08020SA (80 X 20L)
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
.20
50
4800
4000
.16
3200
L
40
K
.12
30
.08
J
2400
Speed
Static Pressure
M
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
1600
M
L
Expected Life
K
Failure Rate: 10%
60°C
60
Speed Curve
40,000 Hours (AA/EA)
.04
10
J
0.40
0.60
0.80
1.00
1.20
14.12
21.18
28.24
35.3
42.36
(m3/min)
CFM
Material
Air Flow
Outline
11.82
min (300)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
Panel Cut-Outs
inch
Units: (mm)
A
.169
(4 – φ4.3)
B
2.81
(71.5)
2.81
(71.5)
2.99
(76.0)
2.99
(76.0)
INLET SIDE
OUTLET SIDE
2.81
(71.5± 0.3)
3.15
(80.0± 0.5)
2.99
(76.0)
2.99
(76.0)
22 )
3. 1.8
8
(φ
2.81
(71.5)
.169
(4 – φ4.3)
2.81
(71.5)
22 )
3. 1.8
8
(φ
0.169
(4−φ4.3± 0.2)
ROTATION
AIR
NAME
PLATE
B
A
2.81
(71.5± 0.3)
0.15
(4.0± 0.3)
3.15
(80.0 ± 0.5)
0.78
(20.0± 0.3)
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
08020SA-12J-AA-00
12
6.0 ~ 13.8
0.05
0.60
2600
27.5
0.78
08020SA-12K-AA-00
12
6.0 ~ 13.8
0.07
0.84
2900
31.1
0.88
08020SA-12L-AA-00
12
6.0 ~ 13.8
0.09
1.08
3300
36.0
1.02
08020SA-12M-AA-00
12
6.0 ~ 13.2
0.13
1.56
3700
39.9
08020SA-24J-AA-00
24
9.0 ~ 27.6
0.05
1.20
2600
08020SA-24K-AA-00
24
9.0 ~ 27.6
0.06
1.44
08020SA-24L-AA-00
24
9.0 ~ 27.6
0.07
08020SA-24M-AA-00
24
9.0 ~ 27.6
0.09
MODEL
Rotation: Clockwise
Current
Input
Speed
Noise
Mass
(Pa)*1
(dB)*1
(g)
0.11
28.3
27.0
80
0.14
34.9
31.0
80
0.17
43.6
34.0
80
1.13
0.21
52.8
37.5
80
27.5
0.78
0.09
23.5
27.0
80
2900
31.1
0.88
0.11
28.5
31.0
80
1.68
3300
36.0
1.02
0.14
35.0
34.0
80
2.16
3700
39.9
1.13
0.18
44.0
37.5
80
Power
(A)*1 (W)*1
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
(min-1)*1 CFM*1 (m3/min)*1 in H2O
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
.24
P-Q Curve
(Pa)
很抱歉,暂时无法提供与“08020SA-12J-AL-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 96+84.1826296+10.56073
