120×120×25 mm
San Ace 120 9G type
Model 9G1212B401 is not certified.
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Yellow
Sensor
· Mass………………………………………… 240 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
SPL
Operating temperature
Expected life
[V]
[V]
[A]
[W]
[min-1]
[m3/min]
[CFM]
[Pa]
[inchH2O]
[dB (A)]
[˚C]
[h]
0.9
0.58
0.4
0.31
0.19
0.14
0.06
0.47
0.37
0.21
0.17
0.1
0.08
0.23
0.16
0.13
0.1
0.06
0.05
10.8
6.96
4.8
3.72
2.28
1.68
0.72
11.28
8.88
5.04
4.08
2.4
1.92
11.04
7.68
6.24
4.8
2.88
2.4
4100
3650
3150
2850
2250
1950
1000
4100
3650
3150
2850
2250
1950
4100
3650
3150
2850
2250
1950
3.68
3.25
2.83
2.5
1.98
1.66
0.88
3.68
3.25
2.83
2.5
1.98
1.66
3.68
3.25
2.83
2.5
1.98
1.66
130
115
100
88
70
59
31
130
115
100
88
70
59
130
115
100
88
70
59
120
98
77
64
42
31
9.6
120
98
77
64
42
31
120
98
77
64
42
31
0.482
0.394
0.309
0.257
0.169
0.124
0.039
0.482
0.394
0.309
0.257
0.169
0.124
0.482
0.394
0.309
0.257
0.169
0.124
51
48
44
40
35
29
18
51
48
44
40
35
29
51
48
44
40
35
29
-20 to +70
40000/60˚C
(70000/40˚C)
9G1212G401
9G1212E401
9G1212A401
9G1212H401
9G1212F401
9G1212M401
9G1212B401
9G1224G401
9G1224E401
9G1224A401
9G1224H401
9G1224F401
9G1224M401
9G1248G401
9G1248E401
9G1248A401
9G1248H401
9G1248F401
9G1248M401
10.2 to 13.8
6 to 13.8
12
7 to 13.8
10.2 to 13.8
20.4 to 27.6
24
12 to 27.6
20.4 to 27.6
48
40.8 to 55.2
Max. airflow
Max. static pressure
Note 1: Sensor and control options are available for selection. Refer to the table on pp. 627 to 628.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
9G1212E401
With pulse sensor
(inch H2O) (Pa)
0.5
0.4
0.3
0.2
0.1
140
13.8 V
120
0.4
12 V
100
10.2 V
80
60
40
2
3
4
0 20 40 60 80 100 120 140
Airflow
172
CATALOG No. C1111B002 '21.9.IT
(m3/min)
(CFM)
0.3
0.2
0.1
(inch H2O) (Pa)
120
0.4
100
13.8 V
13.8 V
100
12 V
80
10.2 V
60
40
With pulse sensor
(inch H2O) (Pa)
Static pressure
0.6
9G1212A401
With pulse sensor
Static pressure
9G1212G401
Static pressure
DC
DC Fan 120 mm sq.
DC Fan
1
2
0 20 40 60 80
3
4
(m3/min)
100 120 140 (CFM)
Airflow
0.3
12 V
80
10.2 V
60
0.2
40
0.1
2
3
4
(m3/min)
0 20 40 60 80 100 120 140 (CFM)
Airflow
9G1212F401
With pulse sensor
60
Static pressure
12 V
0.2
40
6V
9G1212B401
40
60
Airflow
3 (m3/min)
80 100
13.8 V
Static pressure
Static pressure
0.5
12 V
6
10.2 V
4
0.4
0.3
0.2
0.1
2
1.2 (m3/min)
0.8
30
40
Static pressure
Static pressure
0.3
24 V
20.4 V
2
3
4
0.1
0.6
27.6 V
0.5
24 V
30
20.4 V
0.04
10
0.3
0.2
0.1
0.02
2
3
4
0.5
1.0
1.5
2.0 (m3/min)
0 10 20 30 40 50 60 70
Airflow
0.3
0.2
0.1
(m3/min)
(CFM)
(CFM)
With pulse sensor
120
27.6 V
100
24 V
80
20.4 V
60
40
2
3
4
(m3/min)
Airflow
9G1224F401
With pulse sensor
With pulse sensor
27.6 V
24 V
12 V
40
60
Airflow
3 (m3/min)
80 100
60
50
27.6 V
40
24 V
20.4 V
30
1.0
1.5
2.0
2.5
(m3/min)
0 10 20 30 40 50 60 70 80 90 (CFM)
Airflow
9G1248E401
With pulse sensor
With pulse sensor
(inch H2O) (Pa)
0.5
140
55.2 V
120
0.4
48 V
100
40.8 V
80
60
40
0.22
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
(CFM)
(inch H2O) (Pa)
40
2.0 (m3/min)
(inch H2O) (Pa)
Static pressure
Static pressure
0.08
20.4 V
(inch H2O) (Pa)
1.5
Airflow
0.4
24 V
9G1248G401
1.0
40
(m3/min)
With pulse sensor
0.10
0.5
27.6 V
0.2
Airflow
0.14
9G1224E401
60
9G1224M401
10
27.6 V
(m3/min)
40
0.12
2.5
9G1224H401
0.2
0.16
2.0
40
80
60
(inch H2O) (Pa)
0.1
0.06
0.5
80
100
60
7V
Airflow
With pulse sensor
80
0.08
(inch H2O) (Pa)
100
(inch H2O) (Pa)
0.3
1.0
With pulse sensor
120
(CFM)
0.4
0.5
140
Airflow
9G1224A401
12 V
0.10
0.02
0.6
8
7V
10
(inch H2O) (Pa)
10
0.01
9G1224G401
With pulse sensor
12
0.02
30
13.8 V
30
14
0.03
12 V
0.12
Airflow
(inch H2O) (Pa)
0.04
13.8 V
40
(CFM)
0.05
40
0.14
50
Static pressure
Static pressure
0.1
(inch H2O) (Pa)
60
Static pressure
Static pressure
13.8 V
0.24
0.22
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
Static pressure
80
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
0.3
9G1212M401
With pulse sensor
DC Fan 120 mm sq.
9G1212H401
DC
1
2
3
4
(m3/min)
Airflow
0.3
0.2
0.1
55.2 V
100
48 V
80
40.8 V
60
40
2
3
4
(m3/min)
Airflow
173
9G1248H401
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
100
80
48 V
80
0.3
0.3
55.2 V
40.8 V
60
0.2
40
0.1
2
3
4
48 V
40.8 V
40
(m3/min)
Airflow
9G1248M401
With pulse sensor
(inch H2O) (Pa)
40
55.2 V
Static pressure
0.14
0.12
48 V
30
0.10
0.08
40.8 V
0.04
10
0.02
1.0
1.5
2.0 (m3/min)
(CFM)
Airflow
■ Dimensions (unit: mm)
(With ribs)
4-ø4.3±0.3
Mounting hole
(10)
+30
300 0
Lead wire
AWG24
UL 1007
(5)
104.8±0.3
119±0.5
Rotating direction
174
2
60
Airflow
0.16
55.2 V
0.2
0.1
With pulse sensor
(inch H2O) (Pa)
60
Static pressure
Static pressure
0.4
9G1248F401
With pulse sensor
Static pressure
9G1248A401
119±0.5
104.8±0.3
DC
DC Fan 120 mm sq.
(5)
+1
25 0
Airflow direction
3 (m3/min)
80 100
(CFM)
0.24
0.22
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
50
55.2 V
40
48 V
40.8 V
30
1.0
1.5
2.0
2.5
(m3/min)
Airflow
Outlet side
104.8±0.3
117
104.8±0.3
34
117
117
4-ø4.5
ø1
104.8±0.3
26
ø1
104.8±0.3
4-ø4.5
DC Fan 120 mm sq.
Inlet side
DC
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
117
■ Options
Finger guards
page: p. 585
Model no.: 109-019E, 109-019K, 109-019C, 109-019H
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1000G
page: p. 592
Model no.: 109-1000F13 (13PPI), 109-1000F20 (20PPI),
109-1000F30 (30PPI), 109-1000F40 (40PPI)
175
很抱歉,暂时无法提供与“9G1248A4011”相匹配的价格&库存,您可以联系我们找货
