74ALVCH16823DGG,11
74ALVCH16823DGG,11
    NEXPERIA(安世)
    TSSOP56
    IC FF D-TYPE DUAL 9BIT 56TSSOP
74ALVCH16823DGG,11 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS 74ALVCH16823 18-bit bus-interface D-type flip-flop with reset and enable (3-State) Product specification IC24 Data Handbook       1998 Jul 29 Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 FEATURES DESCRIPTION • Wide supply voltage range of 1.2V to 3.6V • Complies with JEDEC standard no. 8-1A. • CMOS low power consumption • Direct interface with TTL levels • Current drive ± 24 mA at 3.0 V • Multibyteflow-through standard pin-out architecture • Low inductance multiple VCC and GND pins to minimize noise and The 74ALVCH16823 is a 18-bit edge-triggered flip-flop featuring separate D-type inputs for each flip-flop and 3-state outputs for bus oriented applications. Incorporates bushold data inputs which eliminate the need for external pull-up resistors to hold unused inputs. The74ALVCH16823 consists of two sections of nine edge-triggered flip-flops. A clock (CP) input, an output-enable (OE) input, a Master reset (MR) input and a clock-enable( CE) input are provided for each total 9-bit section. With the clock-enable (CE) input LOW, the D-type flip-flops will store the state of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH CP transition. Taking CE HIGH disables the clock buffer, thus latching the outputs. Taking the Master reset (MR) input LOW causes all the Q outputs to go LOW independently of the clock. ground bounce • All data inputs have bus hold • Output drive capability 50Ω transmission lines @ 85°C When OE is LOW, the contents of the flip-flops are available at the outputs. When the OE is HIGH, the outputs go to the high impedance OFF-state. Operation of the OE input does not affect the state of flip-flops. Active bus hold circuitry is provided to hold unused or floating data inputs at a valid logic level. QUICK REFERENCE DATA GND = 0V; Tamb = 25°C; tr = tf ≤ 2.5ns TYPICAL UNIT tPHL/tPLH Propagation delay CP to Qn PARAMETER VCC = 2.5V, CL = 30pF VCC = 3.3V, CL = 50pF 2.1 2.1 ns Fmax Maximum clock frequency VCC = 2.5V, CL = 30pF VCC = 3.3V, CL = 50pF 300 350 MHz CI Input capacitance 5.0 pF CPD Power dissipation capacitance per latch SYMBOL CONDITIONS VI = GND to VCC1 Outputs enabled 16 Outputs disabled 10 pF NOTES: 1. CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD × VCC2 × fi +  (CL × VCC2 × fo) where: fi = input frequency in MHz; CL = output load capacity in pF; fo = output frequency in MHz; VCC = supply voltage in V;  (CL × VCC2 × fo) = sum of outputs. ORDERING INFORMATION PACKAGES TEMPERATURE RANGE OUTSIDE NORTH AMERICA NORTH AMERICA DWG NUMBER 56-Pin Plastic SSOP Type II -40°C to +85°C 74ALVCH16823 DL ACH16823 DL SOT371-1 56-Pin Plastic TSSOP Type II -40°C to +85°C 74ALVCH16823 DGG ACH16823 DGG SOT364-1 1998 Jul 29 2 853–2100 19800 Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 PIN DESCRIPTION PIN NUMBER SYMBOL 2, 27 1OE, 2OE Output enable input (active-Low) FUNCTION 54, 52, 51, 49, 48, 47, 45, 44, 43 42, 41, 40, 38, 37, 36, 34, 33, 31 1D0-1D8 2D0-2D8 Data inputs 3, 5, 6, 8, 9, 10, 12, 13, 14 15, 16, 17, 19, 20, 21, 23, 24, 26 1Q0-1Q8 2Q0-2Q8 Data outputs 56, 29 1CP, 2CP Clock pulse input (active rising edge) 55, 30 1CE, 2CE Clock enable input (active-Low) 1, 28 1MR, 2MR Master reset input (active-Low) 4, 11, 18, 25, 32, 39, 46, 53 GND Ground (0V) 7, 22, 35, 50 VCC Positive supply voltage PIN CONFIGURATION LOGIC SYMBOL 1 1MR 1 56 1CP 1OE 2 55 1CE 1Q0 3 54 1D0 GND 4 53 GND 1Q1 5 52 1D1 1Q2 6 51 1D2 VCC 7 50 VCC 1Q3 8 49 1D3 1Q4 9 48 1D4 1Q5 10 47 1D5 GND 11 46 GND 1Q6 12 45 1D6 1Q7 13 44 1D7 1Q8 14 43 1D8 2Q0 15 42 2D0 2Q1 16 41 2D1 2Q2 17 40 2D2 GND 18 39 GND 2Q3 19 38 2D3 2Q4 20 37 2D4 2Q5 21 36 2D5 VCC 22 35 VCC 2Q6 23 34 2D6 2Q7 24 33 2D7 GND 25 32 GND 2Q8 26 31 2D8 2OE 27 30 2CE 2MR 28 29 2CP 28 2 27 1MR 2MR 1OE 2OE 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 A0 A1 A2 A3 B0 B1 B2 B3 A4 A5 A6 A7 B4 B5 B6 B7 A8 A9 A10 A11 B8 B9 B10 B11 A12 A13 A14 A15 B12 B13 B14 B15 A16 A17 B16 B17 3 5 6 8 9 10 12 13 14 15 16 17 19 20 21 23 24 26 1CP 2CP 1CE 2CE 48 29 55 30 SW00341 SH00014 1998 Jul 29 3 Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 LOGIC SYMBOL (IEEE/IEC) BUS HOLD CIRCUIT VCC 2 EN1 1MR 1 R2 1CE 55 G3 1CP 56 2OE 27 EN5 2MR 28 R6 2CE 30 G7 2CP 29 1D0 54 3 1Q0 1D1 52 5 1Q1 1D2 51 6 1Q2 1D3 49 8 1Q3 1D4 48 9 1Q4 1D5 47 10 1Q5 1D6 45 12 1Q6 1D7 44 13 1Q7 1D8 43 14 1Q8 15 2Q0 1OE 2D0 3C4 Data Input To internal circuit 7C8 1, 2 ∇ 4D 42 5, 6 ∇ 8D 2D1 41 16 2Q1 2D2 40 17 2Q2 2D3 38 19 2Q3 2D4 37 20 2Q4 2D5 36 21 2Q5 2D6 34 23 2Q6 2D7 33 24 2Q7 2D8 31 25 2Q8 SW00044 SH00015 LOGIC DIAGRAM nCE nD0 nD1 nD2 nD3 nD4 nD5 nD6 nD7 nD8 nCP nD R CP nD R Q CP nD R Q CP Q CP nD nD R R Q CP nD R Q CP nD R Q CP nD R Q CP nD R Q CP Q nMR nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 nQ8 n = 1 or 2 SH00016 1998 Jul 29 4 Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 FUNCTION TABLE INPUTS H h L l X Z ↑ OUTPUT nOE nMR nCE nCP nDx nQx L L X X X L L H L ↑ h H L H L ↑ l L L H L L X Q0 L H H X X Q0 = = = = = = = H X X X X Z HIGH voltage level HIGH voltage level one set-up time prior to the Low-to-High clock transition LOW voltage level LOW voltage level one set-up time prior to the Low-to-High clock transition Don’t care HIGH impedance “off” state LOW to High clock transition OPERATING MODES Clear Load and read data Hold Disable outputs RECOMMENDED OPERATING CONDITIONS LIMITS SYMBOL VCC VCC PARAMETER CONDITIONS UNIT MIN MAX DC supply voltage 2.5V range (for max. speed performance @ 30 pF output load) 2.3 2.7 DC supply voltage 3.3V range (for max. speed performance @ 50 pF output load) 3.0 3.6 V DC supply voltage (for low-voltage applications) VI DC Input voltage range VO DC output voltage range Tamb Operating free-air temperature range tr, tf Input rise and fall times 1.2 3.6 V for data input pins 0 VCC V for control pins 0 5.5 V 0 VCC V –40 +85 °C 0 0 20 10 ns/V VCC = 2.3 to 3.0V VCC = 3.0 to 3.6V ABSOLUTE MAXIMUM RATINGS In accordance with the Absolute Maximum Rating System (IEC 134). Voltages are referenced to GND (ground = 0V). SYMBOL VCC PARAMETER CONDITIONS DC supply voltage VI 0 IIK DC input diode current VI DC in input ut voltage IOK DC output diode current VO VCC or VO  0 VO DC output voltage Note 1 IO DC output source or sink current VO = 0 to VCC For control pins1 IGND, ICC Tstg PTOT For data inputs1 DC VCC or GND current Storage temperature range Power dissipation per package –plastic medium-shrink (SSOP) –plastic thin-medium-shrink (TSSOP) For temperature range: –40 to +125 °C above +55°C derate linearly with 11.3 mW/K above +55°C derate linearly with 8 mW/K NOTE: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 1998 Jul 29 5 RATING UNIT –0.5 to +4.6 V –50 mA –0.5 to +5.5 –0.5 to VCC +0.5 V 50 mA –0.5 to VCC +0.5 V 50 mA 100 mA –65 to +150 °C 850 600 mW Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 DC ELECTRICAL CHARACTERISTICS Over recommended operating conditions. Voltage are referenced to GND (ground = 0 V). LIMITS SYMBOL PARAMETER TEST CONDITIONS Temp = -40°C to +85°C MIN VIH VIL HIGH level Input In ut voltage LOW level In Input ut voltage VCC = 1.2V VCC VCC = 1.8V 0.7*VCC 0.9 VCC = 2.3 to 2.7V 1.7 1.2 VCC = 2.7 to 3.6V 2.0 1.5 VOL II IIHZ/IILZ IOZ ∆ICC MAX V – GND VCC = 1.8V 0.9 0.2*VCC VCC = 2.3 to 2.7V 1.2 0.7 1.5 0.8 VCC = 1 1.8 8 to 3 3.6V; 6V; VI = VIH or VIL; IO = –100µA VCC0.2 0 2 VCC – VCC = 1.8V; VI = VIH or VIL; IO = –6mA VCC0.4 VCC0.10 – VCC = 2.3V; VI = VIH or VIL; IO = –6mA VCC0.3 VCC0.08 – VCC = 2.3V; VI = VIH or VIL; IO = –12mA VCC0.5 VCC0.17 – VCC = 2.3V; VI = VIH or VIL; IO = –18mA VCC0.6 VCC0.26 – VCC = 2.7V; VI = VIH or VIL; IO = –12mA VCC0.5 VCC0.14 – VCC = 3.0V; VI = VIH or VIL; IO = –24mA VCC1.0 VCC0.28 – 8 to 3 6V; VI = VIH or VIL; IO = 100µA VCC = 1 1.8 3.6V; GND 0 20 0.20 VCC = 1.8V; VI = VIH or VIL; IO = 6mA 0.09 0.30 VCC = 2.3V; VI = VIH or VIL; IO = 6mA 0.07 0.20 VCC = 2.3V; VI = VIH or VIL; IO = 12mA 0.15 0.40 VCC = 2.3V; VI = VIH or VIL; IO = 18mA 0.23 0.60 VCC = 2.7V; VI = VIH or VIL; IO = 12mA 0.14 0.40 VCC = 3.0V; VI = VIH or VIL; IO = 24mA 0.27 0.55 Input leakage current per control pin VCC = 1.8 to 3.6V; VI = 5.5V or GND 0.1 5 Input leakage current per data pin VCC = 1.8 to 3.6V; VI = VCC or GND 0.1 5 VCC = 1.8 to 2.7V; VI = VCC or GND 0.1 10 VCC = 3.6V; VI = VCC or GND 0.1 15 VCC = 1.8 to 2.7V; VI = VIH or VIL; VO = VCC or GND 0.1 5 VCC = 2.7 to 3.6V; VI = VIH or VIL; VO = VCC or GND 0.1 10 VCC = 2.7V to 3.6V; VI = VCC – 0.6V; IO = 0 150 750 HIGH level output voltage LOW level output voltage Input current for common I/O pins 3-State output OFF-state current Additional quiescent supply current given per data I/O pin 0.7V2 V V V µA µA µA IBHL Bus hold LOW sustaining g current VCC = 2.3V; VI = 45 – VCC = 3.0V; VI = 0.8V2 75 150 IBHH Bus hold HIGH sustaining g current VCC = 2.3V; VI = 1.7V2 –45 VCC = 3.0V; VI = 2.0V2 –75 IBHLO Bus hold LOW overdrive current VCC = 2.7V2 300 VCC = 3.6V2 450 IBHHO Bus hold HIGH overdrive current VCC = 2.7V2 –300 VCC = 3.6V2 –450 NOTES: 1. All typical values are at Tamb = 25°C. 2. Valid for data inputs of bus hold parts. 1998 Jul 29 UNIT VCC = 1.2V VCC = 2.7 to 3.6V VOH TYP1 6 –175 µA µA µA µA µA Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 AC CHARACTERISTICS FOR VCC = 2.3V TO 2.7V RANGE AND VCC < 2.3V GND = 0V; tr = tf ≤ 2.0ns; CL = 30pF LIMITS SYMBOL PARAMETER WAVEFORM VCC = 1.8V VCC = 1.2V MIN VCC = 2.3 to 2.7V TYP1, 2 MAX MIN TYP1 MAX TYP1 UNIT tPLH/tPHL Propagation delay nCP to nQn 1, 5 1.0 2.8 4.9 1.5 4.5 7.5 10.6 ns tPLH/tPHL Propagation delay nMR to nQn 2, 5 1.0 2.9 5.0 1.5 4.6 7.4 9.9 ns tPZH/tPZL 3-State output enable time nOEn to nQn 4, 5 1.0 2.8 5.3 1.5 4.4 7.7 10.4 ns tPHZ/tPLZ 3-State output disable time nOEn to nQn 4, 5 1.0 2.2 4.1 1.5 3.3 5.5 6.7 ns nCP pulse width 1, 5 3.0 1.6 4.0 2.0 nMR pulse width, LOW 3, 5 3.0 0.4 4.0 0.8 1.2 0.2 1.5 0.2 1.8 –0.2 2.0 –0.2 0.8 –0.1 0.6 –0.2 0.3 0.2 0.3 0.2 2, 5 1.0 0.3 0.8 0.2 ns 1, 5 150 300 125 250 MHz tW Set up time nDn to nCP tSU Set up time nCE to nCP Hold time nDn to nCP th Hold time nCE to nCP trec Recovery time nMR to nCP Fmax Maximum clock pulse frequency NOTE: 1. All typical values are measured at Tamb = 25°C. 2. Typical value is measured at VCC = 2.5V. 3 5 3, 3 5 3, ns ns ns AC CHARACTERISTICS FOR VCC = 3.0V TO 3.6V RANGE AND VCC = 2.7V GND = 0V; tr = tf ≤ 2.5ns; CL = 50pF LIMITS SYMBOL PARAMETER WAVEFORM VCC = 3.0 ± 0.3V VCC = 2.7V UNIT MIN TYP1, 2 MAX MIN TYP1 MAX tPLH/tPHL Propagation delay nCP to nQn 1, 5 1.0 2.5 3.7 1.0 2.7 4.3 ns tPLH/tPHL Propagation delay nMR to nQn 2, 5 1.0 2.6 4.0 1.0 3.1 4.6 ns tPZH/tPZL 3-State output enable time nOEn to nQn 4, 5 1.0 2.5 4.3 1.0 3.1 5.2 ns tPHZ/tPLZ 3-State output disable time nOEn to nQn 4, 5 1.0 2.8 3.9 1.0 3.1 4.3 ns nCP pulse width HIGH or LOW 1, 5 2.5 1.4 3.0 1.6 nMR pulse width HIGH or LOW 3, 5 2.5 0.3 3.0 0.6 1.2 0.2 1.5 0.4 1.5 –0.1 1.9 –0.1 0.8 0.0 0.6 –0.2 0.5 0.1 0.4 0.1 tW tSU th trec Set up time nDn to nCP Set up time nCE to nCP Hold time nDn to nCP Hold time nCE to nCP Recovery time nMR to nCP Fmax Maximum clock pulse frequency NOTES: 1. All typical values are measured at Tamb = 25°C. 2. Typical value is measured at VCC = 3.3V. 1998 Jul 29 3 5 3, 3 5 3, ns ns ns 2, 5 1.0 0.2 0.8 0.1 ns 1, 5 200 350 150 300 MHz 7 Philips Semiconductors Product specification 18-bit D-type flip-flop (3-State) 74ALVCH16823 AC WAVEFORMS FOR VCC = 2.3V TO 2.7V AND VCC < 2.3V RANGE VM = 0.5 VCC VX = VOL + 0.15V VY = VOH –0.15V VOL and VOH are the typical output voltage drop that occur with the output load. V =V CC I VI VM nOE INPUT GND AC WAVEFORMS FOR VCC = 3.0V TO 3.6V AND VCC = 2.7V RANGE tPLZ tPZL VCC VM = 1.5 V VX = VOL + 0.3V VY = VOH –0.3V VOL and VOH are the typical output voltage drop that occur with the output load. V = 2.7V I OUTPUT LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ tPZH VOH 1/fMAX nCP VM OUTPUT HIGH-to-OFF OFF-to-HIGH 3.0V or VCC whichever is less VM VY VM GND outputs enabled 0V tw tPLH outputs disabled outputs enabled tPHL VOH nQn VM SW00308 Waveform 4. 3-State Enable and Disable Times VM 0V TEST CIRCUIT SH00017 Waveform 1. Clock (nCP) to Output (nQn) Propagation Delays, Clock Pulse Width, and Maximum Clock Pulse Frequency S1 VCC 2VCC Open GND RL=500 Ω VM nMR VIN 3.0V or VCC whichever is less VM PULSE GENERATOR 3.0V or VCC whichever is less VM nCP SWITCH POSITION VOH nQn VM 0V SH00018 Waveform 2. Master Reset (MR) Pulse WIdth, MR to Output propagation Delay and MR to Clock Recovery Time VM tsu tsu th VIN tPLZ/tPZL 2VCC  2.7V 2.7 – 3.6V VCC 2.7V tPHZ/tPZH GND SW00047 VM VM NOTE: The data set-up and hold times for Dn or CE input to the CP input SH00155 Waveform 3. Data Setup and Hold Times for the Dn or CE input to the CP input 1998 Jul 29 VCC Open Waveform 5. Load circuitry for switching times VOH nQn OUTPUT VOL SWITCH th VI nCE, nDn INPUT GND TEST tPLH/tPHL DEFINITIONS RL = Load resistor CL = Load capacitance includes jig and probe capacitance RT = Termination resistance should be equal to ZOUT of pulse generators. VI nCP INPUT GND RL=500 Ω CL Test Circuit for 3-State Outputs 0V tPHL D.U.T. RT 0V tREC tw VOUT 8 Philips Semiconductors Product specification 18-bit bus-interface D-type flip-flop with reset and enable (3-State) 74ALVCH16823 SSOP56: plastic shrink small outline package; 56 leads; body width 7.5 mm 1998 Jul 29 9 SOT371-1 Philips Semiconductors Product specification 18-bit bus-interface D-type flip-flop with reset and enable (3-State) 74ALVCH16823 TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1mm 1998 Jul 29 10 SOT364-1 Philips Semiconductors Product specification 18-bit bus-interface D-type flip-flop with reset and enable (3-State) 74ALVCH16823 NOTES 1998 Jul 29 11 Philips Semiconductors Product specification 18-bit bus-interface D-type flip-flop with reset and enable (3-State) 74ALVCH16823 Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make chages at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 1998 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 print code Document order number:       1998 Jul 29 12 Date of release: 05-96 9397-750-04554
74ALVCH16823DGG,11 价格&库存
很抱歉,暂时无法提供与“74ALVCH16823DGG,11”相匹配的价格&库存,您可以联系我们找货
