109P0912M401
109P0912M401
    SANYODENKI
    FAN92X25MM12VDCTACH
109P0912M401 数据手册
DC Fan 92 San Ace 92 mm sq. ■ General Specifications 25mm thick (9GA type), 25mm thick (9S type) 25mm thick (9P type), 25mm thick (San Cooler) (9A type) 32mm thick (9G type), 38mm thick (9GA type) 38mm thick (9HV type), 38mm thick (9GV type) 38mm thick (9G type) ・Material …………………… Frame: Plastics (Flammability: UL94V-0), Impeller: Plastics (Flammability: UL94V-1) ・Expected Life …………… Refer to specifications(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) Sensor yellow ・Storage Temperature …-30℃ to +70℃(Non-condensing) ・Lead Wire …………………⊕red ⊖black or blue 92×92×25mm ■ Specifications 9P type 〔Mass:150g〕 The following nos. have pulse sensors and ribs. For ribless, append "1" to the model no. Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. [V] 109P0912J401 109P0912W401 109P0912H401 109P0912F401 109P0912M401 109P0912L401 109P0924W401 109P0924H401 109P0924F401 109P0924M401 109P0924L401 109P0948H401 [W] [min-1] [m³/min] [CFM] 6 to 13.8 6 to 16 0.56 0.21 0.21 0.14 0.1 0.07 0.12 0.12 0.08 0.06 0.05 0.06 6.72 2.52 2.52 1.68 1.2 0.84 2.88 2.88 1.92 1.44 1.2 2.88 4,300 2,850 2,850 2,450 2,100 1,700 2,850 2,850 2,450 2,100 1,700 2,850 2.03 1.45 1.45 1.24 1.04 0.8 1.45 1.45 1.24 1.04 0.8 1.45 71.6 51.2 51.2 43.8 36.7 28.3 51.2 51.2 43.8 36.7 28.3 51.2 10.2 to 13.8 12 to 30 48 Max. Airflow [A] 12 24 Rated Speed [V] 20.4 to 27.6 43 to 53 Max. Static Pressure SPL Operating Temperature Expected Life [Pa] [inchH²O] [dB(A)] 92.2 45 45 32.3 23.5 16.6 45 45 32.3 23.5 16.6 45 0.37 0.181 0.181 0.130 0.094 0.067 0.181 0.181 0.130 0.094 0.067 0.181 47 33 33 30 27 23 33 33 30 27 23 33 [℃] [h] -20 to +60 -20 to +70 40,000 -20 to +70 Some models can also be equipped without sensors as an option. Please refer to the index (pp. 417 to 437). ■Set Models ・The set models listed below can be ordered as a single order.  Set configuration items: Fan (without sensor), finger guard, screws (with flat washer and spring washer), hex nuts, operation manual Fan Model Sensor Specifications 9U-109P0912H402 109P0912H402 (performs the same as the 109P0912H401) 9U-109P0924H402 109P0924H402 (performs the same as the 109P0924H401) ■ Dimensions(unit : mm)(With ribs) 4-φ4.3±0.3 Mounting 取付用穴 Hole 109-099E ■ Options(unit : mm) Finger Guards 25±0.5 (4) Mounting Screws M4 screws (40 mm) x 4, Nuts x 4 Model:109-099C (4) Outlet side +1 4.3±0.3 5 0 φ1.6 φ1.6 8 9. φ3φ87 +1.5 120.5 ー0.5 +30 300 0 99 92±0.5 82.5±0.3 Lead Wire リード線 AWG24 UL1007 .6 16 φ1 (10) Rotating Direction 回転方向 Mass 質量:22g Airflow Direction 風吹出方向 ■ Reference Dimension of Model:109-099E :109-099H Mounting Holes and Vent Opening(unit : mm) 90.5 +1.5 82.5±0.3 10 φ Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Inlet side, Outlet side 4-φ4.5 8 3 82.5±0.3 90.5 82.5±0.3 4-φ4.5 10 φ Outlet side 120.5 -0.5 Inlet side 82.5±0.3 Color Surface treatment :Nickel-chrome plating(silver) +1 5  0 4.3±0.3 φ1.6 φ1.6 7 φ8 91 92±0.5 82.5±0.3 Without sensor Finger Guard Model 99 Model Number to Order .6 16 φ1 131 90.5 90.5 質量:29g Mass Resin Filter Kits Model:109-1001G Model:109-1001F13(13PPI) ,109-1001F20(20PPI) :109-1001F30(30PPI) ,109-1001F40(40PPI) 96.5±1 7±0.5 4-2±0.5 4-φ4.3±0.3 10.5±0.5 82.5±0.3 96.5±1 4-φ4.3±0.3 82.5±0.3 82.5±0.3 92±1 92±1 82.5±0.3 4-φ9.5±0.5 質量:12g Mass Mass 質量:25g 4-2±0.5 ■ Airflow - Static Pressure Characteristics (inch H2O) (Pa) 0.30 13.8V 12V 6V 0.5 1 1.5 2 0 10 20 30 40 50 60 70 80 → 風量 → Airflow 60 0.20 50 20 0.05 10 0 H speed (inch H2O)(Pa) 13.8V/27.6V 12V/24V 30 0.10 10.2V/20.4V 20 0.05 10 0 0 0.5 1.0 1.5 0.20 0.15 0.10 0.05 0 2.0 (m3/min) 25 0.08 20 0.06 10 0.02 5 0 0 0.10 48V 43V 30 20 10 0 0.5 1.0 (Pa) (inch H2O) 24V 30 20 0.05 10 0 0 12V 0.5 1.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 風量 →→ Airflow 0.15 53V 40 30V 40 (CFM) 2.0 (m3/min) (CFM) 109P0948H401 M speed (CFM) F speed 40 13.8V/27.6V 30 12V/24V 0.10 10.2V/20.4V 20 0.05 0 10 0 0.5 0 10 20 1.0 30 40 風量 →→ Airflow 1.5 (m3/min) 50 (CFM) 109P0912F401 109P0924F401 L speed 0.10 25 13.8V/27.6V 12V/24V 10.2V/20.4V 15 0.04 50 (inch H2O)(Pa) →→ Airflow 風量 → Static Pressure → 静圧 → Static Pressure → 静圧 0.10 0.20 109P0924W401 0 10 20 30 40 50 60 70 109P0912H401 109P0924H401 30 2.0 (m3/min) H speed 50 →→ Airflow 風量 0.12 1.5 60 0 10 20 30 40 50 60 70 (CFM) (inch H2O)(Pa) 1.0 → 風量 → Airflow 0.25 40 0.5 60 0.15 Wide range 70 0.25 109P0912W401 50 0.15 6V 0 10 20 30 40 50 60 70 60 0.20 12V 30 0.10 90 (CFM) → Static Pressure → 静圧 → Static Pressure → 静圧 0.25 0.30 16V 40 0.15 109P0912J401 (inch H2O)(Pa) (inch H2O) (Pa) 70 0.25 0 2.5 (m3/min) Wide range → Static Pressure → 静圧 120 0.45 110 0.4 100 0.35 90 80 0.3 70 0.25 60 0.2 50 0.15 40 30 0.1 20 0.05 10 0 0 → Static Pressure → 静圧 → Static Pressure → 静圧 0.5 → Static Pressure → 静圧 J speed (inch H2O)(Pa) 0.5 0 10 20 1.0 30 40 →→ Airflow 風量 109P0912M401 109P0924M401 1.5 (m3/min) 50 (CFM) 0.08 20 0.06 15 0.04 10 0.02 5 0 0 13.8V/27.6V 12V/24V 10.2V/20.4V 0.2 0.4 0.6 0.8 1.0 1.2 0 5 10 15 20 25 30 35 40 →→ Airflow 風量 (m3/min) (CFM) 109P0912L401 109P0924L401 132 DC Fan 92mm Resin Finger Guards DC ■ Options(unit : mm)
109P0912M401
物料型号:San Ace 92,包括多种厚度和类型,例如9GA、9S、9P、San Cooler (9A)、9G、9GA、9HV、9GV。
器件简介:92毫米方形直流风扇,具有塑料框架和叶轮,预期寿命请参考规格。
引脚分配:红线为正极,黑线或蓝线为负极,黄线为传感器。
参数特性:包括额定电压、操作电压范围、额定电流、额定输入功率、额定转速、最大风量、最大静压、声压级、操作温度范围和预期寿命。
功能详解:文档提供了不同型号风扇的详细规格,包括电压、电流、转速、风量、静压和声压级等。
应用信息:风扇适用于需要直流风扇的各种应用,部分型号配备脉冲传感器和肋条,可以根据需要选择是否带传感器。
封装信息:提供了风扇的尺寸、质量、安装孔和通风口的参考尺寸,以及不同型号的风扇的特定选项,如手指防护罩和过滤器套件。
109P0912M401 价格&库存
很抱歉,暂时无法提供与“109P0912M401”相匹配的价格&库存,您可以联系我们找货
