109R0612D4D011
109R0612D4D011
    SANYODENKI
    FAN60X25MM12VDCRBLSLOCK
109R0612D4D011 数据手册
DC DC Fan 60 mm sq. DC Fan 60×60×25 mm San Ace 60 9R type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Sensor Yellow · Mass………………………………………… 90 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. 109R0605H401 109R0605F401 109R0605M401 Rated voltage Operating voltage range Rated current Rated input Rated speed SPL Operating temperature Expected life [V] [V] [A] [W] [min-1] [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [˚C] [h] 4.5 to 5.5 0.34 0.2 0.13 1.7 1.0 0.65 3800 3200 2600 0.53 0.44 0.36 18.7 15.5 12.7 40.2 29.4 19.6 0.161 0.118 0.079 28 24 20 -20 to +70 -20 to +60 -20 to +70 60000/60˚C (90000/40˚C) 0.47 5.64 7600 1.06 37.1 155.0 0.622 44 -20 to +60 40000/60˚C (70000/40˚C) 2.88 2.52 2.04 1.32 1.08 0.72 5.76 3.12 2.88 1.92 1.44 1.2 0.96 5.76 3.36 5600 5150 4600 3800 3200 2600 7600 5600 5150 4600 3800 3200 2600 7600 5600 0.78 0.72 0.65 0.53 0.44 0.36 1.06 0.78 0.72 0.65 0.53 0.44 0.36 1.06 0.78 27.5 25.4 23.0 18.7 15.5 12.7 37.1 27.5 25.4 23.0 18.7 15.5 12.7 37.1 27.5 87.3 73.5 56.8 40.1 29.4 19.6 155.0 87.3 73.5 56.8 40.2 29.4 19.6 155.0 87.3 0.351 0.295 0.228 0.161 0.118 0.079 0.622 0.351 0.295 0.228 0.161 0.118 0.079 0.622 0.351 39 37 33 28 24 20 44 39 37 33 28 24 20 44 39 -20 to +70 60000/60˚C (90000/40˚C) 14 to 27.6 43.2 to 52.8 43 to 53 0.24 0.21 0.17 0.11 0.09 0.06 0.24 0.13 0.12 0.08 0.06 0.05 0.04 0.12 0.07 40 to 53 0.04 1.92 3800 0.53 18.7 40.2 0.161 28 5 109R0612J401 109R0612G401 109R0612D401 109R0612S401 109R0612H401 109R0612F401 109R0612M401 109R0624J401 109R0624G401 109R0624D401 109R0624S401 109R0624H401 109R0624F401 109R0624M401 109R0648J401 109R0648G401 10.8 to 13.2 12 10.2 to 13.8 6 to 13.8 7 to 13.8 21.6 to 26.4 20.4 to 27.6 24 48 109R0648H401 12 to 27.6 Note 1: Sensor and control options are available for selection. Refer to the table on pp. 622 to 623. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 74 CATALOG No. C1111B002 '21.9.IT Max. airflow Max. static pressure -20 to +60 -20 to +70 -20 to +60 -20 to +70 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 109R0605F401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.16 5V 30 4.5 V 20 0.10 0.08 5V 20 4.5 V 0.06 0.04 10 0.02 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 5 10 15 20 0 25 (CFM) 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 5 Airflow 109R0612J401 109R0612G401 With pulse sensor 0.5 0.4 0.3 0.2 0.1 0 0.45 0.40 13.2 V 12 V 10.8 V 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min) 0 5 10 15 20 25 30 35 40 45 60 0.15 40 0.10 0.05 0 0.20 13.8 V Static pressure Static pressure 50 12 V 6V 30 20 0.15 0.10 0.2 0 5 0.4 10 0.6 15 12 V 10.8 V 20 0.8 25 0 (m3/min) 5 10 15 20 25 30 20 0.06 15 0.04 10 0.02 5 0 0 13.8 V 0.7 12 V 7V 0.6 0.5 0.4 0.3 0.2 0.1 0 5 0.3 10 Airflow 0.4 15 0.5 (m3/min) 20 (CFM) 0 0.3 0.4 10 0.5 (m3/min) 15 (CFM) With pulse sensor 100 0.3 80 12 V 60 10.2 V 0.2 40 0.1 20 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0 5 10 15 20 25 (m3/min) 30 (CFM) 109R0612F401 With pulse sensor 0.18 0.16 12 V 40 30 6V 10 40 13.8 V 0.14 0.12 12 V 30 0.10 0.08 6V 20 0.06 0.04 10 0.02 0 200 180 160 140 120 100 80 60 40 20 0 0.2 5 Operating voltage range 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 5 10 15 20 0 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 25 (CFM) 5 10 15 20 (CFM) Airflow 109R0624G401 With pulse sensor Operating voltage range 0.8 0.2 0.1 Airflow With pulse sensor Operating voltage range (inch H2O) (Pa) 0.1 0 0 13.8 V 109R0624J401 With pulse sensor Static pressure Static pressure 0.08 0 (inch H2O) (Pa) 0 30 25 5 4.5 V Airflow (inch H2O) (Pa) 0.10 0.02 (CFM) With pulse sensor 50 30 (CFM) Operating voltage range 0.12 10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) Airflow 109R0612M401 0.04 5V Operating voltage range 13.2 V 20 0.05 10 0 15 13.8 V 109R0612H401 (inch H2O) (Pa) 0.20 0.06 5.5 V 109R0612D401 Operating voltage range 80 60 20 0.4 0 (inch H2O) (Pa) 0.25 0.08 Airflow With pulse sensor 70 25 (inch H2O) (Pa) 110 100 90 80 70 60 50 40 30 20 10 0 (CFM) Operating voltage range 0.30 0.10 Airflow With pulse sensor Airflow 109R0612S401 30 (CFM) (inch H2O) (Pa) 200 180 160 140 120 100 80 60 40 20 0 Static pressure Static pressure 0.6 20 Operating voltage range (inch H2O) (Pa) 0.7 15 0.12 Airflow Operating voltage range 0.8 10 Static pressure 0 10 5.5 V Static pressure 0.05 30 Static pressure 40 0.12 (inch H2O) (Pa) 26.4 V 24 V Static pressure 0.10 5.5 V Static pressure Static pressure 0.15 (inch H2O) (Pa) 40 0.14 50 With pulse sensor Operating voltage range (inch H2O) (Pa) 60 0.20 109R0605M401 With pulse sensor DC Fan 60 mm sq. 109R0605H401 DC ■ Airflow - Static Pressure Characteristics 21.6 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min) 0 5 10 15 20 25 30 35 40 45 Airflow (CFM) 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 120 110 100 90 80 70 60 50 40 30 20 10 0 27.6 V 24 V 20.4 V 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 5 10 15 20 25 30 (CFM) Airflow CATALOG No. C1111B002 '21.9.IT 75 109R0624S401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) (inch H2O) (Pa) 80 60 100 0.30 80 0.3 24 V Static pressure Static pressure 27.6 V 60 0.2 12 V 40 0.1 20 0 0.25 50 0.15 40 0.10 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0 5 10 15 20 25 0 (m3/min) 24 V 12 V 30 20 0 30 (CFM) 0.2 0 5 0.12 Static pressure Static pressure 27.6 V 0.14 24 V 30 0.10 12 V 20 0.06 10 0.04 0.02 0 0 25 5 10 15 109R0648G401 20 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 5 109R0648J401 (inch H2O) (Pa) 60 Static pressure 0.20 53 V 48 V 43 V 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.15 0.10 27.6 V 0.7 24 V 0.6 14 V 0 (m3/min) 0.1 0.2 5 0.3 10 0.4 15 0.5 (m3/min) 20 (CFM) 53 V 48 V 40 30 40 V 10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 Airflow 5 10 15 20 25 (CFM) Airflow (With ribs) +1 60 0 50±0.3 4-ø4.3±0.3 Mounting hole 25±0.5 (3) (3) Lead wire AWG24 UL 1007 50±0.3 +50 300 0 (10) Rotating direction CATALOG No. C1111B002 '21.9.IT 15 20 25 (CFM) With pulse sensor 0.4 0.3 0.2 0 200 180 160 140 120 100 80 60 40 20 0 52.8 V 48 V 43.2 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min) 0 5 10 15 20 25 30 35 40 45 Airflow With pulse sensor 50 10 15 20 25 30 35 (CFM) 0.5 0.1 20 0.05 10 Operating voltage range Operating voltage range 120 110 100 90 80 70 60 50 40 30 20 10 0 76 10 0 0.8 109R0648H401 With pulse sensor ■ Dimensions (unit: mm) 0.05 Airflow Airflow (inch H2O) (Pa) 5 12 V (inch H2O) (Pa) 0 (CFM) Operating voltage range 0 30 30 (CFM) With pulse sensor Airflow Static pressure 20 24 V 40 20 0 (m3/min) 30 0.10 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 15 0.8 (inch H2O) (Pa) 0.18 0.08 0.6 Operating voltage range (inch H2O) (Pa) 0.12 0.4 10 109R0624M401 With pulse sensor 40 0.10 27.6 V 50 Airflow Operating voltage range 0.16 0.15 10 Airflow 109R0624F401 0.20 27.6 V 60 0.20 0.05 0 70 With pulse sensor Operating voltage range Static pressure 0.4 109R0624H401 With pulse sensor Static pressure 109R0624D401 +1 60 0 DC DC Fan 60 mm sq. ■ Airflow - Static Pressure Characteristics Airflow direction (CFM) DC ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) DC Fan 60 mm sq. Inlet side, Outlet side 59 50±0.3 29.7 59 29.7 50±0.3 62 .7 4-ø4.5 ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 77
109R0612D4D011
物料型号:文档中列出了多个型号,例如109R0605H401、109R0605F401、109R0612J401等。
器件简介:这是一个60毫米正方形的直流风扇,具有塑料框架和塑料叶轮,具有UL 94V-0和UL 94V-1的阻燃等级。
引脚分配:文档中提到了红色、黑色或蓝色传感器线和黄色线。
参数特性:包括额定电压、转速、输入功率、最大气流、最大静态压力、声压级、工作温度范围、预期寿命等。
功能详解:风扇具备电机保护功能,如锁定转子烧毁保护和反极性保护。
应用信息:适用于需要直流风扇的各种应用场合。
封装信息:提供了风扇的尺寸和安装孔的参考尺寸。
109R0612D4D011 价格&库存
很抱歉,暂时无法提供与“109R0612D4D011”相匹配的价格&库存,您可以联系我们找货
