07530GA (Ø75 X 30L)
Legacy Part No. BG0703
NMBTC.COM / 818.341.3355
Characteristic Curves
General Specifications
Motor Protection:
P-Q Curve
Auto Restart/Polarity Protection
In H2O (Pa)
Insulation Resistance:
6000
.80
200
5000
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
.64
160
4000
.48
120
.32
80
.16
40
Ps
Expected Life
Failure Rate: 10%
25°C
70,000 Hours
M
J
DC
DCAxial
Blowers
Fans
240
10M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Speed Curve
.96
3000
N
2000
L
K
1000
3.53
Material
0.20
0.30
7.06
10.59
Air Flow
(m3/min)
CFM
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
Outline
In H2O (Pa)
1.18
.48
120
(30 0.5
.96
1.37
.078
.40 (2 100
0.3)
(3.5 0.3) (24.5)
.32
Ps
.16
.24
.177 PASS THROUGH
2 – (φ4.5 0.3)
LOT No.
80
AIR
60
AIR
.08
(21.6 0.3)
NAME
PLATE
40
7.87
(200) min
1.43
(36.2 0.3)
2.98
(75.7)
1.57
1.21
(30.9 0.3) (39.9 0.3)
ROTATION
2.98
(75.7)
.95
1.49
(24.1)
(37.9)
Static Pressure
inch
Units: (mm)
0 0.05 0.10 0.15 0.20 0.25 0.30
1.7 3.5 5.3 7.0 8.8 10.6
CFM
Air Flow
Specifications
MODEL
(m3/min)
LEGACY P/N
Rated Operating Current
Voltage Voltage
Input
Power
Speed
(V) (V) (A)*1 (W)*1 (min-1)*1
Max.
Air Flow
Max. Static
Pressure
CFM*1 (m3/min)*1 in H2O
Noise
(Pa)*1 (dB)*1
Mass
(g)
07530GA-12J-AA-00
BG0703-B041-000-00
12
6 ~ 13.8
0.10
1.20
2000
6.7
0.19
.16
40
28.0
90
07530GA-12K-AA-00
BG0703-B042-000-00
12
6 ~ 13.8
0.12
1.44
2200
7.4
0.21
.20
50
29.5
90
07530GA-12L-AA-00
BG0703-B043-000-00
12
6 ~ 13.8
0.18
2.16
2550
8.8
0.25
.30
75
34.5
90
07530GA-12M-AA-00
BG0703-B044-000-00
12
6 ~ 13.0
0.29
3.48
3000
10.6
0.30
.44
110
38.5
90
07530GA-12N-AA-00
BG0703-B045-000-00
12
6 ~ 13.0
0.51
6.12
3650
13.1
0.37
.66
164
43.0
90
07530GA-24J-AA-00
BG0703-B051-000-00
24
10 ~ 27.6 0.06 1.44 2000 6.7 0.19 .16 40 28.0 90
07530GA-24K-AA-00
BG0703-B052-000-00
24
10 ~ 27.6 0.07 1.68 2200 7.4 0.21 .20 50 29.5 90
07530GA-24L-AA-00
BG0703-B053-000-00
24
10 ~ 27.6 0.09 2.16 2550 8.8 0.25 .30 75 34.5 90
07530GA-24M-AA-00
BG0703-B054-000-00
24
10 ~ 26.0 0.15 3.60 3000 10.6 0.30 .44 110 38.5 90
07530GA-24N-AA-00
BG0703-B055-000-00
24
10 ~ 26.2 0.20 4.80 3650 13.1 0.37 .66 164 43.0 90
Rotation: Counterclockwise
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“BG0703-B042-00S-00”相匹配的价格&库存,您可以联系我们找货
