06038DA-12Q-EA-D0
06038DA-12Q-EA-D0
    NMBTECHNOLOGIESCORPORATION
    FAN12VDC60X38MM2WR
06038DA-12Q-EA-D0 数据手册
06038DA (60 X 38L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -30°C ~ +70°C (Storage) (non-condensing environment) 4.00 1000 3.20 800 2.40 600 1.60 400 .80 200 0 0 R Class Q Class Ps Expected Life Failure Rate: 10% 40°C S Class 70,000 Hours (L10) Material 0 0.5 0 17.65 Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL10368, AWG24, +Red, -Black (m3/min) 35.3 52.95 70.6 CFM 7.88 min (200) AIR .177 (4 – φ4.5) (4 – φ4.5) 2.28 (58.0) 1.97 (50.0) 52 2. 4.0) 6 (φ .157 (4.0 ±0.3 ) 1.77 (8 – φ 4.5 ±0.3) 2.36 (60.0 ±1.0 ) 1.97 (50.0 ±0.3) .177 (φ 2.4 63 8 .0 ) 2.0 ROTATION Panel Cut-Outs 2.28 (58.0) 1.97 (50.0) 1.5 Air Flow Outline inch Units: (mm) 1.0 1.97 (50.0 ±0.3 ) 2.36 (60.0 ±1.0 ) .157 (4.0 ±0.3) 1.49 (38.0 ±0.5 ) 1.97 (50.0) 2.28 (58.0) 1.97 (50.0) 2.28 (58.0) INLET SIDE OUTLET SIDE NAME PLATE Specifications Rated Operating Voltage Voltage Power (V) (V) (A)*1 (W)*1 (min-1)*1 06038DA-12Q-EA-D0 12 10.8 ~ 13.2 0.78 9.40 13000 50.5 1.43 2.31 575.0 58.0 123 06038DA-12R-EA-D0 12 10.8 ~ 13.2 1.16 14.00 15000 58.6 1.66 2.97 740.0 61.5 123 06038DA-12S-EA-D0 12 10.8 ~ 13.2 1.65 19.80 17000 66.4 1.88 3.71 925.0 63.5 123 MODEL Rotation: Clockwise Current Airflow Outlet: Air Out Over Struts Input Speed Max. Max. Static Air Flow Pressure CFM*1 (m3/min)*1 in H2O *1: Average Values in Free Air Noise Mass (Pa)*1 (dB)*1 (g) Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: (Pa)
06038DA-12Q-EA-D0 价格&库存
很抱歉,暂时无法提供与“06038DA-12Q-EA-D0”相匹配的价格&库存,您可以联系我们找货
