CFM-A225-13-20
CFM-A225-13-20
    CUIDEVICES
    DCAXIALFAN,120MMSQUARE,25
CFM-A225-13-20 数据手册
Additional Resources: Product Page | 3D Model date 08/12/2022 page 1 of 6 SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN FEATURES • 120 x 120 mm frame • high fan speed for greater air flow • dual ball bearing construction • auto restart protection standard on all models MODEL input voltage rated (Vdc) input current range (Vdc) typ (A) input power rated speed air flow1 static pressure2 max (A) max (W) noise typ (RPM) (CFM) (inch H2O) max (dBA) CFM-A225-13* 12 6~13.8 0.59 0.79 9.48 4,100 126.89 0.49 53.5 CFM-A225-23* 24 16~27.6 0.31 0.39 9.36 4,100 126.89 0.49 53.5 CFM-A225-43* 48 30~55.2 0.17 0.23 11.04 4,100 126.89 0.49 53.5 CFM-A238-13* 12 6~13.8 1.40 1.75 21 4,600 200.9 0.78 61.5 CFM-A238-23* 24 16~27.6 0.77 0.88 21.12 4,600 200.9 0.78 61.5 CFM-A238-43* 48 30~55.2 0.36 0.48 23.04 4,600 200.9 0.78 61.5 Notes: 1. At 0 inch H20 static pressure. 2. At 0 CFM airflow. *. Discontinued CFM-A225-13-10, CFM-A225-13-11, CFM-A225-13-20, CFM-A225-23-11, CFM-A225-23-22, CFM-A225-43-11, CFM-A225-43-20, CFM-A225-43-22, CFM-A238-13-11, CFM-A238-23-11, CFM-A238-23-20, CFM-A238-23-22, and CFM-A238-43-20 models. PART NUMBER KEY CFM-A2 XX - X 3 - XX - CXX Base Number Depth 25 = 25 mm 38 = 38 mm Reserved for Custom Configurations Input Voltage 1 = 12 Vdc 2 = 24 Vdc 4 = 48 Vdc cuidevices.com Fan Signals 10 = no signals 11 = rotation detector signal 20 = tachometer signal 22 = tachometer signal / PWM control signal Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 2 of 6 INPUT parameter conditions/description min typ max units operating input voltage 12 Vdc input models 24 Vdc input models 48 Vdc input models 6 16 30 12 24 48 13.8 27.6 55.2 Vdc Vdc Vdc current CFM-A225-13 CFM-A225-23 CFM-A225-43 CFM-A238-13 CFM-A238-23 CFM-A238-43 0.59 0.31 0.17 1.40 0.77 0.36 0.79 0.39 0.23 1.75 0.88 0.48 A A A A A A power CFM-A225-13 CFM-A225-23 CFM-A225-43 CFM-A238-13 CFM-A238-23 CFM-A238-43 7.08 7.44 8.16 16.80 18.48 17.28 9.48 9.36 11.04 21 21.12 23.04 W W W W W W starting voltage at 25°C 12 Vdc input models 24 Vdc input models 48 Vdc input models 6 12 24 Vdc Vdc Vdc PERFORMANCE parameter conditions/description min typ max units rated speed at 25°C, after 10 minutes CFM-A225 models CFM-A238 models 3,690 4,140 4,100 4,600 4,510 5,060 RPM RPM air flow at 0 inch H2O, see performance curves CFM-A225 models CFM-A238 models static pressure noise 126.89 200.9 CFM CFM at 0 CFM, see performance curves CFM-A225 models CFM-A238 models 0.49 0.78 inch H2O inch H2O at 1 m CFM-A225 models CFM-A238 models 51.5 59.5 53.5 61.5 dBA dBA min typ max units min typ max units PROTECTIONS / SIGNALS1 parameter conditions/description auto restart protection available on all models rotation detector available on “11” models tachometer signal available on “20” and “22” models PWM control signal available on “22” models Notes: 1. See application notes for details. SAFETY & COMPLIANCE parameter conditions/description insulation resistance of frame at 500 Vdc between frame and positive terminal dielectric strength at 500 Vac, 60 Hz, 1 minute between frame and positive terminal safety approvals UL/cUL 507, TUV (EN 62368-1) EMI/EMC EN 55022:2010+AC:2011 Class B, EN 61000-3-2:2014, EN 61000-3-3:2013, EN 55024:2010 life expectancy at 45°C, 15~65% RH RoHS yes 10 MΩ 5 70,000 cuidevices.com mA hours Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 3 of 6 ENVIRONMENTAL parameter conditions/description min operating temperature typ max units 70 °C -10 storage temperature -40 70 °C operating humidity non-condensing 5 90 % storage humidity non-condensing 5 95 % PERFORMANCE CURVES 0.50 0.40 CFM-A238 (mm H2O) (Inch H2O) CFM-A225 14.00 0.98 12.00 . . 10.00 0.30 0.20 . 8.00 6.00 10. 4.00 0.10 0.00 . 2.00 0.00 0.00 0.00 50.00 100.00 150.00 (CFM) 0. 0. (CMM) 0.00 0.74 1.49 2.23 2.98 3.72 0.00 cuidevices.com . 100. . . . Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 4 of 6 MECHANICAL parameter conditions/description motor 4 pole DC brushless min bearing system ball bearing direction of rotation counter-clockwise viewed from front of fan blade dimensions CFM-A225 models 120 x 120 x 25.4 CFM-A238 models 120 x 120 x 38 material PBT (UL94V-0) weight CFM-A225-13 CFM-A225-23 CFM-A225-43 CFM-A238-13 CFM-A238-23 CFM-A238-43 units: mm [inch] CFM-A225 wire: UL 1007, 24 AWG WIRE CONNECTIONS Function Red +Vin Black -Vin Yellow1 FG Signal White RD Signal Blue1 PWM 1 ōŢţŦŭ CFM-A238 wire: UL 1007, 24 AWG WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin 1 Yellow FG Signal White1 RD Signal Blue PWM 1 Note: ōŢţŦŭ 1. Wires only present on versions with output signals. cuidevices.com max units mm mm 190.0 189.8 190.6 297.0 283.7 283.2 MECHANICAL DRAWING Wire Color typ g g g g g g Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 5 of 6 APPLICATION NOTES Auto Restart Protection/Current Limit Protection When the fan motor is locked, the device will cut off the drive current within two to six seconds and restart automatically after a few seconds. If the lock situation is continued, the device will work on a repeated cycle of cut-off and restart until the lock is released. (See Figure 1 below). Figure 1 Current Limit Protection Lock Sensor/Rotation Detector Lock Sensor is used to detect if the fan motor is operating or stopped. Alarm High: the output will be logical low when fan is operating and be logical high when fan motor is locked. (See Figures 2~3 below). Figure 3 RD Signal Output Circuit: Open Collector Figure 2 Alarm High Output Waveform Ic=5mA max Pulse Sensor/Tachometer Signal/FG Pulse Sensor is for detecting the rotational speed of the fan motor. At locked rotor condition, the signal stops cycling and the output is fixed at VoH or VoL (See Figures 4~5 below). Figure 4 Output Waveform Figure 5 FG Signal Output Circuit: Open Collector Ic=10mA max PMW Control Signal A speed control lead can be provided that will accept a PWM signal from the customer circuit to vary the speed of the fan. The change in speed is linear by changing the Duty-Cycle of the PWM. Open collector type and pull-up voltage is changed by maximum operating voltage and sink current by consuming current. (See Figure 6 below). Figure 6 Duty Cycle Vs=4~5 V cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-120 | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 6 of 6 REVISION HISTORY rev. description date 1.0 initial release 08/15/2016 1.01 updated datasheet 07/27/2017 1.02 updated to be certified to EN 62368-1 safety standard 07/09/2019 1.03 brand update 02/07/2020 1.04 discontinued CFM-A225-23-22 and CFM-A238-23-22 models 03/31/2022 1.05 discontinued CFM-A225-13-10, CFM-A225-13-11, CFM-A225-13-20, CFM-A225-23-11, CFM-A225-43-11, CFM-A225-43-20, CFM-A225-43-22, CFM-A238-13-11, CFM-A238-23-11, CFM-A238-23-20, and CFM-A238-43-20 models 04/26/2022 logo, datasheet style update 08/12/2022 1.06 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CFM-A225-13-20 价格&库存
很抱歉,暂时无法提供与“CFM-A225-13-20”相匹配的价格&库存,您可以联系我们找货
CFM-A225-13-20
  • 1+199.258871+24.99708
  • 10+163.3354910+20.49048
库存:15
