08020SA-12K-AL-00
08020SA-12K-AL-00
    NMBTECHNOLOGIESCORPORATION
    FAN12VDC80X20MM3WR
08020SA-12K-AL-00 数据手册
08020SA (80 X 20L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger .20 50 4800 4000 .16 3200 L 40 K .12 30 .08 20 J 2400 Speed Static Pressure M -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps 1600 M L Expected Life K Failure Rate: 10% 60°C 60 Speed Curve 40,000 Hours (AA/EA) .04 10 0 0 800 J 0 0.20 0.40 0.60 0.80 1.00 1.20 0 7.06 14.12 21.18 28.24 35.3 42.36 0 (m3/min) CFM Material Air Flow Outline 11.82 min (300) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black Panel Cut-Outs inch Units: (mm) A .169 (4 – φ4.3) B 2.81 (71.5) 2.81 (71.5) 2.99 (76.0) 2.99 (76.0) INLET SIDE OUTLET SIDE 2.81 (71.5± 0.3) 3.15 (80.0± 0.5) 2.99 (76.0) 2.99 (76.0) 22 ) 3. 1.8 8 (φ 2.81 (71.5) .169 (4 – φ4.3) 2.81 (71.5) 22 ) 3. 1.8 8 (φ 0.169 (4−φ4.3± 0.2) ROTATION AIR NAME PLATE B A 2.81 (71.5± 0.3) 0.15 (4.0± 0.3) 3.15 (80.0 ± 0.5) 0.78 (20.0± 0.3) Specifications Rated Operating Voltage Voltage (V) (V) 08020SA-12J-AA-00 12 6.0 ~ 13.8 0.05 0.60 2600 27.5 0.78 08020SA-12K-AA-00 12 6.0 ~ 13.8 0.07 0.84 2900 31.1 0.88 08020SA-12L-AA-00 12 6.0 ~ 13.8 0.09 1.08 3300 36.0 1.02 08020SA-12M-AA-00 12 6.0 ~ 13.2 0.13 1.56 3700 39.9 08020SA-24J-AA-00 24 9.0 ~ 27.6 0.05 1.20 2600 08020SA-24K-AA-00 24 9.0 ~ 27.6 0.06 1.44 08020SA-24L-AA-00 24 9.0 ~ 27.6 0.07 08020SA-24M-AA-00 24 9.0 ~ 27.6 0.09 MODEL Rotation: Clockwise Current Input Speed Noise Mass (Pa)*1 (dB)*1 (g) 0.11 28.3 27.0 80 0.14 34.9 31.0 80 0.17 43.6 34.0 80 1.13 0.21 52.8 37.5 80 27.5 0.78 0.09 23.5 27.0 80 2900 31.1 0.88 0.11 28.5 31.0 80 1.68 3300 36.0 1.02 0.14 35.0 34.0 80 2.16 3700 39.9 1.13 0.18 44.0 37.5 80 Power (A)*1 (W)*1 Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure (min-1)*1 CFM*1 (m3/min)*1 in H2O *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 P-Q Curve (Pa)
08020SA-12K-AL-00 价格&库存
很抱歉,暂时无法提供与“08020SA-12K-AL-00”相匹配的价格&库存,您可以联系我们找货
