G8015M05B-RGR
G8015M05B-RGR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL80X15MM05VDC
G8015M05B-RGR 数据手册
.24 0.60 ±0.01 (15.3 ±0.3) 3.15 ±0.02 (80 ±0.5) 2.82 ±0.02 (71.5 ±0.5) STATIC PRESSURE - IN. OF WATER DC AXIAL FANS G8015-G series 0.16 (4) .18 S L M .12 H E X .06 0 14 28 42 56 AIR FLOW (CFM) 4x Ø 0.18 ±0.01 (Ø 4.5 ±0.3) (80 x 80 x 15 mm) 3.15 x 3.15 x 0.59 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing or sleeve Rated Voltage Speed Current mA Air Volume Max. Static Pressure (H2 0) Sound Noise Weight V 5 12 24 RPM MM INCH dbA g Connection: AWG 26, UL1007 lead wires G8015S-G 5/12/24 200 100 80 2,800 0.73 26 2.24 0.09 28 58 Frame: ribbed G8015L-G 5/12/24 280 130 90 3,200 0.82 29 2.86 0.11 31 58 Protection: thermal Options: tachometer output or locked rotor alarm signal; encapsulated motor; PWM speed control w w w.mechatronic s.com 10.19.21 Model No. M³/Min. CFM G8015M-G 5/12/24 380 180 120 3,600 0.92 32 3.47 0.14 34 58 G8015H-G 12/24 - 230 150 4,000 1.05 37 4.29 0.17 36 58 G8015E-G 12/24 - 320 180 4,400 1.13 40 5.00 0.20 38 58 G8015X-G 12/24 - 350 250 4,800 1.23 43 5.92 0.23 40 58 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
G8015M05B-RGR 价格&库存
很抱歉,暂时无法提供与“G8015M05B-RGR”相匹配的价格&库存,您可以联系我们找货
