906-31-1-18-2-B-0
906-31-1-18-2-B-0
    WAKEFIELD-VETTE
    HEAT SINK ELLIP FIN 31X31MM CLIP
906-31-1-18-2-B-0 数据手册
ELLIPTICAL FIN HEAT SINK 900 Series Wakefield-Vette’s 900 Series Heat Sinks for Chipset can match up to devices from Intel, Broadcom, Xilinx, TI, Motorola, ATI, AMD, Nvidia, Vishay, Powerex, Infineon, Microsemi, and many more. These heat sinks are designed for air flow applications in the Telecom, Data Center, Networking, Cloud Computing, and many more Industries. Material: AL 6063 Finish: Black Anodize FORCED CONVECTION SERIES 901 902 903 904 905 FORCED CONVECTION Height CHIP SIZE NATURAL CONVECTION 200 LFM 400 LFM 600 LFM 200 LFM 400 LFM 600 LFM 12 19mm 14.77 C/W 6.63 C/W 5.09 C/W 4.38 C/W 12 31mm 12.02 C/W 3.37 C/W 2.25 C/W 1.87 C/W 15 19mm 14 C/W 6.12 C/W 4.63 C/W 3.95 C/W 15 31mm 11.43 C/W 3.13 C/W 2.02 C/W 1.66 C/W 18 19mm 13.23 C/W 5.67 C/W 4.17 C/W 3.58 /CW 18 31mm 10.85 C/W 2.85 C/W 1.79 C/W 1.45 C/W 21 19mm 12.46 C/W 5.28 C/W 3.87 C/W 3.24 C/W 21 31mm 10.27 C/W 2.63 C/W 1.63 C/W 1.31 C/W 23 19mm 11.98 C/W 4.89 C/W 3.58 C/W 3.06 C/W 23 31mm 9.88 C/W 2.44 C/W 1.5 C/W 1.19 C/W 28 19mm 11.5 C/W 4.38 C/W 3.26 C/W 2.80 C/W 28 31mm 8.93 C/W 2.21 C/W 1.36 C/W 1.05 C/W 33 19mm 9.57 C/W 4.04 C/W 2.98 C/W 2.62 C/W 33 31mm 7.98 C/W 2.02 C/W 1.19 C/W .93 C/W 12 21mm 14.31 C/W 5.81 C/W 3.86 C/W 3.16 C/W 12 33mm 11.56 C/W 3.23 C/W 2.09 C/W 1.73 C/W 15 21mm 13.57 C/W 5.3 C/W 3.5 C/W 2.89 C/W 15 33mm 11 C/W 2.97 C/W 1.88 C/W 1.54 C/W 18 21mm 12.83 C/W 4.95 C/W 3.35 C/W 2.66 C/W 18 33mm 10.45 C/W 2.69 C/W 1.7 C/W 1.37 C/W 21 21mm 12.09 C/W 4.61 C/W 3.111 C/W 2.47 C/W 21 33mm 9.9 C/W 2.5 C/W 1.52 C/W 1.22 C/W 23 21mm 11.63 C/W 4.32 C/W 2.91 C/W 2.32 C/W 23 33mm 9.54 C/W 2.3 C/W 1.37 C/W 1.08 C/W 28 21mm 10.47 C/W 3.89 C/W 2.61 C/W 2.09 C/W 28 33mm 8.62 C/W 2.08 C/W 1.23 C/W .98 C/W 33 21mm 9.3 C/W 3.57 C/W 2.37 C/W 1.95 C/W 33 33mm 7.71 C/W 1.89 C/W 1.08 C/W .86 C/W 12 23mm 13.85 C/W 4.75 C/W 3.31 C/W 2.79 C/W 12 35mm 11.1 C/W 3.07 C/W 2.07 C/W 1.64 C/W 15 23mm 13.14 C/W 4.38 C/W 3.05 C/W 2.53 C/W 15 35mm 10.58 C/W 2.79 C/W 1.87 C/W 1.46 C/W 18 23mm 12.44 C/W 4.07 C/W 2.81 C/W 2.32 C/W 18 35mm 10.06 C/W 2.54 C/W 1.69 C/W 1.27 C/W 21 23mm 11.73 C/W 3.84 C/W 2.57 C/W 2.11 C/W 21 35mm 9.53 C/W 2.35 C/W 1.52 C/W 1.15 C/W 23 23mm 11.28 C/W 3.59 C/W 2.4 C/W 1.97 C/W 23 35mm 8.75 C/W 2.13 C/W 1.35 C/W 1.01 C/W 28 23mm 10.16 C/W 3.22 C/W 2.17 C/W 1.8 C/W 28 35mm 7.93 C/W 1.94 C/W 1.19 C/W .86 C/W 33 23mm 9.04 C/W 2.93 C/W 1.95 C/W 1.64 C/W 33 35mm 7.11 C/W 1.69 C/W 1.02 C/W .72 C/W 12 27mm 12.93 C/W 4.34 C/W 3 C/W 2.53 C/W 12 37.5mm 10.52 C/W 3.11 C/W 2.01 C/W 1.61 C/W 15 27mm 12.29 C/W 4.05 C/W 2.76 C/W 2.29 C/W 15 37.5mm 10.04 C/W 2.82 C/W 1.79 C/W 1.41 C/W 18 27mm 11.64 C/W 3.73 C/W 2.5 C/W 2.07 C/W 18 37.5mm 9.56 C/W 2.59 C/W 1.59 C/W 1.22 C/W 21 27mm 11 C/W 3.43 C/W 2.31 C/W 1.9 C/W 21 37.5mm 9.08 C/W 2.38 C/W 1.41 C/W 1.06 C/W 23 27mm 10.58 C/W 3.21 C/W 2.11 C/W 1.71 C/W 23 37.5mm 8.75 C/W 2.15 /CW 1.24 C/W .94 C/W 28 27mm 9.54 C/W 2.89 C/W 1.84 C/W 1.51 C/W 28 37.5mm 7.93 C/W 1.88 C/W 1.08 C/W .8 C/W 33 27mm 8.51 C/W 2.62 C/W 1.66 C/W 1.35 C/W 33 37.5mm 7.11 C/W 1.64 C/W .93 C/W .68 C/W 12 29mm 12.47 C/W 4.09 C/W 2.74 C/W 2.25 C/W 12 40mm 9.95 C/W 3.09 C/W 1.93 C/W 1.56 C/W 15 29mm 11.86 C/W 3.81 C/W 2.52 C/W 2.02 C/W 15 40mm 9.51 C/W 2.77 C/W 1.73 C/W 1.37 C/W 18 29mm 11.25 C/W 3.56 C/W 2.31 C/W 1.84 C/W 18 40mm 9.06 C/W 2.74 C/W 1.52 C/W 1.17 C/W 21 29mm 10.63 C/W 3.3 C/W 2.12 C/W 1.65 C/W 21 40mm 8.62 C/W 2.22 C/W 1.35 C/W .99 C/W 23 29mm 10.23 C/W 3.06 C/W 1.91 C/W 1.49 C/W 23 40mm 8.3 C/W 2.01C/W 1.19 C/W .87 C/W 28 29mm 9.24 C/W 2.72 C/W 1.69 C/W 1.33 C/W 28 40mm 7.55 C/W 1.8 C/W 1.04 C/W .75 C/W 33 29mm 8.24 C/W 2.47 C/W 1.49 C/W 1.18 C/W 33 40mm 6.78 C/W 1.61 C/W .88 C/W .64 C/W SERIES 906 907 908 909 910 HEIGHT CHIP SIZE Series Chip Size Construction Height Chip Height 901191121- NATURAL CONVECTION Finish B- Interface 1 XXX XX X XX X X X 901 902 903 904 905 906 907 908 909 910 19 21 23 27 29 31 33 35 37.5 40 1= Eliptical Fin 2= Pin Fin 12 = 11.6 15 = 14.6 18 = 17.6 21 = 20.6 23 = 22.6 28 = 27.6 33 = 32.6 1 = .9-2.1 2 = 2.2-3.4 B = BLK ANO 0 = None 1 = T725 T h e r m a l C o o l i n g S o l u t i o n s f r o m S m a r t www.wakefield-vette.com t o F i n i s h ELLIPTICAL FIN HEAT SINK 900 Series Wakefield-Vette’s heat sink assembles onto chip set using the space that is between the PCB and the substrate of the solder balls. The solder balls provide a minimal gap of .5mm to .7mm. Attachment feature is below a .4mm thickness. The clipping system will not interfere or damage chip. Contact area is the edge of chip. ASSEMBLY INSTRUCTION: Step 1: Hook the clip under one side of the BGA chip set. Step 2: Rotate assembly down until opposite side clip engages substrate edge of BGA chip set. Random Vibration Test Frequency :5 Hz to 500 Hz Acceleration :3.13 grms P.S.D :0.01 g2/HZ (5 Hz) 0.02 g2/HZ (20 Hz to 500 Hz) Test Axis :X, Y, Z axis Test Time :10 mins (Each axis) Total Test Time :30 mins T h e r m a l C o o l i n g S o l u t i o n s Step 3: Make sure the sop rods are clearing from edges of BGA chip set. Step 4: Press firmly down to make sure clips fully engage edges of chip set. Heat Sink should not move around easily. SHOCK TEST SPECIFICATION: Wave Form :Half sine wave Acceleration :50 g Duration Time :11 ms No. of Shock :Each axis 3 times Shock Direction :±X, ±Y, ±Z axis Reliability & Communication Testing Instruments f r o m S m a r t www.wakefield-vette.com t o F i n i s h
906-31-1-18-2-B-0 价格&库存
很抱歉,暂时无法提供与“906-31-1-18-2-B-0”相匹配的价格&库存,您可以联系我们找货
906-31-1-18-2-B-0
  • 1+73.015511+9.48070
  • 10+69.3603810+9.00610
  • 20+64.4868820+8.37330
  • 50+56.7414950+7.36760
  • 90+52.7382690+6.84780
906-31-1-18-2-B-0
  • 1000+63.005341000+8.18093
906-31-1-18-2-B-0
  • 1+86.84050
  • 10+82.49249
  • 20+76.69513
  • 50+67.48405
  • 90+62.71681
