74LVC1G08GW,165
74LVC1G08GW,165
    NEXPERIA(安世)
    TSSOP-5_2.05X1.25MM
    IC GATE AND 1CH 2-INP 5TSSOP
74LVC1G08GW,165 数据手册
74LVC1G08 Single 2-input AND gate Rev. 11 — 28 November 2016 Product data sheet 1. General description The 74LVC1G08 provides one 2-input AND function. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V applications. Schmitt trigger action at all inputs makes the circuit tolerant of slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 1.65 V to 5.5 V  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance  250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74LVC1G08 Nexperia Single 2-input AND gate 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G08GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G08GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G08GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G08GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G08GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G08GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74LVC1G08GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G08GW VE 74LVC1G08GV V08 74LVC1G08GM VE 74LVC1G08GF VE 74LVC1G08GN VE 74LVC1G08GS VE 74LVC1G08GX VE [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram $  %  $ <    <  % PQD PQD Fig 1. Logic symbol 74LVC1G08 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 11 — 28 November 2016 PQD Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 19 74LVC1G08 Nexperia Single 2-input AND gate 6. Pinning information 6.1 Pinning /9&* /9&* %  $  *1'   9&&  < %   9&& $   QF *1'   < DDE 7UDQVSDUHQWWRSYLHZ DDE Fig 4. Pin configuration SOT353-1 and SOT753 Fig 5. Pin configuration SOT886 /9&* /9&* % %   9&& $   QF *1'   <  9&&  <  *1' $ DDH  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 6.  Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 B 1 1 data input A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 74LVC1G08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 19 74LVC1G08 Nexperia Single 2-input AND gate 7. Functional description Table 4. Function table[1] Input Output A B Y L L L L H L H L L H H H [1] H = HIGH voltage level; L = LOW voltage level 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V [1] Min Max 0.5 +6.5 50 - 0.5 +6.5 V mA V mA - 50 Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA - 100 mA 100 - mA - 250 mW 65 +150 C VO > VCC or VO < 0 V VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] Unit For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 4 of 19 74LVC1G08 Nexperia Single 2-input AND gate 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V VCC = 0 V; Power-down mode 0 - 5.5 V 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL II HIGH-level input voltage LOW-level input voltage 40 C to +85 C Conditions Max Min Max 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - 0.35VCC V VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VCC  0.1 - - VCC  0.1 - V IO = 4 mA; VCC = 1.65 V 1.2 - - 0.95 - V IO = 8 mA; VCC = 2.3 V 1.9 - - 1.7 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 1.9 - V IO = 24 mA; VCC = 3.0 V 2.3 - - 2.0 - V IO = 32 mA; VCC = 4.5 V 3.8 - - 3.4 - V - - 0.10 - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.40 - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.80 V - 0.1 1 - 1 A LOW-level VI = VIH or VIL output voltage IO = 100 A; VCC = 1.65 V to 5.5 V 74LVC1G08 Product data sheet Unit Min HIGH-level VI = VIH or VIL output voltage IO = 100 A; VCC = 1.65 V to 5.5 V input leakage current 40 C to +125 C Typ[1] VI = 5.5 V or GND; VCC = 0 V to 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 11 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 5 of 19 74LVC1G08 Nexperia Single 2-input AND gate Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Unit Min Max Min Max - 0.1 2 - 2 A IOFF power-off leakage current ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 A ICC additional per pin; VCC = 2.3 V to 5.5 V; supply current VI = VCC  0.6 V; IO = 0 A - 5 500 - 500 A CI input capacitance - 5 - - - pF [1] VCC = 0 V; VI or VO = 5.5 V 40 C to +125 C Typ[1] VCC = 3.3 V; VI = GND to VCC All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for load circuit see Figure 9. Symbol Parameter 40 C to +85 C Conditions propagation delay A, B to Y; see Figure 8 tpd Max Min Max 1.0 3.4 8.0 1.0 10.5 Unit ns VCC = 2.3 V to 2.7 V 0.5 2.2 5.5 0.5 7.0 ns VCC = 2.7 V 0.5 2.5 5.5 0.5 7.0 ns VCC = 3.0 V to 3.6 V 0.5 2.1 4.5 0.5 6.0 ns 0.5 1.7 4.0 0.5 5.5 ns - 16 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance Typ[1] [2] VCC = 1.65 V to 1.95 V CPD 40 C to +125 C Min VI = GND to VCC; VCC = 3.3 V [3] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLZ and tPZL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1G08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 6 of 19 74LVC1G08 Nexperia Single 2-input AND gate 12. AC waveforms 9, 90 $%LQSXW *1' W 3+/ W 3/+ 92+ 90
74LVC1G08GW,165 价格&库存
很抱歉,暂时无法提供与“74LVC1G08GW,165”相匹配的价格&库存,您可以联系我们找货
