Counter Rotating Fan
80
San Ace 80
80mm thick (CRA type), 80mm thick (CR type)
mm sq.
■ General Specifications With a pulse sensor Specifications for pulse sensors
Refer to Page 309
・Material …………………… Frame: Plastics (Flammability: UL94V-0),
Impeller:Plastics (Flammability: UL94V-1)
・Expected Life …………… Varies for each model(L10:Survival rate:90% at 60℃ ,
rated voltage, and continuously run in a free air state)
䊝red
䊞black Sensor yellow
Outlet 䊝orange 䊞gray Sensor purple
・Storage Temperature …−30℃ to +70℃(Non-condensing)
・Lead Wire ………………… Inlet
80×80×80mm
〔Mass:350g〕
CR type
■ Specifications
Rated Voltage Operating Voltage Range Rated Current Rated Input
Model No.
[V]
[V]
[A]
[W]
Rated Speed
[min-1]
Inlet
9CR0812S801
9CR0812H801
Without Sensor
12
10.8 to 13.2
5.5
3.6
66.0
43.2
Available upon request for all the
Pulse Sensor models above.
Max. Air Flow
[m³/min]
[CFM]
4.53
3.97
160
140
Max. Static Pressure
SPL
[Pa] [inchH²O] [dB(A)]
Operating Temperature Expected Life
[h]
−10 to +60
40,000
Outlet
8,000 5,300
7,000 4,600
Lock Sensor
520
400
2.09
1.61
71
68
Please inquire as the availability of these functions depend
PWM Control on the model.
■ Dimensions(Unit : mm)
Outlet side
Inlet side
(4)
71.5±0.5
(4)
(10)
+30
300 0
Lead
Wire
リード線
AWG24
UL1430
4-φ4.3±0.5
Mounting
取付用穴 Hole
風吹出方向
Air Flow
Direction
回転方向
Rotating
Direction
■ Reference dimension of mounting holes and vent opening(Unit : mm)
Inlet side, Outlet side
4-φ4.5
78.5
71.5±0.3
φ
90
71.5±0.3
78.5
195
回転方向
Rotating
Direction
80±0.5
80±0.5
71.5±0.5
80±1
4-φ4.3±0.5
Mounting
Hole
取付用穴
■ Options(Unit : mm)
Finger guards
Resin finger guards
Model:109-049C
Model:109-1002G
Color
Surface treatment :Nickel-chrome plating(silver)
Outlet side
82±1
4.3±0.3
4-φ4.3±0.3
4-2±0.5
82±1
88
+1.5
ー0.5
φ3
9
Counter Rotating Fan 80mm
75
φ
φ1.6
105
7±0.5
71.5±0.3
71.5±0.3
φ1.6
5 +10
.6
φ101.2
Color
:Cation electropainting(black)
Model:109-049E
:109-049H
Resin filter kits
Model:109-1002F13(13PPI)
,109-1002F20(20PPI)
:109-1002F30(30PPI)
,109-1002F40(40PPI)
10.5±0.5
85.5±1
+1
5 0
105
88
85.5±1
+1.5
−0.5
φ75
4-φ4.3±0.3
71.5±0.3
71.5±0.3
4.3±0.3
φ1.6
φ1.6
φ101.2
4-φ10±0.5
4-2±0.5
■ Air Flow - Static Pressure Characteristics
S speed
H speed
(inch H2O)(Pa)
(inch H2O)(Pa)
600
800
1.5
600
12V
500
10.8V
400
300
1.0
200
0.5
1.5
1
50
3
100
4
150
5
200(CFM)
10.8V
1.0
200
0.5
(m3/min)
12V
400
300
100
13.2V
500
100
50
3
100
4
150
→ 風量
→ Air
Flow
→ 風量
→ Air
Flow
9CR0812S801
9CR0812H801
5
(m3/min)
200(CFM)
80mm
2.0
13.2V
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
2.5
196
很抱歉,暂时无法提供与“9CR0812P8H03”相匹配的价格&库存,您可以联系我们找货
