74ABT04
Hex inverter
Rev. 4 — 6 October 2020
Product data sheet
1. General description
The 74ABT04 is a hex inverter. This device is fully specified for partial power down applications
using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow
current through the device when it is powered down.
2. Features and benefits
Supply voltage range from 4.5 V to 5.5 V
BiCMOS high speed and output drive
Direct interface with TTL levels
IOFF circuitry provides partial Power-down mode operation
Latch-up protection exceeds 500 mA per JESD78B class II level A
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74ABT04D
-40 °C to +85 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74ABT04PW
-40 °C to +85 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ABT04
Nexperia
Hex inverter
4. Functional diagram
1
1
1A
1Y
2
3
2A
2Y
4
3
5
5
3A
3Y
6
9
4A
4Y
8
11
5A
5Y
10
13
6A
6Y
12
9
11
13
mna342
Fig. 1.
1
2
1
4
1
6
1
8
1
10
1
12
Y
A
mna343
Logic symbol
Fig. 2.
mna341
IEC logic symbol
Fig. 3.
Logic diagram (one inverter)
5. Pinning information
5.1. Pinning
74ABT04
1A
1
14 VCC
1Y
2
13 6A
2A
3
12 6Y
2Y
4
3A
5
3Y
GND
6
1A
1
1Y
2
14 VCC
13 6A
11 5A
2A
3
12 6Y
10 5Y
2Y
4
11 5A
3A
5
10 5Y
3Y
6
9
4A
GND
7
8
4Y
9
7
74ABT04
8
4A
4Y
aaa-024193
aaa-024192
Fig. 4.
Pin configuration SOT108-1 (SO14)
Fig. 5.
Pin configuration SOT402-1 (TSSOP14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A, 5A, 6A
1, 3, 5, 9, 11, 13
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74ABT04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 10
74ABT04
Nexperia
Hex inverter
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
nA
nY
L
H
H
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7.0
V
[1]
-1.2
+7.0
V
[1]
-0.5
+5.5
V
VCC
supply voltage
VI
input voltage
VO
output voltage
output HIGH or LOW
IIK
input clamping current
VI < 0 V
-18
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
output in LOW-state
40
mA
Tj
junction temperature
150
°C
Tstg
storage temperature
-65
+150
°C
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
8. Recommended operating conditions
Table 5. Operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
4.5
5.5
V
VCC
V
2.0
V
V
VCC
supply voltage
VI
input voltage
VIH
HIGH-level input voltage
VIL
LOW-level input voltage
0.8
IOH
HIGH-level output current
-15
mA
IOL
LOW-level output current
mA
Δt/ΔV
input transition rise and fall rate
ns/V
Tamb
ambient temperature
-40
+85
74ABT04
Product data sheet
in free air
°C
3 / 10
74ABT04
Nexperia
Hex inverter
9. Static characteristics
Table 6. Static characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Unit
VIK
input clamping voltage
VCC = 4.5 V; IIK = -18 mA
-1.2
-0.9
-1.2
V
VOH
HIGH-level output
voltage
VCC = 4.5 V; IOH = -15 mA;
VI = VIL or VIH
2.5
2.9
2.5
V
VOL
LOW-level output
voltage
VCC = 4.5 V; IOL = 20 mA;
VI = VIL or VIH
0.35
0.5
0.5
V
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
±0.01
±1.0
±1.0
μA
IOFF
power-off leakage
current
VCC = 0 V; VI or VO ≤ 4.5 V
±5.0
±100
±100
μA
ICEX
output high leakage
current
HIGH-state; VO = 5.5 V;
VCC = 5.5 V; VI = GND or VCC
5.0
50
50
μA
IO
output current
VCC = 5.5 V; VO = 2.5 V
-50
-75
-180
-50
-180
mA
ICC
supply current
2
50
50
μA
ΔICC
additional supply
current
per input pin; VCC = 5.5 V;
one input at 3.4 V;
other inputs at VCC or GND
0.25
500
500
μA
CI
input capacitance
VI = 0 V or VCC
3
pF
[1]
[2]
[1]
[2]
Not more than one output should be tested at a time, and the duration of the test should not exceed one second.
This is the increase in supply current for each input at 3.4 V.
10. Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; for test circuit, see Fig. 7.
Symbol Parameter
Conditions
25 °C; VCC = 5.0 V
-40 °C to +85 °C;
VCC = 5.0 V ± 0.5 V
Min
Typ
Max
Min
Max
Unit
tPLH
LOW to HIGH
propagation delay
nA to nY; see Fig. 6
1.0
2.2
3.4
1.0
4.1
ns
tPHL
HIGH to LOW
propagation delay
1.0
1.6
2.5
1.0
3.0
ns
tsk(o)
output skew time
0.4
0.5
0.5
ns
[1]
[1]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
74ABT04
Product data sheet
4 / 10
74ABT04
Nexperia
Hex inverter
10.1. Waveforms and test circuit
Vl
nA input
VM
GND
tPLH
tPHL
VOH
nY output
VM
VOL
aaa-024194
VM = 1.5 V
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 6.
Propagation delay input (nA) to output (nY) and output skew time
VI
negative
pulse
tW
90 %
90 %
VM
10 %
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VEXT
VCC
G
90 %
VM
VI
VM
10 %
DUT
RT
10 %
tW
RL
VO
CL
mna616
001aai298
a. Input pulse definition
RL
b. Test circuit
Test data is given in Table 8.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 8. Test data
Input
VEXT
Load
VI
fi
tW
tr, tf
CL
RL
tPHL, tPLH
3.0 V
1 MHz
500 ns
≤ 2.5 ns
50 pF
500 Ω
open
74ABT04
Product data sheet
5 / 10
74ABT04
Nexperia
Hex inverter
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74ABT04
Product data sheet
6 / 10
74ABT04
Nexperia
Hex inverter
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
Fig. 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT402-1 (TSSOP14)
74ABT04
Product data sheet
7 / 10
74ABT04
Nexperia
Hex inverter
12. Abbreviations
Table 9. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74ABT04 v.4
20201006
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 and Section 2 updated.
Type number 74ABT04DB (SOT337-1 / SSOP14) removed.
74ABT04 v.3
20160812
Modifications:
74ABT04 v.2
74ABT04
Product data sheet
74ABT04 v.3
Product data sheet
74ABT04 v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
19950918
Product specification
8 / 10
74ABT04
Nexperia
Hex inverter
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ABT04
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
9 / 10
74ABT04
Nexperia
Hex inverter
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 2
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................3
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 4
10.1. Waveforms and test circuit........................................ 5
11. Package outline.......................................................... 6
12. Abbreviations.............................................................. 8
13. Revision history..........................................................8
14. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 October 2020
74ABT04
Product data sheet
10 / 10
