109BF12MC2
109BF12MC2
    SANYODENKI
    BLOWER120X32MM12VDCTACH
109BF12MC2 数据手册
Blower 120 San Ace B120 32mm thick (9BF type), 32mm thick (9BFB type) mm ■ General Specifications ・Material …………………… Frame: Plastics (Flammability: UL94V-0), Impeller: Plastics (Flammability: UL94V-1) ・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ , rated voltage, and continuously run in a free air state) Sensor yellow ・Storage Temperature …-30℃ to +70℃(Non-condensing) ・Lead Wire …………………⊕red ⊖black or blue 120mm×32mm 9BF type The following nos. have pulse sensors. Model No. [V] 109BF12HC2 109BF12MC2 109BF24HC2 109BF24MC2 [V] 12 10.2 to 13.8 24 20.4 to 27.6 Rated Speed Max. Airflow Max. Static Pressure [A] [W] [min-1] [m³/min] [CFM] 0.6 0.32 0.3 0.16 7.2 3.84 7.2 3.84 2,400 1,900 2,400 1,900 0.78 0.61 0.78 0.61 27.5 21.5 27.5 21.5 SPL Operating Temperature Expected Life [Pa] [inchH²O] [dB(A)] 175.4 109.8 175.4 109.8 0.704 0.441 0.704 0.441 52 44 52 44 [℃] [h] - 20 to + 60 40,000 Some models can also be equipped without sensors as an option. Please refer to the index (pp. 417 to 437). 104.8±0.5 55 4 φ7 3 0. le 3± Ho . 4 φ in用g 穴 t 6- n付 u o取 M (5) 88±0.3 Rotating Direction 回転方向 120±1 AIRFLOW 88±0.3 92±0.3 (15) +30 300 0 (3) 32±0.5 (45) (15) Lead Wire リード線 AWG24 UL1007 (10) ■ Dimensions(unit : mm) 104.8±0.5 120±1 Airflow Direction 風吹出方向 ■ Airflow - Static Pressure Characteristics H speed (inch H2O)(Pa) 0.6 300 13.8V/27.6V 1.0 0.8 12V/24V 200 10.2V/20.4V 0.6 0.4 → 静圧 → Static Pressure → Static Pressure → 静圧 1.2 100 0.2 0 0 0.5 0 10 20 1.0 30 M speed (inch H2O)(Pa) 40 →→ Airflow 風量 109BF12HC2 109BF24HC2 1.5(m3/min) 50 (CFM) 150 13.8V/27.6V 0.5 0.4 12V/24V 100 10.2V/20.4V 0.3 0.2 50 0.1 0 0 0.5 0 10 20 1.0 30 40 →→ Airflow 風量 1.5(m3/min) 50 (CFM) 109BF12MC2 109BF24MC2 350 DC Rated Voltage Operating Voltage Range Rated Current Rated Input Blower 97mm/120mm ■ Specifications 〔Mass:270g〕
109BF12MC2 价格&库存
很抱歉,暂时无法提供与“109BF12MC2”相匹配的价格&库存,您可以联系我们找货
