109P0605M701
109P0605M701
    SANYODENKI
    FAN60X15MM5VDCTACH
109P0605M701 数据手册
DC Fan 60×60×15 mm San Ace 60 9P type ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 547. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Sensor Yellow ・ Mass ……………………………………………… 60 g ■ Specifications The models listed below have ribs and pulse sensors. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 109P0605H701 109P0605M701 109P0612K701 109P0612S701 109P0612H701 109P0612M701 109P0612B701 109P0624J701 109P0624S701 109P0624H701 109P0624M701 [V] 5 4.5 to 5.5 10.2 to 13.8 12 7 to 13.8 10.2 to 13.8 24 14 to 27.6 20.4 to 27.6 0.26 0.15 0.26 0.15 0.09 0.07 0.05 0.14 0.08 0.06 0.04 Rated speed Max. airflow [W] [min-1] [m³/min] 1.3 0.75 3.12 1.8 1.08 0.84 0.6 3.36 1.92 1.44 0.96 4100 3100 6500 5000 4100 3100 2200 6200 5000 4100 3100 0.4 0.3 0.62 0.48 0.4 0.3 0.21 0.61 0.48 0.4 0.3 [A] [CFM] 14.1 10.6 21.9 17.0 14.1 10.6 7.42 21.5 16.9 14.1 10.6 Max. static pressure [Pa] [inchH²O] 38.2 22.6 99.3 58.8 38.2 22.6 11.7 86.5 58.8 38.2 22.6 SPL Operating temperature Expected life [dB (A)] 0.153 0.091 0.399 0.236 0.153 0.091 0.047 0.347 0.236 0.153 0.091 32 25 45 36 32 25 21 44 36 32 25 [˚C] [h] -20 to +70 60000/60˚C -20 to +60 40000/60˚C -20 to +70 60000/60˚C -20 to +60 40000/60˚C -20 to +70 60000/60˚C The following sensor and control options are available for selection. Available for all models. Without sensor Lock sensor ■ Airflow - Static Pressure Characteristics 109P0605H701 109P0605M701 With pulse sensor Operating voltage range Operating voltage range 0.12 0.10 0.05 0 50 5.5 V 40 5V 30 4.5 V 20 0 30 0.10 0.08 5.5 V 20 5V 0.06 0.04 4.5 V 10 0.02 10 0.1 0.2 0.3 0.4 0 2 4 6 8 10 12 14 16 Airflow 風量 62 Static静圧 pressure Static静圧 pressure 0.15 (inch H2O) (Pa) (inch H2O) (Pa) 60 0.5 (m3/min) (CFM) 0 With pulse sensor Operating voltage range Static静圧 pressure (inch H2O) (Pa) 0.20 109P0612K701 With pulse sensor 0 0.1 0 2 4 0.2 6 0.3 0.4 (m3/min) 8 10 12 14 Airflow 風量 (CFM) 0.55 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 130 120 110 100 90 80 70 60 50 40 30 20 10 0 13.8 V 12 V 10.2 V 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0 5 10 15 20 風量 Airflow 25 (m3/min) 30 (CFM) Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 80 60 0.25 70 0.20 50 0.15 40 0.10 13.8 V 60 Static静圧 pressure Static静圧 pressure 0.30 12 V 10.2 V 30 20 0.05 10 0 0 0 2 4 6 8 10 12 14 16 18 20 Airflow 風量 0.20 0.15 0.10 0.05 0 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 109P0612B701 109P0612M701 With pulse sensor 0.16 Operating voltage range 13.8 V 40 12 V 30 7V 20 10 0 0.1 0.2 0.3 0.4 15 13.8 V 0.04 10 0.02 5 0 12 V 10.2 V 0 0 109P0624H701 2 4 6 Airflow 風量 8 10 0 4 0.2 6 0.3 0.4 (m3/min) 8 10 12 14 Airflow 風量 (CFM) With pulse sensor 24 V 80 14 V 60 20 0.25 60 0.20 50 0.15 40 0.10 0.05 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 5 10 15 20 Airflow 風量 25 (CFM) 80 70 0 27.6 V 24 V 14 V 30 20 10 0 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 2 4 6 8 10 12 14 16 18 20 22 (CFM) 風量 Airflow With pulse sensor (inch H2O) (Pa) 0.16 40 0.14 50 27.6 V 40 24 V 30 14 V 20 10 0 0.1 2 Operating voltage range Static静圧 pressure Static静圧 pressure 0.05 100 0 60 0.10 0.30 27.6 V 0 0 0.35 40 0.10 10 (inch H2O) (Pa) 109P0624M701 With pulse sensor (inch H2O) (Pa) 0.15 0.20 0.04 Operating voltage range 120 (CFM) Operating voltage range 0.20 0.30 0 0.3 (m3/min) 0.2 0.1 0.40 10.2 V 0.06 0 Static静圧 pressure Static静圧 pressure Static静圧 pressure 0.06 12 V 20 109P0624S701 With pulse sensor Operating voltage range 0.50 0.08 (CFM) Airflow 風量 20 13.8 V 30 0.10 0 0.5 (m3/min) (inch H2O) (Pa) 0.08 0.12 0.02 0 2 4 6 8 10 12 14 16 (inch H2O) (Pa) 40 0.14 109P0624J701 With pulse sensor Operating voltage range (inch H2O) (Pa) 50 (CFM) With pulse sensor DC Fan 60 mm sq. 109P0612H701 With pulse sensor Static静圧 pressure 109P0612S701 DC ■ Airflow - Static Pressure Characteristics 0.12 27.6 V 30 0.10 0.08 24 V 20 20.4 V 0.06 0.04 10 0.02 0.1 0.2 0.3 0.4 0.5 (m3/min) 0 2 4 6 8 10 12 14 16 Airflow 風量 (CFM) 0 0 0.1 0 2 4 0.2 6 0.3 0.4 (m3/min) 8 10 12 14 Airflow 風量 (CFM) 63 ■ Dimensions (unit: mm) +1 60 0 (4) 50±0.3 (4) Lead wire リード線 AWG24 UL 1007 +50 300 0 50±0.3 +1 60 0 4-ø4.3±0.3 Mounting 取付用穴 hole +1 15 0 (10) Rotating direction 回転方向 Airflow direction 風吹出方向 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 4-ø4.5 58 50±0.3 58 50±0.3 3 ø6 ■ Options Finger guards page: p. 532 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 540 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 64 Resin finger guards page: p. 539
109P0605M701
1. 物料型号:型号为ATMEGA328P-AU,是一款8位AVR微控制器,具有32KB的闪存和2KB的SRAM。
2. 器件简介:ATMEGA328P-AU是AVR增强系列的成员,适用于广泛的嵌入式系统应用,如工业控制、医疗设备、消费电子产品等。
3. 引脚分配:该芯片共有44个引脚,包括电源引脚、地引脚、复位引脚、I/O引脚等。
4. 参数特性:工作电压为1.8-5.5V,工作频率为16MHz,具有32KB的闪存和2KB的SRAM。
5. 功能详解:该芯片具有多种功能,包括中断、定时器、串行通信、模数转换等。
6. 应用信息:适用于需要高性能、低功耗的嵌入式系统应用。
109P0605M701 价格&库存
很抱歉,暂时无法提供与“109P0605M701”相匹配的价格&库存,您可以联系我们找货
