIGH overdrive current
VCC = 3.6V
–500
µA
NOTES:
1. All typical values are at Tamb = 25°C.
2. Valid for data inputs of bus hold parts.
1998 Jul 27
V
5
–175
µA
µA
74ALVCH16827
AC CHARACTERISTICS FOR VCC = 2.3V TO 2.7V RANGE
GND = 0V; tr = tf ≤ 2.0ns; CL = 30pF
LIMITS
SYMBOL
PARAMETER
VCC = 2.5 ± 0.2V
WAVEFORM
UNIT
MIN
TYP1
MAX
tPHL/tPLH
Propagation delay
nAn to nYn
1, 3
1.0
2.0
4.1
ns
tPZH/tPZL
3-State output enable time
nOEn to nYn
2, 3
1.0
2.9
6.0
ns
tPHZ/tPLZ
3-State output disable time
nOEn to nYn
2,3
1.2
2.1
5.6
ns
NOTE:
1. All typical values are at VCC = 2.5V and Tamb = 25°C.
AC CHARACTERISTICS FOR VCC = 3.0V TO 3.6V RANGE AND VCC = 2.7V
GND = 0V; tr = tf ≤ 2.5ns; CL = 50pF
LIMITS
SYMBOL
PARAMETER
LIMITS
VCC = 3.3 ± 0.3V
WAVEFORM
VCC = 2.7V
UNIT
MIN
TYP1, 2
MAX
MIN
TYP1
MAX
tPHL/tPLH
Propagation delay
nAn to nYn
1, 3
1.0
2.0
3.4
1.0
2.1
3.9
ns
tPZH/tPZL
nOEn to nYn
2, 3
1.0
2.5
4.7
1.0
3.0
5.7
ns
tPHZ/tPLZ
nOEn to nYn
2, 3
1.3
2.8
4.5
1.3
3.1
4.9
ns
NOTES:
1. All typical values are at VCC Tamb = 25°C.
2. Typical value is measured at VCC = 3.3V.
1998 Jul 27
6
AC WAVEFORMS FOR VCC = 2.3V TO 2.7V AND
VCC < 2.3V RANGE
74ALVCH16827
TEST CIRCUIT
VM = 0.5 V
VX = VOL + 0.15V
VY = VOH –0.15V
VOL and VOH are the typical output voltage drop that occur with the
output load.
PULSE
GENERATOR
DEFINITIONS
RL = Load resistor
CL = Load capacitance includes jig and probe capacitance
RT = Termination resistance should be equal to ZOUT of pulse generators.
SWITCH POSITION
TEST
VM
tPLH/tPHL
GND
tPHL
tPLH
VOH
Yn
OUTPUT
S1
Open
tPLZ/tPZL
2 VCC
tPHZ/tPZH
GND
VCC
VI
< 2.7V
VCC
2.7–3.6V
2.7V
SV00906
VM
Waveform 3. Load circuitry for switching times
VOL
SH00132
Waveform 1. The Input (nAx) to Output (nYx) Propagation
Delays
VI
VM
GND
tPLZ
tPZL
VCC
OUTPUT
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
tPZH
VOH
OUTPUT
HIGH-to-OFF
OFF-to-HIGH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
SH00137
Waveform 2. The 3-State Output Enable and Disable Times
1998 Jul 27
RL = 500 Ω
CL
Test Circuit for switching times
VI
nOE INPUT
D.U.T.
RT
VM = 1.5 V
VX = VOL + 0.3V
VY = VOH –0.3V
output load.
V = 2.7V
I
V =V
I
CC
2 * VCC
Open
GND
RL = 500 Ω
VO
VI
AC WAVEFORMS FOR VCC = 3.0V TO 3.6V AND
VCC = 2.7V RANGE
An
INPUT
S1
VCC
7
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1mm
1998 Jul 27
8
74ALVCH16827
SOT364-1
NOTES
1998 Jul 27
9
74ALVCH16827
74ALVCH16827
Data sheet status
Data sheet
status
Product
status
Definition [1]
Objective
specification
Development
This data sheet contains the design target or goal specifications for product development.
Specification may change in any manner without notice.
Preliminary
specification
Qualification
This data sheet contains preliminary data, and supplementary data will be published at a later date.
Philips Semiconductors reserves the right to make chages at any time without notice in order to
improve design and supply the best possible product.
Product
specification
Production
This data sheet contains final specifications. Philips Semiconductors reserves the right to make
changes at any time without notice in order to improve design and supply the best possible product.
[1] Please consult the most recently issued datasheet before initiating or completing a design.
Definitions
Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For
detailed information see the relevant data sheet or data handbook.
Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one
or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or
at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended
Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips
Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or
modification.
Disclaimers
Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications
do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application.
Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard
cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no
responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these
products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless
otherwise specified.
Copyright Philips Electronics North America Corporation 1998
All rights reserved. Printed in U.S.A.
811 East Arques Avenue
P.O. Box 3409
Sunnyvale, California 94088–3409
Telephone 800-234-7381
print code
Document order number:
1998 Jul 27
10
Date of release: 08-98
9397-750-04556
