BG0703-B053-00S-00
BG0703-B053-00S-00
    NMBTECHNOLOGIESCORPORATION
    FAN BLOWER 75.7X30MM 24VDC WIRE
BG0703-B053-00S-00 数据手册
07530GA (Ø75 X 30L) Legacy Part No. BG0703 NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: P-Q Curve Auto Restart/Polarity Protection In H2O (Pa) Insulation Resistance: 6000 .80 200 5000 Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .64 160 4000 .48 120 .32 80 .16 40 Ps Expected Life Failure Rate: 10% 25°C 0 70,000 Hours M J DC DCAxial Blowers Fans 240 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Speed Curve .96 3000 N 2000 L K 1000 0 0 0.10 3.53 Material 0.20 0.30 7.06 10.59 Air Flow (m3/min) CFM Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black Outline In H2O (Pa) 1.18 .48 120 ) (30 0.5 .96 1.37 .078 .40 (2 100 0.3) (3.5 0.3) (24.5) .32 Ps .16 .24 .177 PASS THROUGH 2 – (φ4.5 0.3) LOT No. 80 AIR 60 AIR .08 20 0 .85 (21.6 0.3) NAME PLATE 40 7.87 (200) min 1.43 (36.2 0.3) 2.98 (75.7) 1.57 1.21 (30.9 0.3) (39.9 0.3) ROTATION 2.98 (75.7) .95 1.49 (24.1) (37.9) Static Pressure inch Units: (mm) 0 0.05 0.10 0.15 0.20 0.25 0.30 1.7 3.5 5.3 7.0 8.8 10.6 CFM Air Flow Specifications MODEL (m3/min) LEGACY P/N Rated Operating Current Voltage Voltage Input Power Speed (V) (V) (A)*1 (W)*1 (min-1)*1 Max. Air Flow Max. Static Pressure CFM*1 (m3/min)*1 in H2O Noise (Pa)*1 (dB)*1 Mass (g) 07530GA-12J-AA-00 BG0703-B041-000-00 12 6 ~ 13.8 0.10 1.20 2000 6.7 0.19 .16 40 28.0 90 07530GA-12K-AA-00 BG0703-B042-000-00 12 6 ~ 13.8 0.12 1.44 2200 7.4 0.21 .20 50 29.5 90 07530GA-12L-AA-00 BG0703-B043-000-00 12 6 ~ 13.8 0.18 2.16 2550 8.8 0.25 .30 75 34.5 90 07530GA-12M-AA-00 BG0703-B044-000-00 12 6 ~ 13.0 0.29 3.48 3000 10.6 0.30 .44 110 38.5 90 07530GA-12N-AA-00 BG0703-B045-000-00 12 6 ~ 13.0 0.51 6.12 3650 13.1 0.37 .66 164 43.0 90 07530GA-24J-AA-00 BG0703-B051-000-00 24 10 ~ 27.6 0.06 1.44 2000 6.7 0.19 .16 40 28.0 90 07530GA-24K-AA-00 BG0703-B052-000-00 24 10 ~ 27.6 0.07 1.68 2200 7.4 0.21 .20 50 29.5 90 07530GA-24L-AA-00 BG0703-B053-000-00 24 10 ~ 27.6 0.09 2.16 2550 8.8 0.25 .30 75 34.5 90 07530GA-24M-AA-00 BG0703-B054-000-00 24 10 ~ 26.0 0.15 3.60 3000 10.6 0.30 .44 110 38.5 90 07530GA-24N-AA-00 BG0703-B055-000-00 24 10 ~ 26.2 0.20 4.80 3650 13.1 0.37 .66 164 43.0 90 Rotation: Counterclockwise *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
BG0703-B053-00S-00 价格&库存
很抱歉,暂时无法提供与“BG0703-B053-00S-00”相匹配的价格&库存,您可以联系我们找货
