E1225L05B-FSR
E1225L05B-FSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL120X25MM05VDC
E1225L05B-FSR 数据手册
4.72 ±0.02 (120 ±0.5) 0.98 ±0.02 (25 ±0.5) 4.13 ±0.01 (105 ±0.3) 0.19 (5) .32 0.19 (5) STATIC PRESSURE - IN. OF WATER DC AXIAL FANS E1225 series E .28 H .24 M .20 L S .16 .12 .08 .04 20 0 40 60 80 100 120 AIR FLOW (CFM) 4x Ø 0.18 (Ø 4.5) (120 x 120 x 25 mm) 4.72 x 4.72 x 0.98 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing or sleeve Rated Voltage Current mA Air Volume V 5 12 48 RPM 5/12/24 220 100 85 - 1,400 1.24 44 2.25 0.09 28 197 E1225L 5/12/24 340 142 95 - 1,800 1.55 55 3.00 0.12 32 197 Frame: flanged E1225M 5/12/24/48 600 245 160 80 2,200 1.89 67 4.50 0.18 36 197 Protection: thermal E1225H 12/24/48 - 385 240 120 2,600 2.32 82 6.00 0.24 40 197 tachometer output or locked rotor alarm signal; thermistor control; PWM speed control E1225E 12/24/48 - 580 340 170 3,000 2.63 93 7.00 0.28 44 197 w w w.mechatronic s.com E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise g dbA MM INCH E1225S Options: 24 Speed terminal or AWG24, UL1007 lead wires Connection: 12.15.14 Model No. 800-453-4569 Cooling Simplified
E1225L05B-FSR 价格&库存
很抱歉,暂时无法提供与“E1225L05B-FSR”相匹配的价格&库存,您可以联系我们找货
