74ALVT162823DL,518
74ALVT162823DL,518
    NEXPERIA(安世)
    SSOP56_300MIL
    IC FF D-TYPE DUAL 9BIT 56SSOP
74ALVT162823DL,518 数据手册
74ALVT162823 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Rev. 3 — 23 January 2018 1 Product data sheet General description The 74ALVT162823 18-bit bus interface register is designed to eliminate the extra packages required to buffer existing registers and provide extra data width for wider data or address paths of buses carrying parity. The 74ALVT162823 has two 9-bit wide buffered registers with clock enable (nCE) and master reset (nMR) which are ideal for parity bus interfacing in high microprogrammed systems. The registers are fully edge-triggered. The state of each D input, one set-up time before the LOW-to-HIGH clock transition is transferred to the corresponding Q output of the flip-flop. The 74ALVT162823 is designed with 30 Ω series resistance in both the pull-up and pull-down output structures. This design reduces line noise in applications such as memory address drivers, clock drivers, and bus receivers or transmitters. 2 Features and benefits • Two sets of high speed parallel registers with positive edge-triggered D-type flip-flops • 5 V I/O compatible • Ideal where high speed, light loading or increased fan-in are required with MOS microprocessors • Bus hold data inputs eliminate the need for external pull-up resistors to hold unused inputs • Live insertion and extraction permitted • Power-up 3-state • Power-up reset • Output capability: +12 mA to −12 mA • Outputs include series resistance of 30 Ω making external termination resistors unnecessary • Latch-up protection: – JESD78: exceeds 500 mA • ESD protection: – MIL STD 883, method 3015: exceeds 2000 V – MM: exceeds 200 V 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name 74ALVT162823DGG −40 °C to +85 °C 4 TSSOP56 Description Version plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 Functional diagram 1OE 1MR 1CE 1CP 2OE 2MR 2CE 2CP 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 1D8 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 2D8 2 1 55 56 27 28 30 29 54 52 VCC EN1 R2 G3 3C4 EN5 R6 G7 7C8 4D data input 1,2 3 5 51 6 49 8 48 9 47 10 45 12 44 13 43 14 42 41 8D 5,6 15 16 40 17 38 19 37 20 36 21 34 23 33 24 31 26 1Q0 1Q1 1Q2 1Q3 1Q4 001aad245 Figure 2. Bus hold circuit 1Q5 VCC 1Q6 1Q7 VCC 1Q8 2Q0 2Q1 2Q2 27 Ω 2Q3 output 2Q4 2Q5 27 Ω 2Q6 2Q7 2Q8 001aad244 001aad242 Figure 1. IEC logic symbol 74ALVT162823 Product data sheet to internal circuit Figure 3. Schematic of each output All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state nCE nD0 nD1 nD2 nD3 nD4 nD5 nD6 nD7 nD8 nCP CP nD R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R Q nMR nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 nQ8 001aad243 Figure 4. Logic diagram 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 5 Pinning information 5.1 Pinning 1MR 1 56 1CP 1OE 2 55 1CE 1Q0 3 54 1D0 GND 4 53 GND 1Q1 5 52 1D1 1Q2 6 51 1D2 VCC 7 1Q3 8 50 VCC 49 1D3 1Q4 9 48 1D4 1Q5 10 47 1D5 GND 11 46 GND 1Q6 12 45 1D6 1Q7 13 44 1D7 1Q8 14 2Q0 15 43 1D8 74ALVT162823 42 2D0 2Q1 16 41 2D1 2Q2 17 40 2D2 GND 18 39 GND 2Q3 19 38 2D3 2Q4 20 37 2D4 2Q5 21 36 2D5 VCC 22 2Q6 23 35 VCC 34 2D6 2Q7 24 33 2D7 GND 25 32 GND 2Q8 26 31 2D8 2OE 27 30 2CE 2MR 28 29 2CP 001aab433 Figure 5. Pin configuration 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7, 1D8 54, 52, 51, 49, 48, 47, 45, 44, 43 data inputs 1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7, 1Q8 3, 5, 6, 8, 9, 10, 12, 13, 14 data outputs 2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7, 2D8 42, 41, 40, 38, 37, 36, 34, 33, 31 data inputs 2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7, 2Q8 15, 16, 17, 19, 20, 21, 23, 24, 26 data outputs 1MR, 2MR 1, 28 master reset input (active-LOW) 1OE, 2OE 2, 27 output enable inputs (active LOW) 1CP, 2CP 56, 29 clock pulse inputs (active rising edge) 1CE, 2CE 55, 30 clock enable input (active-LOW) GND 4, 11, 18, 25, 32, 39, 46, 53 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6 Functional description Table 3. Function table Operating mode [1] Input Output nOE nMR nCE nCP nDn nQn Clear L L X X X L Load and read data L H L ↑ h H l L Hold L H H NC X NC High-impedance H X X X X Z [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; NC = no change; X = don’t care; Z = high-impedance OFF-state; ↑ = LOW-to-HIGH clock transition; 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134); voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage Min Max Unit −0.5 +4.6 V input voltage [1] −0.5 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] −0.5 +7.0 V IIK input clamping current VI < 0 V - −50 mA IOK output clamping current VO < 0 V - −50 mA IO output current output in LOW-state - 128 mA output in HIGH-state - −64 mA −65 +150 °C - 150 °C VI Tstg storage temperature Tj [2] junction temperature [1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.3 - 2.7 V VCC = 2.5 V VCC supply voltage VI input voltage 0 - 5.5 V IOH HIGH-level output current - - −8 mA IOL LOW-level output current - - 12 mA Δt/Δv input transition rise or fall rate outputs enabled - - 10 ns/V Tamb ambient temperature in free air −40 - +85 °C 3.0 - 3.6 V VCC = 3.3 V VCC supply voltage VI input voltage 0 - 5.5 V IOH HIGH-level output current - - −12 mA IOL LOW-level output current - - 12 mA Δt/Δv input transition rise or fall rate outputs enabled - - 10 ns/V Tamb ambient temperature in free air −40 - +85 °C 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; Tamb = −40 °C to +85 °C; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions [1] Max Unit - -0.85 -1.2 V Min Typ VCC = 2.5 V ± 0.2 V VIK input clamping voltage VCC = 2.3 V; IIK = -18 mA VIH HIGH-level input voltage 1.7 - - V VIL LOW-level input voltage - - 0.7 V VOH HIGH-level output voltage VCC = 2.3 V; IO = -8 mA 1.7 2.5 - V VOL LOW-level output voltage VCC = 2.3 V; IO = 12 mA - 0.3 0.5 V - 0.2 0.55 V - 0.1 ±1 μA - 0.1 10 μA VCC = 2.7 V; VI = 5.5 V - 0.1 10 μA VCC = 2.7 V; VI = VCC - 0.5 1 μA VCC = 2.7 V; VI = 0 V - 0.1 -5 μA VOL(pu) power-up LOW-level output voltage VCC = 2.7 V; IO = 1 mA; VI = VCC or GND II input leakage current control pins [2] VCC = 2.7 V; VI = GND VCC = 2.7 V; VI = 5.5 V I/O data pins IOFF IBHL power-off leakage current bus hold LOW current VCC = 0 V; VI or VO = 0 V to 4.5 V - 0.1 ±100 μA data inputs; VCC = 2.5 V; VI = 0.7 V [4] - 100 - μA [4] - -70 - μA - 10 125 μA - 1 ±100 μA output HIGH state; VO = 2.3 V - 0.5 5 μA output LOW-state; VO = 0.5 V - 0.5 -5 μA - 0.04 0.1 mA - 2.7 4.5 mA - 0.04 0.1 mA IBHH bus hold HIGH current data inputs; VCC = 2.5 V; VI = 1.7 V IEX external current output HIGH-state when VO > VCC; VO = 5.5 V; VCC = 2.5 V IO(pu\pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC IOZ VCC = 2.7 V; VI = VIL or VIH ICC OFF-state output current supply current [3] [5] VCC = 2.7 V; VI = GND or VCC; IO = 0 A outputs HIGH-state outputs LOW-state outputs disabled 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 [6] © Nexperia B.V. 2018. All rights reserved. 7 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Symbol Parameter Conditions ΔICC additional supply current per input pin; VCC = 2.3 V to 2.7 V; one input at VCC - 0.6 V, other inputs at VCC or GND CI input capacitance CO output capacitance Min [7] Typ [1] Max Unit - 0.04 0.4 mA VI = 0 V or VCC - 3 - pF VI/O = 0 V or 3.0 V - 9 - pF VCC = 3.0 V; IIK = -18 mA - -0.85 -1.2 V VCC = 3.3 V ± 0.3 V VIK input clamping voltage VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage VCC = 3.0 V; IO = −12 mA 2.0 2.3 - V VOL LOW-level output voltage VCC = 3.0 V; IO = 12 mA - 0.5 0.8 V - - 0.55 V - 0.1 ±1 μA - 0.1 10 μA VCC = 3.6 V; VI = 5.5 V - 0.1 10 μA VCC = 3.6 V; VI = VCC - 0.5 1 μA VCC = 3.6 V; VI = 0 V - 0.1 −5 μA VOL(pu) power-up LOW-level output voltage VCC = 3.6 V; IO = 1 mA; VI = VCC or GND II input leakage current control pins [2] VCC = 3.6 V; VI = VCC or GND VCC = 0 V or 3.6 V; VI = 5.5 V I/O data pins [3] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V - 0.1 ±100 μA IBHL bus hold LOW current data inputs; VCC = 3 V; VI = 0.8 V 75 130 - μA IBHH bus hold HIGH current data inputs; VCC = 3 V; VI = 2.0 V -75 -140 - μA 500 - - μA −500 - - μA - 10 125 μA - 1 ±100 μA output HIGH state; VO = 3.0 V - 0.5 5 μA output LOW-state; VO = 0.5 V - 0.5 −5 μA - 0.05 0.1 mA - 3.9 5.5 mA - 0.06 0.1 mA IBHLO bus hold LOW overdrive current data inputs; VCC = 3.6 V; VI = 0 V to 3.6 V [8] IBHHO bus hold HIGH overdrive current data inputs; VCC = 3.6 V; VI = 0 V to 3.6 V [8] IEX external current output HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V IO(pu\pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC IOZ VCC = 3.6 V; VI = VIL or VIH ICC OFF-state output current supply current [9] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs HIGH-state outputs LOW-state outputs disabled 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 [6] © Nexperia B.V. 2018. All rights reserved. 8 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Symbol Parameter Conditions Min ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V, other inputs at VCC or GND CI input capacitance CO output capacitance [7] Typ [1] Max Unit - 0.04 0.4 mA VI = 0 V or VCC - 3 - pF VI/O = 0 V or 3.0 V - 9 - pF [1] All typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C. All typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C. [2] For valid test results, data must not be loaded into the flip-flops after applying power. [3] Unused pins at VCC or GND. [4] Not guaranteed. [5] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 2.5 V ± 0.2 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. [6] ICC is measured with outputs pulled up to VCC or pulled down to ground. [7] This is the increase in supply current for each input at the specified voltage level other than VCC or GND. [8] This is the bus hold overdrive current required to force the input to the opposite logic state. [9] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); Tamb = −40 °C to +85 °C; for test circuit see Figure 10. Symbol Parameter [1] Conditions Min Typ Max Unit VCC = 2.5 V ± 0.2 V tPLH LOW to HIGH propagation delay nCP to nQn; see Figure 6 2.1 3.7 5.8 ns tPHL HIGH-to-LOW propagation delay nCP to nQn; see Figure 6 2.0 2.8 4.6 ns nMR to nQn; see Figure 8 2.0 3.0 4.6 ns tPZH OFF-state to HIGH propagation delay nOE to nQn; see Figure 9 2.8 4.4 6.6 ns tPZL OFF-state to LOW propagation delay nOE to nQn; see Figure 9 2.0 3.4 5.2 ns tPHZ HIGH to OFF-state propagation delay nOE to nQn; see Figure 9 2.3 3.2 4.6 ns tPLZ LOW to OFF-state propagation delay nOE to nQn; see Figure 9 2.0 2.5 3.5 ns tsu(H) set-up time HIGH nDn to nCP; see Figure 7 1.0 0.5 - ns nCE to nCP; see Figure 7 1.0 0.2 - ns nDn to nCP; see Figure 7 2.0 1.3 - ns nCE to nCP; see Figure 7 0.5 −0.1 - ns nDn to nCP; see Figure 7 0.1 −1.4 - ns nCE to nCP; see Figure 7 1.0 0.2 - ns nDn to nCP; see Figure 7 0.1 −0.5 - ns nCE to nCP; see Figure 7 1.0 −0.1 - ns nCP HIGH; see Figure 6 2.0 0.8 - ns nCP LOW 3.0 2.1 - ns nMR LOW; see Figure 8 2.0 0.8 - ns nMR to nCP; see Figure 8 2.3 1.3 - ns tsu(L) th(H) th(L) tW trec set-up time LOW hold time HIGH hold time LOW pulse width recovery time 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Symbol Parameter [1] Conditions Min Typ Max Unit VCC = 3.3 V ± 0.3 V tPLH LOW to HIGH propagation delay nCP to nQn; see Figure 6 1.8 2.9 4.4 ns tPHL HIGH-to-LOW propagation delay nCP to nQn; see Figure 6 1.6 2.3 3.6 ns nMR to nQn; see Figure 8 1.8 2.5 3.7 ns tPZH OFF-state to HIGH propagation delay nOE to nQn; see Figure 9 2.0 3.5 5.2 ns tPZL OFF-state to LOW propagation delay nOE to nQn; see Figure 9 1.7 2.8 3.8 ns tPHZ HIGH to OFF-state propagation delay nOE to nQn; see Figure 9 2.4 3.5 4.7 ns tPLZ LOW to OFF-state propagation delay nOE to nQn; see Figure 9 1.9 2.8 3.8 ns tsu(H) set-up time HIGH nDn to nCP; see Figure 7 1.0 0.5 - ns nCE to nCP; see Figure 7 1.0 0.1 - ns nDn to nCP; see Figure 7 1.6 1.1 - ns nCE to nCP; see Figure 7 0.5 −0.5 - ns nDn to nCP; see Figure 7 0.1 −0.5 - ns nCE to nCP; see Figure 7 1.0 −0.1 - ns nDn to nCP; see Figure 7 0.1 −0.7 - ns nCE to nCP; see Figure 7 1.0 0.5 - ns nCP HIGH; see Figure 6 1.5 0.7 - ns nCP LOW 2.5 1.4 - ns nMR LOW; see Figure 8 2.0 1.5 - ns nMR to nCP; see Figure 8 2.0 1.1 - ns tsu(L) th(H) th(L) tW trec set-up time LOW hold time HIGH hold time LOW pulse width recovery time [1] All typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C. All typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C. 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 10.1 Waveforms and test circuit 1/fmax VI nCP input VM VM GND tW t PHL t PLH VOH VM nQn output VOL 001aaa256 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Propagation delay clock input (nCP) to output (nQn), clock pulse (nCP) width HIGH and maximum clock frequency VI input nDn, nCE VM GND VM t su(H) VM t h(H) VM t su(L) t h(L) VI input nCP VM VM GND 001aad401 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Figure 7. Data set-up and hold times VI VM input nMR VM GND t WL t rec VI input nCP VM GND t PHL VOH VM output nQn VOL 001aad400 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 8. Master reset (nMR) pulse width, master reset (nMR) to output (nQn) propagation delay and master reset (nMR) to clock (nCP) recovery time 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state VI nOE input VM VM GND tPLZ nQn output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPZH tPHZ nQn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 9. OFF-state to HIGH and LOW propagation delays and LOW and HIGH to OFF-state propagation delays Table 8. Measurement points VCC Input Output VM VM VX VY ≤ 2.7 V 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V ≥ 3.0 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VEXT VCC VI G RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Figure 10. Test circuit for measuring switching times Table 9. Test data Input VI Load fi 3.0 V or VCC ≤ 10 MHz whichever is less 74ALVT162823 Product data sheet VEXT tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6 V or VCC x 2 open All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 tPLH, tPHL © Nexperia B.V. 2018. All rights reserved. 13 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 11 Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT364-1 (TSSOP56) 74ALVT162823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge MIL Military MM Machine Model MOS Metal-Oxide Semiconductor 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVT162823 v.3 20180123 Product data sheet - 74ALVT162823 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type number 74ALVT162823DL (SOT371-1 / SSOP56) removed. 74ALVT162823 v.2 20050811 Modifications: • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. • Section 2: modified ‘Jedec Std 17’ into ‘JESD78’ • Section 10: changed propagation delays. 74ALVT162823 v.1 19980827 74ALVT162823 Product data sheet Product data sheet Product specification - - All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 74ALVT162823 v.1 - © Nexperia B.V. 2018. All rights reserved. 15 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVT162823 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVT162823 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 23 January 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 18 74ALVT162823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable with 30 Ω termination resistors; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 5 Functional description ........................................5 Limiting values .................................................... 6 Recommended operating conditions ................ 6 Static characteristics .......................................... 7 Dynamic characteristics .....................................9 Waveforms and test circuit .............................. 11 Package outline .................................................14 Abbreviations .................................................... 15 Revision history ................................................ 15 Legal information .............................................. 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 January 2018 Document identifier: 74ALVT162823
74ALVT162823DL,518 价格&库存
很抱歉,暂时无法提供与“74ALVT162823DL,518”相匹配的价格&库存,您可以联系我们找货
