CFM-6025-13-11
CFM-6025-13-11
    CUIDEVICES
    DCAXIALFAN,60MMSQUARE,25M
CFM-6025-13-11 数据手册
Additional Resources: Product Page date 06/18/2021 page 1 of 7 SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN 60 x 60 mm frame high fan speed for greater air flow dual ball bearing construction auto restart protection standard on all models MODEL input voltage input current range (Vdc) CFM-6010-13* 12 6~13.8 CFM-6015-13* 12 6~13.8 CFM-6025-13* 12 6~13.8 rated speed air flow1 static pressure2 noise typ (A) max (A) max (W) typ (RPM) (CFM) (inch H2O) max (dBA) 0.20 0.26 3.12 5,500 24.18 0.22 41.4 0.17 0.22 2.64 5,100 27.50 0.23 39.0 0.32 0.4 4.8 7,000 36.25 0.67 49.0 1. At 0 inch H20 static pressure. 2. At 0 CFM airflow. *. Discontinued CFM-6015-13-20, CFM-6015-13-22. CFM-6025-13-10, CFM-6025-13-11, CFM-6025-13-20, CFM-6025-13-22 and CFM-6010-13-22 models. PART NUMBER KEY N Notes: input power TI rated (Vdc) N U • • • • ED FEATURES Reserved for Custom Configurations IS C Base Number O CFM-60 XX - 13 - XX - CXX Depth 10 = 10 mm 15 = 15 mm 25 = 25 mm D Fan Signals 10 = no signals 11 = rotation detector signal 20 = tachometer signal 22 = tachometer signal / PWM control signal cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 2 of 7 INPUT conditions/description current CFM-6010 models CFM-6015 models CFM-6025 models power CFM-6010 models CFM-6015 models CFM-6025 models starting voltage at 25°C min typ max units 6 12 13.8 Vdc 0.20 0.17 0.32 0.26 0.22 0.4 A A A 2.40 2.04 3.84 3.12 2.64 4.8 W W W 6 PERFORMANCE conditions/description rated speed at 25°C, after 10 minutes CFM-6010 models CFM-6015 models CFM-6025 models air flow at 0 inch H2O, see performance curves CFM-6010 models CFM-6015 models CFM-6025 models static pressure at 0 CFM, see performance curves CFM-6010 models CFM-6015 models CFM-6025 models noise at 1 m CFM-6010 models CFM-6015 models CFM-6025 models N TI conditions/description auto restart protection available on all models rotation detector available on “11” models Vdc typ max units 5,500 5,100 7,000 6,050 5,610 7,700 RPM RPM RPM 24.18 27.50 36.25 CFM CFM CFM 0.22 0.23 0.67 inch H2O inch H2O inch H2O 40.0 37.5 48.0 41.4 39.0 49.0 dBA dBA dBA min typ max units min typ max units O parameter PWM control signal 4,950 4,590 6,300 N PROTECTIONS / SIGNALS1 available on “20” and “22” models available on “22” models 1. See application notes for details. IS C Notes: min U parameter tachometer signal ED parameter operating input voltage SAFETY & COMPLIANCE parameter conditions/description at 500 Vdc between frame and positive terminal dielectric strength at 500 Vac, 60 Hz, 1 minute between frame and positive terminal safety approvals UL/cUL 507, TUV (EN 62368-1) EMI/EMC EN 55022:2010+AC:2011 Class B, EN 61000-32:2014, EN 61000-3-3:2013, EN 55024:2010 life expectancy at 45°C, 15~65% RH RoHS yes D insulation resistance of frame 10 MΩ 5 70,000 cuidevices.com mA hours Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 3 of 7 ENVIRONMENTAL conditions/description min storage temperature max units -10 70 °C -40 70 °C operating humidity non-condensing 5 storage humidity non-condensing 5 PERFORMANCE CURVES 0.19 5.00 0.22 0.17 0.09 0.11 2.00 U % 6.00 4.00 3.00 2.00 0.06 1.00 0.00 0.00 5.00 10.00 15.00 20.00 25.00 30.00 (CFM) N 0.00 95 7.00 TI 3.00 0.00 % 5.00 4.00 0.14 0.05 (mm H 2O) (Inch H2O) 0.28 6.00 90 N 0.24 CFM-6015 (mm H 2O) (Inch H2O) CFM-6010 typ ED parameter operating temperature 1.00 0.00 0.00 5.00 10.00 15.00 20.00 25.00 30.00 (CFM) (CMM) 0.34 0.51 0.68 0.85 IS C (mm H 2O) CFM-6025 (Inch H2O) 0.17 O 0.00 0.71 18.00 16.00 0.57 14.00 12.00 0.43 0.28 10.00 8.00 6.00 4.00 D 0.14 2.00 0.00 0.00 0.00 10.00 20.00 30.00 40.00 (CFM) (CMM) 0.00 0.23 0.45 0.68 0.91 1.13 cuidevices.com (CMM) 0.00 0.17 0.34 0.51 0.68 0.85 Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 4 of 7 MECHANICAL conditions/description 4 pole DC brushless min bearing system ball bearing direction of rotation counter-clockwise viewed from front of fan blade dimensions CFM-6010 models: 60 x 60 x 10.6 CFM-6015 models: 60 x 60 x 15.4 CFM-6025 models: 60 x 60 x 25.4 material PBT (UL94V-0) weight CFM-6010 models CFM-6015 models CFM-6025 models U 28.0 40.2 73.0 units: mm [inch] N CFM-6010 wire: UL 1061, 26 AWG Function Red +Vin FG Signal 1 RD Signal PWM Blue1 ōŢţŦŭ O Yellow White -Vin 1 N Black TI WIRE CONNECTIONS IS C CFM-6015 wire: UL 1061, 26 AWG WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin 1 FG Signal White1 RD Signal Blue1 PWM D Yellow Note: max units mm mm mm MECHANICAL DRAWING Wire Color typ ED parameter motor ōŢţŦŭ 1. Wires only present on versions with output signals. cuidevices.com g g g Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 5 of 7 MECHANICAL DRAWING (CONTINUED) units: mm [inch] ED CFM-6025 wire: UL 1007, 24 AWG WIRE CONNECTIONS Wire Color Function Red +Vin FG Signal 1 RD Signal Yellow White -Vin 1 U Black ōŢţŦŭ PWM D IS C O N TI N Blue1 Note: 1. Wires only present on versions with output signals. cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 6 of 7 APPLICATION NOTES N U Figure 1 Current Limit Protection ED Auto Restart Protection/Current Limit Protection When the fan motor is locked, the device will cut off the drive current within two to six seconds and restart automatically after a few seconds. If the lock situation is continued, the device will work on a repeated cycle of cut-off and restart until the lock is released. (See Figure 1 below). TI Lock Sensor/Rotation Detector Lock Sensor is used to detect if the fan motor is operating or stopped. Alarm High: the output will be logical low when fan is operating and be logical high when fan motor is locked. (See Figures 2~3 below). Figure 3 RD Signal Output Circuit: Open Collector Ic=5mA max N Figure 2 Alarm High Output Waveform O Pulse Sensor/Tachometer Signal/FG Pulse Sensor is for detecting the rotational speed of the fan motor. At locked rotor condition, the signal stops cycling and the output is fixed at VoH or VoL (See Figures 4~5 below). Figure 5 FG Signal Output Circuit: Open Collector IS C Figure 4 Output Waveform Ic=10mA max D PMW Control Signal A speed control lead can be provided that will accept a PWM signal from the customer circuit to vary the speed of the fan. The change in speed is linear by changing the Duty-Cycle of the PWM. Open collector type and pull-up voltage is changed by maximum operating voltage and sink current by consuming current. (See Figure 6 below). Figure 6 Duty Cycle Vs=4~5 V cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-60 │ DESCRIPTION: DC AXIAL FAN date 06/18/2021 │ page 7 of 7 REVISION HISTORY rev. description date 08/15/2016 initial release updated datasheet 1.02 discontinued CFM-6025-13-10, CFM-6025-13-11, CFM-6025-13-20, and CFM-6025-13-22 models 01/29/2018 1.03 updated to be certified to EN 62368-1 safety standard 07/09/2019 1.04 brand update 1.05 discontinued CFM-6015-13-20 and CFM-6015-13-22 models 04/28/2021 discontinued CFM-6010-13-22 06/18/2021 07/27/2017 02/10/2020 U 1.06 ED 1.0 1.01 D IS C O N TI N The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CFM-6025-13-11 价格&库存
很抱歉,暂时无法提供与“CFM-6025-13-11”相匹配的价格&库存,您可以联系我们找货
