4715KL-07W-B59-E00
4715KL-07W-B59-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FANAXIAL119X38MM48VDCWIRE
4715KL-07W-B59-E00 数据手册
11938KA (119 X 38L) Legacy Part No. 4715KL NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: In H2O (Pa) .48 100 Auto Restart/Polarity Protection Insulation Resistance: N 80 .32 10M Ω or over with a DC500V Megger M Static Pressure N Class: -10°C ~ +40°C (Operating) L ~ M Class: -10°C ~ +70°C (Operating) L ~ M Class: -40°C ~ +70°C (Storage) N Class: -40°C ~ +60°C (Storage) (non-condensing environment) .24 60 .16 40 .08 20 L K J Ps Expected Life 0 Failure Rate: 10% 25°C 100,000 Hours 0.5 1.0 1.5 17.6 35.3 53 2.0 71 2.5 88 3.0 3.5 106 124 (m3/min) CFM Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG24, +Red, -Black 11.8 (300) min ROTATION .169 8 – (φ4.3± 0.2) inch Units: (mm) .169 4 – (φ4.3± 0.2) 4.13 (105.0) 4.51 (114.5) 4.13 (105.0) 4.51 (114.5) INLET SIDE OUTLET SIDE Specifications Rated Voltage LEGACY P/N NAME PLATE 96 0) 4. 26. 1 (φ 4.51 (114.5) 4.13 (105.0) 4.51 (114.5) 4.13 (105.0) 88 0) 4. 24. 1 (φ MODEL AIR .169 4 – (φ4.3± 0.2) 4.13 (105.0 ± 0.5) 4.69 (119.0 ± 0.5) Panel Cut-Outs 4.13 (105.0 ± 0.5) 4.69 (119.0 ± 0.5) 1.5 (38.4 ± 0.5) Operating Current Voltage Input Speed Max. Max. Static Power Air Flow Pressure Noise Mass (V) (V) (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 11938KA-12J-EA-00 4715KL-04W-B10-E00 12 6.0 ~ 13.8 0.27 3.24 2300 83.6 2.37 .17 44.1 37.0 260 11938KA-12K-EA-00 4715KL-04W-B20-E00 12 6.0 ~ 13.8 0.40 4.80 2650 97.0 2.75 .22 55.9 41.0 260 11938KA-12L-EA-00 4715KL-04W-B30-E00 12 6.0 ~ 13.8 0.55 6.60 2950 108.0 3.07 .27 68.2 42.5 260 11938KA-12M-EA-00 4715KL-04W-B40-E00 12 6.0 ~ 13.8 0.70 8.40 3200 118.0 3.34 .33 81.4 46.5 260 11938KA-12N-EA-00 4715KL-04W-B50-E00 12 9.5 ~ 12.6 1.00 12.00 3600 129.9 3.68 .44 110.0 50.0 260 11938KA-24J-EA-00 4715KL-05W-B10-E00 24 10.0 ~ 27.6 0.15 3.60 2300 83.6 2.37 .17 44.1 37.0 260 4715KL-05W-B20-E00 24 10.0 ~ 27.6 0.21 5.04 2650 97.0 2.75 .22 55.9 41.0 260 11938KA-24L-EA-00 4715KL-05W-B30-E00 24 10.0 ~ 27.6 0.31 7.44 2950 108.0 3.07 .27 68.2 42.5 260 11938KA-24M-EA-00 4715KL-05W-B40-E00 24 10.0 ~ 27.6 0.35 8.40 3200 118.0 3.34 .33 81.4 46.5 260 11938KA-24N-EA-00 4715KL-05W-B50-E00 24 18.0 ~ 25.0 0.50 12.00 3600 130.0 3.68 .44 110.0 50.0 260 11938KA-48J-EA-00 4715KL-07W-B10-E00 48 25.0 ~ 55.2 0.08 3.84 2300 83.6 2.37 .17 44.1 37.0 260 11938KA-48K-EA-00 4715KL-07W-B20-E00 48 25.0 ~ 55.2 0.11 5.28 2650 97.0 2.75 .22 55.9 41.0 260 11938KA-48L-EA-00 4715KL-07W-B30-E00 48 25.0 ~ 55.2 0.16 7.68 2950 108.0 3.07 .27 68.2 42.5 260 11938KA-48M-EA-00 4715KL-07W-B40-E00 48 25.0 ~ 55.2 0.20 9.60 3200 118.0 3.34 .33 81.4 46.5 260 11938KA-48N-EA-00 4715KL-07W-B50-E00 48 30.0 ~ 60.0 0.16 7.68 3600 130.0 3.68 .44 110.0 50.0 260 11938KA-24K-EA-00 ** DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Rotation: Clockwise ** Airflow Outlet: Air Out Over Struts Contact NMB for availability *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
4715KL-07W-B59-E00
1. 物料型号:11938KA系列,有多个不同的电压和电流规格,如11938KA-12J-EA-00、11938KA-12K-EA-00等。 2. 器件简介:文档描述了直流轴流风扇的一般规格,包括电机保护、特性曲线、自动重启/极性保护、绝缘电阻、介电强度、允许的环境温度范围。 3. 引脚分配:文档中没有明确提到引脚分配。 4. 参数特性:包括额定电压、工作电压、电流、输入功率、转速、最大空气流量、最大静压、噪音水平、质量等。 5. 功能详解:文档提供了风扇的预期寿命和故障率,例如在25°C时预期寿命为100,000小时,故障率为10%。 6. 应用信息:文档提到了风扇的空气流量和静态压力的预期值,以及使用材料的概述,如外壳、叶轮、轴承和引线。 7. 封装信息:提供了面板开孔尺寸和风扇的外形尺寸。
4715KL-07W-B59-E00 价格&库存
很抱歉,暂时无法提供与“4715KL-07W-B59-E00”相匹配的价格&库存,您可以联系我们找货
