Blower
120
San Ace B120
32mm thick (9BF type), 32mm thick (9BFB type)
mm
■ General Specifications
・Material …………………… Frame: Plastics (Flammability: UL94V-0),
Impeller: Plastics (Flammability: UL94V-1)
・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ ,
rated voltage, and continuously run in a free air state)
Sensor yellow
・Storage Temperature …-30℃ to +70℃(Non-condensing)
・Lead Wire …………………⊕red ⊖black or blue
120mm×32mm
9BF type
The following nos. have pulse sensors.
Model No.
[V]
109BF12HC2
109BF12MC2
109BF24HC2
109BF24MC2
[V]
12
10.2 to 13.8
24
20.4 to 27.6
Rated Speed
Max. Airflow
Max. Static Pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
0.6
0.32
0.3
0.16
7.2
3.84
7.2
3.84
2,400
1,900
2,400
1,900
0.78
0.61
0.78
0.61
27.5
21.5
27.5
21.5
SPL
Operating Temperature Expected Life
[Pa] [inchH²O] [dB(A)]
175.4
109.8
175.4
109.8
0.704
0.441
0.704
0.441
52
44
52
44
[h]
- 20 to + 60
40,000
Some models can also be equipped without sensors as an option. Please refer to the index (pp. 417 to 437).
104.8±0.5
55
4
φ7
3
0. le
3± Ho
4
φ in用g 穴
t
6- n付
u
o取
M
(5)
88±0.3
Rotating
Direction
回転方向
120±1
AIRFLOW
88±0.3
92±0.3
(15)
+30
300 0
(3)
32±0.5
(45)
(15)
Lead
Wire
リード線
AWG24
UL1007
(10)
■ Dimensions(unit : mm)
104.8±0.5
120±1
Airflow
Direction
風吹出方向
■ Airflow - Static Pressure Characteristics
H speed
(inch H2O)(Pa)
0.6
300
13.8V/27.6V
1.0
0.8
12V/24V
200
10.2V/20.4V
0.6
0.4
→ 静圧
→ Static
Pressure
→ Static
Pressure
→ 静圧
1.2
100
0.2
30
M speed
(inch H2O)(Pa)
40
Airflow
風量
109BF12HC2
109BF24HC2
1.5(m3/min)
50
(CFM)
150
13.8V/27.6V
0.5
0.4
12V/24V
100
10.2V/20.4V
0.3
0.2
50
0.1
30
40
Airflow
風量
1.5(m3/min)
50
(CFM)
109BF12MC2
109BF24MC2
350
DC
Rated Voltage Operating Voltage Range Rated Current Rated Input
Blower 97mm/120mm
■ Specifications
〔Mass:270g〕
很抱歉,暂时无法提供与“109BF24MD2”相匹配的价格&库存,您可以联系我们找货
