BG1002-B044-000-00
BG1002-B044-000-00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN BLOWER 107X25MM 12VDC WIRE
BG1002-B044-000-00 数据手册
09533GA (Ø95 X 33L) Legacy Part No. BG0903 NMBTC.COM / 248.919.2250 General Specifications Characteristic Curves Motor Protection: Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 25°C (Pa) 1.8 450 1.6 550 500 350 1.2 300 1.0 250 .8 200 .6 .2 M L K 150 100 50 0 100,000 Hours Q 400 1.4 .4 Failure Rate: 10% 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 3.5 7.0 10.6 14.1 17.6 21.1 24.7 28.2 31.8 35.3 40 44.5 Air Flow (m3/min) CFM Material Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black Outline 1.3 (33 ± 0.5) 1.06 (27.0) LOT No. 3.82 (97.0) 1.97 1.54 (39.0 ± 0.3) (50.0 ± 0.3) AIR DIE-CAV No. AIR 3.68 (93.5) 2.09 (53.0) 2.28 (58.0 ± 0.5) THROUGH HOLE .177 2 – (φ4.5 ± 0.3) NAME PLATE 11.8 (300) min ± 1.26 (32.0 ± 0.3) ROTATION 1.54 (39.0 ± 0.3) inch Units: (mm) .98 (25.0) DC Blowers Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: In H2O 2.2 2.0 1.26 (32.0 ± 0.3) Specifications MODEL LEGACY P/N Rated Operating Current Voltage Voltage Input Power Speed (V) (V) (A)*1 (W)*1 (min-1)*1 09533GA-12K-AA-00 BG0903-B042-000-00 12 8 ~ 13.8 0.40 4.80 09533GA-12L-AA-00 BG0903-B043-000-00 12 8 ~ 13.8 0.64 7.68 09533GA-12M-AA-00 BG0903-B044-000-00 12 8 ~ 12.6 1.03 09533GA-12Q-AA-00 BG0903-B047-000-00 12 9.5 ~ 13.2 09533GA-24K-AA-00 BG0903-B052-000-00 24 09533GA-24L-AA-00 BG0903-B053-000-00 09533GA-24M-AA-00 BG0903-B054-000-00 Rotation: Clockwise Label Side Max. Air Flow Max. Static Pressure Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 2700 20.5 0.58 .61 152 47.5 210 3200 24.7 0.70 .90 225 51.5 210 12.40 3700 28.6 0.81 1.4 342 54.5 210 1.6 19.20 5200 38.1 1.08 1.88 470 61.0 210 10 ~ 27.6 0.21 5.04 2700 20.5 0.58 .61 152 47.5 210 24 10 ~ 27.6 0.33 7.92 3200 24.7 0.70 .90 225 51.5 210 24 10 ~ 25.0 0.49 11.80 3700 28.6 0.81 1.4 342 54.5 210 *1: Average Values in Free Air ** Contact NMB for availability Note: PWM/Locked Rotor/Tach Available
BG1002-B044-000-00 价格&库存
很抱歉,暂时无法提供与“BG1002-B044-000-00”相匹配的价格&库存,您可以联系我们找货
