Oil Proof Fan
60×60×20 mm
San Ace 60WF 9WF type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black
Sensor
Yellow
· Mass………………………………………… 80 g
This fan can be used in environments with oil mist.*
* Environment where cutting oil creates oil mist. Conduct a product evaluation with the type of oil to be used.
■ Specifications
The models listed below have ribs and pulse sensors.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
[V]
[V]
[A]
[W]
[min-1]
24
9WF0624H601
12 to 27.6
0.15
3.6
Note: Sensor and control options are available for selection. Refer to the table on p. 637.
■ Airflow - Static Pressure Characteristics
9WF0624H601
With pulse sensor
(inch H2O) (Pa)
0.64 160
0.56 140
Static pressure
Oil Proof Fan 60 mm sq.
DC
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
0.48 120
0.40 100
0.32
80
0.24
60
0.16
40
0.08
27.6 V
24 V
12 V
0.2
0.4
0.6
0.8
1.0 (m3/min)
5 10 15 20 25 30
Airflow
374
CATALOG No. C1111B002 '21.9.IT
(CFM)
6600
Max. airflow
[m3/min]
0.69
[CFM]
24.3
Max. static pressure
[Pa]
114
[inchH2O]
0.45
SPL
Operating temperature
[dB (A)]
[˚C]
[h]
-20 to +70
40000/60˚C
(70000/40˚C)
42
Expected life
■ Dimensions (unit: mm)
+1
4-ø4.5±0.3
60
Mounting hole
50±0.5
(4)
20±0.5
(4)
50±0.5
+1
60 0
Lead wire
AWG 24
UL 1430
300
+50
DC
(10)
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
59
50±0.3
29.7
59
29.7
50±0.3
62
.7
4-ø4.5
■ Options
Finger guards
page: p. 584
Model no.: 109-139E, 109-139H
375
很抱歉,暂时无法提供与“9WF0624H601”相匹配的价格&库存,您可以联系我们找货
