9G1212M4021
9G1212M4021
    SANYODENKI
    FAN120X25MM12VDCRBLS
9G1212M4021 数据手册
120×120×25 mm San Ace 120 9G type Model 9G1212B401 is not certified. ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Yellow Sensor · Mass………………………………………… 240 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed SPL Operating temperature Expected life [V] [V] [A] [W] [min-1] [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.9 0.58 0.4 0.31 0.19 0.14 0.06 0.47 0.37 0.21 0.17 0.1 0.08 0.23 0.16 0.13 0.1 0.06 0.05 10.8 6.96 4.8 3.72 2.28 1.68 0.72 11.28 8.88 5.04 4.08 2.4 1.92 11.04 7.68 6.24 4.8 2.88 2.4 4100 3650 3150 2850 2250 1950 1000 4100 3650 3150 2850 2250 1950 4100 3650 3150 2850 2250 1950 3.68 3.25 2.83 2.5 1.98 1.66 0.88 3.68 3.25 2.83 2.5 1.98 1.66 3.68 3.25 2.83 2.5 1.98 1.66 130 115 100 88 70 59 31 130 115 100 88 70 59 130 115 100 88 70 59 120 98 77 64 42 31 9.6 120 98 77 64 42 31 120 98 77 64 42 31 0.482 0.394 0.309 0.257 0.169 0.124 0.039 0.482 0.394 0.309 0.257 0.169 0.124 0.482 0.394 0.309 0.257 0.169 0.124 51 48 44 40 35 29 18 51 48 44 40 35 29 51 48 44 40 35 29 -20 to +70 40000/60˚C (70000/40˚C) 9G1212G401 9G1212E401 9G1212A401 9G1212H401 9G1212F401 9G1212M401 9G1212B401 9G1224G401 9G1224E401 9G1224A401 9G1224H401 9G1224F401 9G1224M401 9G1248G401 9G1248E401 9G1248A401 9G1248H401 9G1248F401 9G1248M401 10.2 to 13.8 6 to 13.8 12 7 to 13.8 10.2 to 13.8 20.4 to 27.6 24 12 to 27.6 20.4 to 27.6 48 40.8 to 55.2 Max. airflow Max. static pressure Note 1: Sensor and control options are available for selection. Refer to the table on pp. 627 to 628. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 9G1212E401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.5 0.4 0.3 0.2 0.1 0 0.5 140 13.8 V 120 0.4 12 V 100 10.2 V 80 60 40 20 0 1 2 3 4 0 20 40 60 80 100 120 140 Airflow 172 CATALOG No. C1111B002 '21.9.IT (m3/min) (CFM) 0.3 0.2 0.1 0 (inch H2O) (Pa) 120 0.4 100 13.8 V 13.8 V 100 12 V 80 10.2 V 60 40 20 0 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure 0.6 9G1212A401 With pulse sensor Static pressure 9G1212G401 Static pressure DC DC Fan 120 mm sq. DC Fan 1 2 0 20 40 60 80 3 4 (m3/min) 100 120 140 (CFM) Airflow 0.3 12 V 80 10.2 V 60 0.2 40 0.1 0 20 0 1 2 3 4 (m3/min) 0 20 40 60 80 100 120 140 (CFM) Airflow 9G1212F401 With pulse sensor Operating voltage range Operating voltage range 60 Static pressure 12 V 0.2 40 20 6V 0 1 0 9G1212B401 20 2 40 60 Airflow 3 (m3/min) 80 100 13.8 V Static pressure Static pressure 0.5 12 V 6 10.2 V 4 0.4 0.3 0.2 0.1 2 0 0.4 0 10 20 0 1.2 (m3/min) 0.8 30 40 0 Static pressure Static pressure 0.3 24 V 20.4 V 20 1 2 3 4 0.1 0.6 27.6 V 0.5 24 V 30 20.4 V 20 0.06 0.04 10 0 0.4 0.3 0.2 0.1 0.02 0 1 2 3 4 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 Airflow 0.3 0.2 0.1 0 (m3/min) (CFM) 0 (CFM) With pulse sensor 120 27.6 V 100 24 V 80 20.4 V 60 40 20 0 1 2 3 4 (m3/min) 0 20 40 60 80 100 120 140 (CFM) Airflow 9G1224F401 With pulse sensor With pulse sensor Operating voltage range 27.6 V 24 V 20 12 V 0 1 20 2 40 60 Airflow 3 (m3/min) 80 100 60 50 27.6 V 40 24 V 20.4 V 30 20 10 0 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 90 (CFM) Airflow 9G1248E401 With pulse sensor With pulse sensor Operating voltage range (inch H2O) (Pa) 0.5 140 55.2 V 120 0.4 48 V 100 40.8 V 80 60 40 20 0 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 (CFM) (inch H2O) (Pa) 40 2.0 (m3/min) (inch H2O) (Pa) 0 Static pressure Static pressure 0.08 20.4 V Operating voltage range (inch H2O) (Pa) 1.5 Airflow 0.4 24 V 0 9G1248G401 Operating voltage range 1.0 Operating voltage range 40 0 (m3/min) With pulse sensor 0.10 0.5 0 10 20 30 40 50 60 70 27.6 V 0.2 Airflow 0.14 0 9G1224E401 60 0 20 40 60 80 100 120 140 (CFM) 9G1224M401 10 0 20 40 60 80 100 120 140 (CFM) 27.6 V 0 0.04 0 (m3/min) Operating voltage range 40 0.12 2.5 20 9G1224H401 0.2 0.16 2.0 40 80 0 1.5 60 (inch H2O) (Pa) 0.1 0.06 0.5 80 100 60 7V 20 Airflow With pulse sensor 80 0.08 (inch H2O) (Pa) 100 (inch H2O) (Pa) 0.3 1.0 With pulse sensor 120 (CFM) Operating voltage range 0.4 0.5 140 Airflow 9G1224A401 12 V 0.10 0.02 Operating voltage range 0.6 8 0 7V 10 (inch H2O) (Pa) 10 0.01 20 9G1224G401 With pulse sensor 12 0.02 30 13.8 V 30 0 10 20 30 40 50 60 70 80 90 (CFM) 14 0.03 12 V 0.12 Airflow (inch H2O) (Pa) 0.04 13.8 V 40 (CFM) Operating voltage range 0.05 40 0.14 50 Static pressure 0 0.16 Static pressure 0.1 (inch H2O) (Pa) 60 Static pressure Static pressure 13.8 V 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 Static pressure 80 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 0.3 9G1212M401 With pulse sensor DC Fan 120 mm sq. 9G1212H401 DC ■ Airflow - Static Pressure Characteristics 1 2 3 4 (m3/min) 0 20 40 60 80 100 120 140 (CFM) Airflow 0.3 0.2 0.1 0 120 55.2 V 100 48 V 80 40.8 V 60 40 20 0 1 2 3 4 (m3/min) 0 20 40 60 80 100 120 140 (CFM) Airflow CATALOG No. C1111B002 '21.9.IT 173 9G1248H401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 100 80 48 V 80 0.3 0.3 55.2 V 40.8 V 60 0.2 40 0.1 20 0 0 1 2 3 4 48 V 40.8 V 40 0 (m3/min) 20 0 1 0 0 20 40 60 80 100 120 140 (CFM) Airflow 9G1248M401 20 40 With pulse sensor (inch H2O) (Pa) 40 55.2 V Static pressure 0.14 0.12 48 V 30 0.10 0.08 40.8 V 20 0.06 0.04 10 0.02 0 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 (CFM) Airflow ■ Dimensions (unit: mm) (With ribs) 4-ø4.3±0.3 Mounting hole (10) +30 300 0 Lead wire AWG24 UL 1007 (5) 104.8±0.3 119±0.5 Rotating direction 174 CATALOG No. C1111B002 '21.9.IT 2 60 Airflow Operating voltage range 0.16 Operating voltage range 55.2 V 0.2 0.1 With pulse sensor (inch H2O) (Pa) 60 Static pressure Static pressure 0.4 9G1248F401 With pulse sensor Static pressure 9G1248A401 119±0.5 104.8±0.3 DC DC Fan 120 mm sq. ■ Airflow - Static Pressure Characteristics (5) +1 25 0 Airflow direction 3 (m3/min) 80 100 (CFM) 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 60 50 55.2 V 40 48 V 40.8 V 30 20 10 0 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 90 (CFM) Airflow Outlet side 104.8±0.3 117 104.8±0.3 34 117 117 4-ø4.5 ø1 104.8±0.3 26 ø1 104.8±0.3 4-ø4.5 DC Fan 120 mm sq. Inlet side DC ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) 117 ■ Options Finger guards page: p. 585 Model no.: 109-019E, 109-019K, 109-019C, 109-019H Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1000G page: p. 592 Model no.: 109-1000F13 (13PPI), 109-1000F20 (20PPI), 109-1000F30 (30PPI), 109-1000F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 175
9G1212M4021
物料型号:9G1212B401
器件简介:这是一个120×120×25 mm尺寸的直流风扇,由San Ace公司生产。
引脚分配:文档中提到了两种颜色的引线,红色和黑色或蓝色,以及可能的传感器引线黄色。
参数特性: - 材质:框架为塑料(UL 94V-0),叶轮为塑料(UL 94V-1)。 - 预期寿命:在60°C、额定电压下,L10寿命为90%的存活率,40°C的预期寿命仅供参考。 - 电机保护功能:包括锁定转子烧毁保护和反极性保护。 - 耐电压:50/60 Hz,500 VAC,持续1分钟(引线导体与框架之间)。 - 绝缘电阻:10 MΩ或更高,使用500 VDC兆欧表测量(引线导体与框架之间)。 - 声压级(SPL):在空气入口1米处测量。 - 存储温度:-30至+70°C(非凝结)。 - 质量:240克。
功能详解: - 该型号风扇具备脉冲传感器,并且可以选择传感器和控制选项。 - 提供了不同工作电压下的气流-静压特性曲线图。
应用信息:文档中没有明确提供应用信息,但直流风扇通常用于电子设备散热。
封装信息:提供了安装孔的参考尺寸和通风口的尺寸信息。
9G1212M4021 价格&库存
很抱歉,暂时无法提供与“9G1212M4021”相匹配的价格&库存,您可以联系我们找货
9G1212M4021
    库存:5000
