Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
74LVT162240A
3.3 V LVT 16-bit inverting buffer/driver
with 30 Ω termination resistors (3-State)
Product data
Supersedes data of 1998 Feb 19
2003 Feb 21
Product data
FEATURES
74LVT162240A
DESCRIPTION
• 16-bit bus interface
• 3-State buffers
• Output capability: +12 mA/–12 mA
• TTL input and output switching levels
• Input and output interface capability to systems at 5 V supply
• Bus-hold data inputs eliminate the need for external pull-up
The 74LVT162240A is a high-performance BiCMOS product
designed for VCC operation at 3.3 V.
This device is an inverting 16-bit buffer that is ideal for driving bus
lines. The device features four Output Enables (1OE, 2OE, 3OE,
4OE), each controlling four of the 3-State outputs.
The 74LVT162240A is designed with 30 Ω series resistance in both
the pull-up and pull-down output structures. This design reduces line
noise in applications such as memory address drivers, clock drivers,
and bus receivers/transmitters.
resistors to hold unused inputs
• Live insertion/extraction permitted
• Outputs include series resistance of 30 Ω making external
The 74LVT162240A is the same as the 74LVT16240A-1. The part
number has been changed to reflect industry standards.
termination resistors unnecessary
• Power-up 3-State
• No bus current loading when output is tied to 5 V bus
• Latch-up protection exceeds 500 mA per JEDEC Std 17
• ESD protection exceeds 2000 V per MIL STD 883 Method 3015
and 200 V per Machine Model
• Same part as 74LVT16240A-1
QUICK REFERENCE DATA
SYMBOL
CONDITIONS
Tamb = 25 °C
PARAMETER
tPLH
tPHL
Propagation delay
nAx to nYx
CL = 50 pF;
VCC = 3.3 V
CIN
TYPICAL
UNIT
2.6
ns
Input capacitance nOE
VI = 0 V or 3.0 V
3
pF
COUT
Output capacitance
VO = 0 V or 3.0 V
9
pF
ICCZ
Total supply current
Outputs disabled; VCC = 3.6 V
70
µA
ORDERING INFORMATION
TEMPERATURE RANGE
PART NUMBER
DWG NUMBER
48-Pin Plastic SSOP Type III
PACKAGES
–40 °C to +85 °C
74LVT162240ADL
SOT370-1
48-Pin Plastic TSSOP Type II
–40 °C to +85 °C
74LVT162240ADGG
SOT362-1
LOGIC SYMBOL
47
1A0
1Y0
46
1A1
1Y1
1A2
1Y2
1A3
1Y3
44
43
1
1OE
41
2A0
2Y0
2A1
2Y1
2A2
2Y2
2A3
2Y3
40
38
37
48
2OE
2
36 3A0
3Y0
3
35 3A1
3Y1
5
33
3A2
3Y2
3A3
3Y3
6
32
13
14
16
17
25 3OE
8
30
9
29
11
27
12
26
24
4A0
4Y0
4A1
4Y1
4A2
4Y2
4A3
4Y3
19
23
4OE
SW00004
2003 Feb 21
2
Product data
LOGIC SYMBOL (IEEE/IEC)
1OE
1
2OE
EN2
3OE
25
EN3
4OE
24
EN4
1A1
1A2
1A3
2A0
2A1
2A2
2A3
3A0
3A1
3A2
3A3
4A0
4A1
4A2
4A3
PIN CONFIGURATION
EN1
48
1A0
74LVT162240A
47
1∇
1
46
44
2
1Y0
3
1Y1
5
43
41
2∇
1
40
3∇
1
35
1A1
45
GND
1Y2
5
44
1A2
1Y3
6
43
1A3
VCC
7
42
VCC
2Y0
8
41
2A0
2A1
10
39
GND
2Y2
11
38
2A2
2Y3
12
37
2A3
3Y0
13
36
3A0
3Y1
14
35
3A1
GND
15
34
GND
13
2Y1
2Y2
2Y3
3Y0
3Y1
17
3Y3
19
4Y0
4Y1
27
22
26
23
3Y2
16
33
3A2
3Y4
17
32
3A3
VCC
18
31
VCC
4Y0
19
30
4A0
4Y1
4A1
GND
21
28
GND
4Y2
22
27
4A2
4Y3
23
26
4A3
4OE
24
25
3OE
4Y2
4Y3
SW00059
FUNCTION TABLE
OUTPUTS
nOE
nAx
nYx
L
L
H
L
H
L
H
X
Z
SW00006
PIN DESCRIPTION
H = HIGH voltage level
L = LOW voltage level
X = Don’t care
Z = High Impedance “off ” state
SCHEMATIC OF EACH OUTPUT
VCC
VCC
27 Ω
OUTPUT
27 Ω
SW00007
2003 Feb 21
46
4
GND
32
INPUTS
3
2Y0
3Y2
29
1Y1
GND
8
16
4∇
1A0
40
33
1
47
9
14
30
2OE
1Y0
2Y1
12
36
48
1Y3
11
37
1
2
6
9
38
1Y2
1OE
3
PIN NUMBER
SYMBOL
NAME AND FUNCTION
47, 46, 44, 43,
41, 40, 38, 37,
36, 35, 33, 32,
30, 29, 27, 26
1A0 – 1A3
2A0 – 2A3
3A0 – 3A3
4A0 – 4A3
Data inputs
2, 3, 5, 6,
8, 9, 11, 12,
13, 14, 16, 17,
19, 20, 22, 23
1Y0 – 1Y3
2Y0 – 2Y3
3Y0 – 3Y3
4Y0 – 4Y3
Data outputs
1, 48
25, 24
1OE, 2OE,
3OE, 4OE
Output enables
4, 10, 15, 21,
28, 34, 39, 45
GND
Ground (0 V)
7, 18, 31, 42
VCC
Positive supply voltage
Product data
74LVT162240A
ABSOLUTE MAXIMUM RATINGS1, 2
PARAMETER
SYMBOL
VCC
IIK
RATING
UNIT
–0.5 to +4.6
V
–50
mA
–0.5 to +7.0
V
VO < 0 V
–50
mA
Output in Off or HIGH state
–0.5 to +7.0
V
Output in LOW state
128
Output in HIGH state
–64
DC supply voltage
DC input diode current
VI < 0 V
voltage3
VI
DC input
IOK
DC output diode current
VOUT
CONDITIONS
DC output
voltage3
IOUT
O
DC output current
Tstg
Storage temperature range
mA
–65 to +150
°C
NOTES:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C.
3. The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
RECOMMENDED OPERATING CONDITIONS
LIMITS
SYMBOL
VCC
PARAMETER
UNIT
DC supply voltage
MIN
MAX
2.7
3.6
V
V
VI
Input voltage
VIH
HIGH-level input voltage
VIL
Input voltage
0.8
V
IOH
HIGH-level output current
–12
mA
IOL
LOW-level output current
12
mA
∆t/∆v
Input transition rise or fall rate; Outputs enabled
10
ns/V
Tamb
Operating free-air temperature range
+85
°C
2003 Feb 21
2.0
–40
4
V
Product data
74LVT162240A
DC ELECTRICAL CHARACTERISTICS
LIMITS
SYMBOL
PARAMETER
TEST CONDITIONS
Tamb = –40°C to +85°C
MIN
VIK
Input clamp voltage
VCC = 2.7 V; IIK = –18 mA
VOH
HIGH-level output voltage
VCC = 3.0 V; IOH = –12 mA
VOL
LOW-level output voltage
VCC = 3.0 V; IOL = 12 mA
IOFF
IHOLD
Input leakage current
Bus Hold current A
outputs6
–0.85
1.2
2.0
0.8
0.4
10
0.1
1
VCC = 3.6 V; VI = 0 V
–0.4
–5
VCC = 0 V; VI or VO = 0 V to 4.5 V
0.1
±100
Control pins
VCC = 0 V or 3.6 V; VI = 5.5 V
Data
pins4
UNIT
V
V
±1
VCC = 3.6 V; VI = VCC
Output off current
MAX
0.1
VCC = 3.6 V; VI = VCC or GND
II
TYP1
VCC = 3 V; VI = 0.8 V
75
135
VCC = 3 V; VI = 2.0 V
–75
–135
VCC = 0 V to 3.6 V; VCC = 3.6 V
±500
V
µA
µA
µA
Current into an output in the
HIGH state when VO > VCC
VO = 5.5 V; VCC = 3.0 V
50
125
µA
Power-up/down 3-State output
current3
VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC
OE/OE = Don’t care
1
±100
µA
IOZH
3-State output HIGH current
VCC = 3.6 V; VO = 3.0 V; VI = VIL or VIH
0.5
5
µA
IOZL
3-State output LOW current
VCC = 3.6 V; VO = 0.5 V; VI = VIL or VIH
0.5
–5
µA
VCC = 3.6 V; Outputs HIGH, VI = GND or VCC, IO = 0
0.07
0.12
VCC = 3.6 V; Outputs LOW, VI = GND or VCC, IO = 0
4.0
6
VCC = 3.6 V; Outputs Disabled;
VI = GND or VCC, IO = 05
0.07
0.12
VCC = 3 V to 3.6 V; One input at VCC–0.6 V,
Other inputs at VCC or GND
0.1
0.20
IEX
IPU/PD
ICCH
ICCL
Quiescent su
supply
ly current
ICCZ
∆ICC
Additional supply current per
input pin2
mA
mA
NOTES:
1. All typical values are at VCC = 3.3 V and Tamb = 25 °C.
2. This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
3. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 msec. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V
a transition time of 100 µsec is permitted. This parameter is valid for Tamb = 25 °C only.
4. Unused pins at VCC or GND.
5. ICCZ is measured with outputs pulled to VCC or GND.
6. This is the bus hold overdrive current required to force the input to the opposite logic state.
2003 Feb 21
5
Product data
74LVT162240A
AC CHARACTERISTICS
GND = 0 V; tR = tF = 2.5 ns; CL = 50 pF; RL = 500 Ω; Tamb = –40 °C to +85 °C.
LIMITS
SYMBOL
PARAMETER
VCC = 3.3 V ±0.3 V
VCC = 2.7 V
MIN
TYP1
MAX
MAX
WAVEFORM
UNIT
tPLH
tPHL
Propagation delay
nAx to nYx
1
0.5
0.5
2.6
2.6
4.2
4.2
5.0
5.0
ns
tPZH
tPZL
Output enable time
to HIGH and LOW level
2
1.0
1.0
3.3
3.0
5.5
5.0
6.5
5.5
ns
tPHZ
tPLZ
Output disable time
from HIGH and LOW Level
2
1.0
1.0
3.5
3.2
5.0
4.5
5.5
4.5
ns
NOTE:
AC WAVEFORMS
VM = 1.5 V; VIN = GND to 2.7 V
2.7 V
nOE INPUT
1.5 V
1.5 V
2.7 V
nAx INPUT
1.5 V
0V
tPZL
1.5 V
tPLZ
3.0 V
0V
tPHL
1.5 V
nYx OUTPUT
tPLH
VOL + 0.3 V
VOL
VOH
tPHZ
tPZH
nYx OUTPUT
1.5 V
VOH
1.5 V
nYx OUTPUT
VOL
1.5 V
VOH – 0.3 V
0V
SW00001
SW00002
Waveform 1. Input (nAx) to Output (nYx) Propagation Delays
2003 Feb 21
Waveform 2. 3-State Output Enable and Disable Times
6
Product data
74LVT162240A
TEST CIRCUIT AND WAVEFORMS
6V
VCC
OPEN
VOUT
VIN
PULSE
GENERATOR
tW
90%
RL
GND
VM
NEGATIVE
PULSE
CL
10%
0V
RL
tTHL (tF)
tTLH (tR)
tTLH (tR)
tTHL (tF)
90%
POSITIVE
PULSE
Test Circuit for 3-State Outputs
SWITCH
tPHZ/tPZH
GND
tPLZ/tPZL
6V
tPLH/tPHL
open
AMP (V)
90%
VM
VM
10%
10%
tW
SWITCH POSITION
TEST
AMP (V)
VM
10%
D.U.T.
RT
90%
0V
VM = 1.5 V
Input Pulse Definition
INPUT PULSE REQUIREMENTS
DEFINITIONS
FAMILY
RL = Load resistor; see AC CHARACTERISTICS for value.
CL = Load capacitance includes jig and probe capacitance;
74LVT16
Amplitude
Rep. Rate
2.7 V
≤10 MHz
tW
tR
tF
500 ns ≤2.5 ns ≤2.5 ns
RT = Termination resistance should be equal to ZOUT of
pulse generators.
SW00003
2003 Feb 21
7
Product data
SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm
2003 Feb 21
8
74LVT162240A
SOT370-1
Product data
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
2003 Feb 21
9
74LVT162240A
SOT362-1
Product data
74LVT162240A
REVISION HISTORY
Rev
Date
Description
_3
20030221
Product data (9397 750 11157); ECN 853-1777 29438 of 29 January 2003;
supersedes data of 1998 Feb 19 (9397 750 03548).
Modifications:
• Ordering information table on page 2 corrected: remove ‘North America’ column.
• “Logic symbol (IEEE/IEC)” on page 3 modified to correct pin names.
_2
19980219
Product specification (9397 750 03548); ECN 853–1777 18990; supersedes data of 1995 Aug 22.
Data sheet status
Level
Data sheet status [1]
Product
status [2] [3]
Definitions
I
Objective data
Development
This data sheet contains data from the objective specification for product development.
Philips Semiconductors reserves the right to change the specification in any manner without notice.
II
Preliminary data
Qualification
This data sheet contains data from the preliminary specification. Supplementary data will be published
at a later date. Philips Semiconductors reserves the right to change the specification without notice, in
order to improve the design and supply the best possible product.
III
Product data
Production
This data sheet contains data from the product specification. Philips Semiconductors reserves the
right to make changes at any time in order to improve the design, manufacturing and supply. Relevant
changes will be communicated via a Customer Product/Process Change Notification (CPCN).
[1] Please consult the most recently issued data sheet before initiating or completing a design.
[2] The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL
http://www.semiconductors.philips.com.
[3] For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status.
Definitions
Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see
the relevant data sheet or data handbook.
Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting
values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given
in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability.
Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no
representation or warranty that such applications will be suitable for the specified use without further testing or modification.
Disclaimers
Life support — These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be
expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree
to fully indemnify Philips Semiconductors for any damages resulting from such application.
Right to make changes — Philips Semiconductors reserves the right to make changes in the products—including circuits, standard cells, and/or software—described
or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated
via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys
no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent,
copyright, or mask work right infringement, unless otherwise specified.
Koninklijke Philips Electronics N.V. 2003
All rights reserved. Printed in U.S.A.
Contact information
For additional information please visit
Fax: +31 40 27 24825
Date of release: 02-03
For sales offices addresses send e-mail to:
sales.addresses@www.semiconductors.philips.com.
Document order number:
2003 Feb 21
10
9397 750 11157
