74ALVC14
Hex inverting Schmitt trigger
Rev. 5 — 30 April 2021
Product data sheet
1. General description
The 74ALVC14 is a hex inverter with Schmitt-trigger inputs. This device is fully specified for
partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the
potentially damaging backflow current through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 3.6 V
3.6 V tolerant inputs/outputs
CMOS low power consumption
Direct interface with TTL levels (2.7 V to 3.6 V)
Power-down mode
Unlimited input rise and fall times
Latch-up performance exceeds 250 mA
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8-B (2.7 V to 3.6 V)
ESD protection:
• HBM EIA/JESD22-A114-B exceeds 2000 V
• MM EIA/JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C
74ALVC14
Nexperia
3. Ordering information
Table 1. Ordering information
Type number Package
Temperature range Name
Description
Version
-40 °C to +85 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74ALVC14PW -40 °C to +85 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ALVC14BQ -40 °C to +85 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74ALVC14D
SOT762-1
4. Functional diagram
1
3
5
9
11
13
1A
1Y
2A
2Y
3A
3Y
4A
4Y
5A
5Y
6A
6Y
1
2
3
4
5
6
9
8
11
10
13
12
2
4
6
8
10
12
mna204
Fig. 1.
001aac497
Logic symbol
Fig. 2.
IEC logic symbol
A
Y
mna025
Fig. 3.
Logic diagram (one Schmitt trigger)
74ALVC14
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 16
74ALVC14
Nexperia
5. Pinning information
5.1. Pinning
74ALVC14
1A
1
14 VCC
1Y
2
13 6A
2A
3
12 6Y
2Y
4
11 5A
3A
5
10 5Y
3Y
6
9
4A
GND
7
8
4Y
74ALVC14
1A
1
14 VCC
1Y
2
13 6A
2A
3
12 6Y
2Y
4
11 5A
3A
5
10 5Y
3Y
6
9
4A
GND
7
8
4Y
aaa-028708
Fig. 4.
aaa-028709
Pin configuration SOT108-1 (SO14)
Fig. 5.
Pin configuration SOT402-1 (TSSOP14)
1
1A
terminal 1
index area
14 VCC
74ALVC14
1Y
2
2A
3
12 6Y
2Y
4
11 5A
3A
5
3Y
6
GND(1)
13 6A
10 5Y
7
8
GND
4Y
9
4A
aaa-028710
Transparent top view
(1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered,
the solder land should remain floating or connected to GND
Fig. 6.
Pin configuration SOT762-1 (DHVQFN14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A, 5A, 6A
1, 3, 5, 9, 11, 13
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74ALVC14
Product data sheet
3 / 16
74ALVC14
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level;
Input nA
Output nY
L
H
H
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
active mode
Min
Max
Unit
-0.5
+4.6
V
[1]
-0.5
+4.6
V
[1]
-0.5
power-down mode; VCC = 0 V
VCC + 0.5 V
-0.5
+4.6
V
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO > VCC or VO < 0 V
±50
mA
VO = 0 V to VCC
±50
mA
IO(sink/source) output sink or source current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Tamb = -40 °C to +85 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
1.65
3.6
V
VI
input voltage
V
VO
output voltage
VCC
V
V
Tamb
ambient temperature
-40
+85
°C
VCC = 1.65 to 3.6 V
74ALVC14
Product data sheet
in free air
4 / 16
74ALVC14
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
VOL
LOW-level output voltage
VOH
HIGH-level voltage output
Typ[1]
Max
Unit
VI = VIH or VIL
IO = 100 μA; VCC = 1.65 V to 3.6 V
0.2
V
IO = 6 mA; VCC = 1.65 V
0.11
0.3
V
IO = 12 mA; VCC = 2.3 V
0.17
0.4
V
IO = 18 mA; VCC = 2.3 V
0.25
0.6
V
IO = 12 mA; VCC = 2.7 V;
0.16
0.4
V
IO = 18 mA; VCC = 3.0 V
0.23
0.4
V
IO = 24 mA; VCC = 3.0 V
0.30
0.55
V
VCC - 0.2
V
IO = -6 mA; VCC = 1.65 V
1.25
1.51
V
IO = -12 mA; VCC = 2.3 V
1.8
2.10
V
IO = -18 mA; VCC = 2.3 V
1.7
2.01
V
IO = -12 mA; VCC = 2.7 V;
2.2
2.53
V
IO = -18 mA; VCC = 3.0 V
2.4
2.76
V
IO = -24 mA; VCC = 3.0 V
2.2
2.68
V
VI = VIH or VIL
IO = -100 μA; VCC = 1.65 V to 3.6 V
II
input leakage current
VCC = 3.6 V; VI = 3.6 V or GND
±0.1
±5
μA
Ioff
power-off leakage current
VCC = 0 V; VI or VO = 3.6 V
±0.1
±10
μA
ICC
supply current
VCC = 3.6 V; VI = VCC or GND; IO = 0 A
0.2
10
μA
ΔICC
additional supply current
per input pin; VCC = 3.0 V to 3.6 V;
VI = VCC - 0.6 V; IO = 0 A
5
750
μA
CI
input capacitance
3.5
pF
[1]
Typical values are measured at Tamb = 25 °C.
74ALVC14
Product data sheet
5 / 16
74ALVC14
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit, see Fig. 8.
Symbol Parameter
tpd
power dissipation
capacitance
Unit
Min
Typ[1]
Max
VCC = 1.65 V to 1.95 V
1.0
2.9
4.4
ns
VCC = 2.3 V to 2.7 V
1.0
2.2
3.7
ns
VCC = 2.7 V
1.0
2.8
3.9
ns
1.0
2.4
3.4
ns
25
pF
nA to nY; see Fig. 7
propagation delay
CPD
[1]
[2]
[3]
Conditions
[2]
per inverter; VI = GND to VCC;
VCC = 3.3 V
[3]
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively.
tpd is the same as tPHL and tPLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs
10.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VOL
VM
mna344
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Input (nA) to output (nY) propagation delays
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
1.65 V to 1.95 V
VCC
0.5 x VCC
0.5 x VCC
2.3 V to 2.7 V
VCC
0.5 x VCC
0.5 x VCC
2.7 V
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
74ALVC14
Product data sheet
6 / 16
74ALVC14
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
VEXT = Test voltage for switching times.
Fig. 8.
Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
74ALVC14
Product data sheet
VEXT
Load
7 / 16
74ALVC14
Nexperia
11. Transfer characteristics
Table 10. Transfer characteristics
Voltages are referenced to GND (ground = 0 V); see Fig. 9.
Symbol Parameter
VT+
Conditions
positive-going threshold voltage
negative-going threshold voltage
Typ[1]
Max
VCC = 1.65 V
0.7
0.98
1.24
V
VCC = 1.95 V
0.75
1.12
1.46
V
VCC = 2.3 V
0.9
1.27
1.7
V
VCC = 2.7 V
1.0
1.43
2.0
V
1.1
1.56
2.0
V
VCC = 3.6 V
1.1
1.81
2.0
V
VCC = 1.65 V
0.41
0.64
0.9
V
VCC = 1.95 V
0.49
0.76
1.1
V
VCC = 2.3 V
0.6
0.90
1.3
V
VCC = 2.7 V
0.7
1.06
1.4
V
0.8
1.19
1.5
V
VCC = 3.6 V
0.8
1.42
1.7
V
VCC = 1.65 V
0.25
0.34
0.62
V
VCC = 1.95 V
0.25
0.36
0.62
V
VCC = 2.3 V
0.3
0.36
1.0
V
VCC = 2.7 V
0.3
0.38
1.1
V
0.3
0.37
1.2
V
0.3
0.40
1.2
V
VCC = 3.0 V
VH
hysteresis voltage
VCC = 3.0 V
VCC = 3.6 V
[1]
[2]
Unit
Min
VCC = 3.0 V
VT-
[2]
[2]
[2]
All typical values are measured at Tamb = 25 °C.
The typical transfer characteristic is displayed in Fig. 10.
74ALVC14
Product data sheet
8 / 16
74ALVC14
Nexperia
11.1. Transfer characteristics waveforms
VO
VT-
VT+
VH
VT-
VO
VI
VH
mna208
VT- at 20 % and VT+ at 70 %
b. Transfer characteristics definitions
mna207
a. Transfer characteristics
Fig. 9.
VT+
VI
Definition of VT+, VT- and VH
mna582
5
I CC
(mA)
4
3
2
1
1.2
1.8
2.4
VI (V)
3
VCC = 3.0 V
Fig. 10. Typical transfer characteristic
74ALVC14
Product data sheet
9 / 16
74ALVC14
Nexperia
12. Application information
mna581
2.5
I CC
(mA)
2.0
(1)
1.5
(2)
1.0
0.5
2.1
2.4
2.7
3.0
3.3
3.6
VCC (V)
3.9
(1) Positive-going edge.
(2) Negative going-edge.
Linear change of VI between 0.8 V to 2.0 V.
All values given are typical unless otherwise specified.
Fig. 11. Average supply current as a function of supply voltage
R
C
mna035
at VCC = 3.0 V.
Fig. 12. Relaxation oscillator
74ALVC14
Product data sheet
10 / 16
74ALVC14
Nexperia
13. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 13. Package outline SOT108-1 (SO14)
74ALVC14
Product data sheet
11 / 16
74ALVC14
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 14. Package outline SOT402-1 (TSSOP14)
74ALVC14
Product data sheet
12 / 16
74ALVC14
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
SOT762-1
References
IEC
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 15. Package outline SOT762-1 (DHVQFN14)
74ALVC14
Product data sheet
13 / 16
74ALVC14
Nexperia
14. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVC14 v.5
20210430
Product data sheet
74ALVC14 v.4
Modifications:
74ALVC14 v.4
20180814
Modifications:
Section 1 updated.
Section 2: Reference to JESD36 removed.
Section 7: Derating values for Ptot total power dissipation have been updated.
74ALVC14 v.3
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74ALVC14 v.3
20050215
Modifications:
Product data sheet
Product data sheet
74ALVC14 v.2
The format of this data sheet is redesigned to comply with the current presentation and
information standard of Philips Semiconductors.
General text updates.
74ALVC14 v.2
20030514
Product specification
74ALVC14 v.1
74ALVC14 v.1
20030203
74ALVC14
Product data sheet
14 / 16
74ALVC14
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVC14
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74ALVC14
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 6
11. Transfer characteristics............................................. 8
11.1. Transfer characteristics waveforms............................9
12. Application information........................................... 10
13. Package outline........................................................ 11
14. Abbreviations............................................................ 14
15. Revision history........................................................14
16. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 30 April 2021
74ALVC14
Product data sheet
16 / 16
