Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
DATA SHEET
74AVC16244
16-bit buffer/line driver; 3-state
(3.6 V tolerant)
Product specification
Supersedes data of 1998 Dec 11
File under Integrated Circuits, IC24
1999 Nov 15
(3.6 V tolerant)
74AVC16244
FEATURES
DESCRIPTION
• Wide supply voltage range from 1.2 to 3.6 V
The 74AVC16244 is a 16-bit non-inverting buffer/line
driver with 3-state outputs. This device can be used as four
4-bit buffers, two 8-bit buffers or one 16-bit buffer.
The 3-state outputs are controlled by the output enable
inputs nOE. A HIGH level on input nOE causes the outputs
to assume a high-impedance OFF-state.
• Complies with JEDEC standard no. 8-1A/5/7
• CMOS low power consumption
• Input/output tolerant up to 3.6 V
• Dynamic Controlled Output (DCO) circuit dynamically
changes output impedance, resulting in noise reduction
without speed degradation
This product is designed to have an extremely fast
propagation delay and a minimum amount of power
consumption.
• Low inductance multiple power and ground pins for
minimum noise and ground bounce
To ensure the high-impedance output state during
power-up or power-down, input nOE should be tied to VCC
through a pull-up resistor (live insertion).
• Power off disables 74AVC16244 outputs, permitting live
insertion.
A DCO circuitry is implemented to support termination line
drive during transient (see Figs 1 and 2).
MNA506
MNA507
handbook, halfpage
handbook, halfpage
I OH
(mA)
I OL
(mA)
3.3 V
1.8 V
−100
200
2.5 V
2.5 V
−200
100
1.8 V
3.3 V
−300
2
3
VOH (V)
4
Fig.1 Output current as a function of output voltage.
1999 Nov 15
1
2
3
VOL (V)
4
Fig.2 Output current as a function of output voltage.
2
(3.6 V tolerant)
74AVC16244
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf ≤ 2.0 ns; CL = 30 pF.
SYMBOL
PARAMETER
tPHL/tPLH
propagation delay
nAn to nYn
CI
input capacitance
CPD
power dissipation
capacitance per buffer
CONDITIONS
TYP.
UNIT
VCC = 1.2 V
2.6
ns
VCC = 1.5 V
1.8
ns
VCC = 1.8 V
1.7
ns
VCC = 2.5 V
1.3
ns
VCC = 3.3 V
1.1
ns
5.0
pF
outputs enabled
34
pF
outputs disabled
1
pF
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
∑ (CL × VCC2 × fo) = sum of outputs.
2. The condition is VI = GND to VCC.
FUNCTION TABLE
See note 1.
INPUTS
nOE
OUTPUTS
nAn
L
L
L
L
H
H
H
X
Z
Note
1. H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
1999 Nov 15
nYn
3
(3.6 V tolerant)
74AVC16244
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
TEMPERATURE RANGE
PINS
PACKAGE
MATERIAL
CODE
−40 to +85 °C
48
TSSOP
plastic
SOT362-1
74AVC16244DGG
PINNING
PIN
SYMBOL
DESCRIPTION
1
1OE
output enable input (active LOW)
2, 3, 5 and 6
1Y0 to 1Y3
data outputs
4, 10, 15, 21, 28, 34, 39 and 45
GND
ground (0 V)
7, 18, 31 and 42
VCC
positive supply voltage
8, 9, 11 and 12
2Y0 to 2Y3
data outputs
13, 14, 16 and 17
3Y0 to 3Y3
data outputs
19, 20, 22 and 23
4Y0 to 4Y3
data outputs
24
4OE
25
3OE
26, 27, 29 and 30
4A3 to 4A0
data inputs
32, 33, 35 and 36
3A3 to 3A0
data inputs
37, 38, 40 and 41
2A3 to 2A0
data inputs
43, 44, 46 and 47
1A3 to 1A0
data inputs
48
2OE
1999 Nov 15
4
(3.6 V tolerant)
74AVC16244
handbook, halfpage
handbook, halfpage
1OE 1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
nA0
nY0
nA1
nY1
nA2
nY2
nA3
nY3
nOE
MNA502
GND 10
39 GND
2Y2 11
38 2A2
37 2A3
2Y3 12
3Y0 13
Fig.4 Logic symbol.
16244
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
handbook, halfpage
1
48
25
24
3Y2 16
33 3A2
3Y3 17
32 3A3
47
1EN
2EN
3EN
4EN
1
1
2
46
3
VCC 18
31 VCC
44
5
4Y0 19
30 4A0
43
6
4Y1 20
29 4A1
41
1 2
8
40
9
GND 21
28 GND
38
11
4Y2 22
27 4A2
37
12
4Y3 23
26 4A3
36
4OE 24
25 3OE
35
14
33
16
32
17
1 3
13
MNA501
30
1 4
19
29
22
26
23
MNA503
Fig.3 Pin configuration.
1999 Nov 15
Fig.5 IEEE/IEC logic symbol.
5
(3.6 V tolerant)
74AVC16244
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
PARAMETER
DC supply voltage
CONDITIONS
according JEDEC low-voltage
standards
low-voltage applications
MIN.
MAX.
UNIT
1.65
1.95
V
2.3
2.7
V
3.0
3.6
V
1.2
3.6
V
V
V
VI
DC input voltage
VO
DC output voltage
3-state
HIGH or LOW state
VCC
V
Tamb
operating ambient temperature
in free air
−40
+85
°C
tr,tf
input rise and fall times
VCC = 1.65 to 2.3 V
ns/V
VCC = 2.3 to 3.0 V
ns/V
VCC = 3.0 to 3.6 V
ns/V
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 134); voltages are referenced to GND (ground = 0 V).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCC
DC supply voltage
−0.5
+4.6
V
IIK
DC input diode current
VI < 0 V
−50
mA
VI
DC input voltage
for inputs; note 1
−0.5
+4.6
V
IOK
DC output diode current
VO > VCC or VO < 0 V
±50
mA
VO
DC output voltage
HIGH or LOW state; note 1
−0.5
VCC + 0.5
V
3-state; note 1
−0.5
+4.6
V
VO = 0 V to VCC
±50
mA
IO
DC output source or sink current
ICC,IGND
DC VCC or GND current
±100
mA
Tstg
storage temperature
−65
+150
°C
PD
power dissipation per package
500
mW
temperature range from
−40 to +85 °C; note 2
Notes
1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
2. Above 60 °C the value of PD derates linearly with 5.5 mW/K.
1999 Nov 15
6
(3.6 V tolerant)
74AVC16244
DC CHARACTERISTICS
Over recommended operating conditions; voltages are referenced to GND (ground = 0 V).
TEST CONDITIONS
SYMBOL
PARAMETER
40 to +85
VCC (V)
OTHER
VIH
VIL
VOH
VOL
Tamb (°C)
MAX.
VCC
V
1.65 to 1.95
0.65VCC
0.9
V
2.3 to 2.7
1.7
1.2
V
3.0 to 3.6
2.0
1.5
V
1.2
GND
V
1.65 to 1.95
0.9
0.35VCC V
2.3 to 2.7
1.2
0.7
V
3.0 to 3.6
1.5
0.8
V
IO = −100 µA
1.65 to 3.6
VCC − 0.20
VCC
V
IO = −4 mA
1.65
VCC − 0.45
VCC − 0.10
V
IO = −8 mA
2.3
VCC − 0.55
VCC − 0.28
V
IO = −12 mA
3.0
VCC − 0.70
VCC − 0.32
V
IO = 100 µA
1.65 to 3.6
GND
0.20
V
IO = 4 mA
1.65
0.10
0.45
V
IO = 8 mA
2.3
0.26
0.55
V
IO = 12 mA
3.0
0.36
0.70
V
LOW-level input
voltage
LOW-level output
voltage
TYP.(1)
MIN.
1.2
HIGH-level input
voltage
HIGH-level output
voltage
UNIT
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current per pin
VI = VCC or GND
1.65 to 3.6
0.1
2.5
µA
Ioff
power off leakage
current
VI or VO = 3.6 V
±10
µA
IIHZ/IILZ
input current for
common I/O pins
VI = VCC or GND
1.65 to 3.6
0.1
12.5
µA
IOZ
3-state output
OFF-state current
VI = VIH or VIL;
VO = VCC or GND
1.65 to 2.7
0.1
5
µA
3.0 to 3.6
0.1
10
µA
quiescent supply
current
VI = VCC or GND;
IO = 0
1.65 to 2.7
0.1
µA
3.0 to 3.6
0.2
40
µA
ICC
Note
1. All typical values are measured at Tamb = 25 °C.
1999 Nov 15
7
(3.6 V tolerant)
74AVC16244
AC CHARACTERISTICS
GND = 0 V; tr = tf ≤ 2.0 ns; CL = 30 pF.
TEST CONDITIONS
SYMBOL
propagation delay nAn to nYn
tPZH/tPZL
3-state output enable time
nOE to nYn
tPHZ/tPLZ
−40 to +85 °C
PARAMETER
WAVEFORMS
tPHL/tPLH
Tamb
see Figs 6 and 8
see Figs 7 and 8
3-state output disable time
nOE to nYn
see Figs 7 and 8
VCC (V)
MIN.
TYP.(1)
2.6
ns
1.8
ns
1.65 to 1.95 0.7
1.7
3.1
ns
2.3 to 2.7
0.6
1.3
1.9
ns
3.0 to 3.6
0.5
1.1
1.7
ns
1.2
5.2
ns
1.40 to 1.60 −
3.3
ns
1.65 to 1.95 1.3
2.7
5.5
ns
2.3 to 2.7
1.9
4.3
ns
1.2
0.9
3.0 to 3.6
0.7
1.7
3.5
ns
1.2
5.7
ns
1.40 to 1.60 −
4.3
ns
1.65 to 1.95 2.0
3.2
6.2
ns
2.3 to 2.7
1.0
1.9
4.0
ns
3.0 to 3.6
1.2
1.8
3.5
ns
1. All typical values are measured at Tamb = 25 °C and at VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V or 3.3 V.
AC WAVEFORMS
handbook, halfpage VI
VM
GND
t PHL
t PLH
VOH
nYn output
VM
VOL
VCC
VM
MNA504
VI
≤2.3 to 2.7 V
0.5VCC
VCC
3.0 to 3.6 V
0.5VCC
VCC
VOL and VOH are typical output voltage drop that occur with the output load.
Fig.6 The input (nAn) to output (nYn) propagation delay.
1999 Nov 15
8
MAX.
1.40 to 1.60 −
Note
nAn input
UNIT
(3.6 V tolerant)
74AVC16244
VI
handbook, full pagewidth
nOE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
enabled
outputs
disabled
MNA478
VCC
VM
VX
VY
VI
≤2.3 to 2.7 V
0.5VCC
VOL + 0.15 V
VOH − 0.15 V VCC
3.0 to 3.6 V
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
VCC
Fig.7 The 3-state output enable and disable times.
S1
VCC
PULSE
GENERATOR
VI
2 × VCC
open
GND
R load
VO
D.U.T.
CL
RT
R load
MNA505
TEST
S1
VCC
VI
Rload
VCC
1000 Ω
tPLH/tPHL
open
