12038VA-24L-EL-00
12038VA-24L-EL-00
    NMBTECHNOLOGIESCORPORATION
    FAN24VDC120X38MM3WR
12038VA-24L-EL-00 数据手册
4715VL (120 X 38L) NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger 1.60 400 1.40 350 P-Q Curve (Pa) Speed Curve 8000 7000 B80 Ps Expected Life Failure Rate: 10% 25°C 100,000 Hours (E00) 300 1.00 250 0.80 200 0.60 150 0.40 100 0.20 50 0.00 0 6000 B70 B60 5000 4000 Speed Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 1.20 3000 2000 B80 B70 B60 1000 0 0 1.68 1.12 3.36 4.48 5.60 6.72k (m3/min) CFM 0 20 40 60 80 100 120 140 160 180 200 220 240 260 Air Flow Material DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL1061, AWG24, +Red, -Black 11.8 min (300) Outline ROTATION .169 (8 F4.3± 0.3) inch Units: (mm) AIR 4.13 (105.0) NAME PLATE .169 (4 – F4.3) .197 (5.0 ) 4.13 (105.0) 3 5.4 38) (F1 4.63 (117.6) 4.63 (117.6) 0 5.0 27) (F1 4.63 (117.6) .169 (4 – F4.3) 4.13 (105.0) 4.63 (117.6) 4.13 (105.0± 0.5) 4.72 (120.0± 0.5) Panel Cut-Outs 1.49 (38.0± 0.5) .197 (5.0 ) 4.13 (105.0± 0.5) 4.72 (120.0 ± 0.5) LOT NO. 4.13 (105.0) INLET SIDE OUTLET SIDE Specifications Rated Voltage MODEL Operating Current Voltage Input Speed Power Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 4715VL-04W-B60- EXX 12 10.0 ~ 13.8 1.50 18.00 4715VL-04W-B70- EXX 12 10.0 ~ 13.8 2.25 4715VL-04W-B80- EXX 12 10.0 ~ 12.6 3.00 4715VL-05W-B50- EXX 24 18.0 ~ 27.6 4715VL-05W-B60- EXX 24 4715VL-05W-B70- EXX 4715VL-05W-B80- Max. Air Flow Max. Static Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 5000 189.9 27.00 5700 36.00 6400 0.76 18.24 18.0 ~ 27.6 0.74 24 18.0 ~ 27.6 EXX 24 4715VL-07W-B50- EXX 4715VL-07W-B60- 5.38 0.92 229 59.5 370 215.7 6.11 1.15 287 63.0 370 243.2 6.89 1.46 363 66.0 370 4700 182.5 5.17 0.83 207 55.5 370 17.76 5000 189.9 5.38 0.92 229 59.5 370 1.04 24.96 5700 215.7 6.11 1.15 287 63.0 370 18.0 ~ 27.6 1.48 35.52 6400 243.2 6.89 1.46 363 66.0 370 48 40.0 ~ 52.8 0.37 17.80 4700 182.5 5.17 0.83 207 55.5 370 EXX 48 40.0 ~ 55.2 0.45 21.60 5000 189.9 5.38 0.92 229 59.5 370 4715VL-07W-B70- EXX 48 40.0 ~ 55.2 0.60 28.80 5700 215.7 6.11 1.15 287 63.0 370 4715VL-07W-B80- EXX 48 40.0 ~ 52.0 0.80 38.40 6400 243.2 6.89 1.46 363 66.0 370 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air 1.12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: NMB Technologies: 4715VL-04W-B80-E00 12038VA-12Q-ET-00 12038VA-48P-EL-00 4715VL-05W-B39-E00 4715VL-05W-B50-E00 12038VA-12P-EA-00 12038VA-48R-ET-00 4715VL-05W-B40-E00 12038VA-24R-ET-00 12038VA-48Q-EA-00 12038VA-12P-ET-00 12038VA-24P-EL-00 12038VA-48P-ET-00 12038VA-24Q-EL-00 12038VA-24Q-ET-00 12038VA-48Q-ET-00 4715VL-07W-B39-E50 12038VA-24R-EL-00 12038VA-24M-EA-00 12038VA-24Q-EA-00 12038VA-24P-ET-00 12038VA-24N-EA-00 12038VA-24P-EA-00 12038VA-48Q-EL-00 12038VA-12R-ET-00 12038VA-24L-EL-00 12038VA-48L-ET00 12038VA-12Q-EL-00 12038VA-48R-EL-00 12038VA-48P-EA-00 12038VA48R-EA-00 12038VA-12R-EA-00 12038VA-48N-EA00 12038VA-12P-EL-00 12038VA-12Q-EA-00 4715VL-05W-B89E50 4715VL-07W-B69-E50 4715VL-05W-B89-E00 12038VA-24R-EA-00 12038VA-12R-EL-00 4715VL-05W-B69-E50 4715VL-05W-B79-E00 4715VL-05W-B60-E00 4715VL-07W-B60-E00 4715VL-07W-B80-E00 4715VL-07W-B89-E00 4715VL-07W-B70-E00 4715VL-04W-B60-E00 4715VL-05W-B69-E00 4715VL-04W-B89-E50 4715VL-05W-B80-E00 4715VL-04W-B79-E50 4715VL-07W-B50-E00 4715VL-07W-B89-E50 4715VL-04W-B69-E50 4715VL-07W-B79-E00 4715VL-04W-B89-E00 4715VL-07W-B69-E00 4715VL-04W-B79-E00 4715VL-04W-B70-E00 4715VL-04W-B69-E00 4715VL-07W-B79-E50 4715VL-05W-B70-E00 4715VL-05W-B79-E50
12038VA-24L-EL-00 价格&库存
很抱歉,暂时无法提供与“12038VA-24L-EL-00”相匹配的价格&库存,您可以联系我们找货
