9CR0812P8S03
9CR0812P8S03
    SANYODENKI
    FAN80X80MM12VDCDUALTACH,PWM
9CR0812P8S03 数据手册
Counter Rotating Fan 80 San Ace 80 80mm thick (CRA type), 80mm thick (CR type) mm sq. ■ General Specifications With a pulse sensor Specifications for pulse sensors Refer to Page 309 ・Material …………………… Frame: Plastics (Flammability: UL94V-0), Impeller:Plastics (Flammability: UL94V-1) ・Expected Life …………… Varies for each model(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) 䊝red 䊞black Sensor yellow Outlet 䊝orange 䊞gray Sensor purple ・Storage Temperature …−30℃ to +70℃(Non-condensing) ・Lead Wire ………………… Inlet 80×80×80mm 〔Mass:350g〕 CR type ■ Specifications Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. [V] [V] [A] [W] Rated Speed [min-1] Inlet 9CR0812S801 9CR0812H801 Without Sensor 12 10.8 to 13.2 5.5 3.6 66.0 43.2 Available upon request for all the Pulse Sensor models above. Max. Air Flow [m³/min] [CFM] 4.53 3.97 160 140 Max. Static Pressure SPL [Pa] [inchH²O] [dB(A)] Operating Temperature Expected Life [℃] [h] −10 to +60 40,000 Outlet 8,000 5,300 7,000 4,600 Lock Sensor 520 400 2.09 1.61 71 68 Please inquire as the availability of these functions depend PWM Control on the model. ■ Dimensions(Unit : mm) Outlet side Inlet side (4) 71.5±0.5 (4) (10) +30 300 0 Lead Wire リード線 AWG24 UL1430 4-φ4.3±0.5 Mounting 取付用穴 Hole 風吹出方向 Air Flow Direction 回転方向 Rotating Direction ■ Reference dimension of mounting holes and vent opening(Unit : mm) Inlet side, Outlet side 4-φ4.5 78.5 71.5±0.3 φ 90 71.5±0.3 78.5 195 回転方向 Rotating Direction 80±0.5 80±0.5 71.5±0.5 80±1 4-φ4.3±0.5 Mounting Hole 取付用穴 ■ Options(Unit : mm) Finger guards Resin finger guards Model:109-049C Model:109-1002G Color Surface treatment :Nickel-chrome plating(silver) Outlet side 82±1 4.3±0.3 4-φ4.3±0.3 4-2±0.5 82±1 88 +1.5 ー0.5 φ3 9 Counter Rotating Fan 80mm 75 φ φ1.6 105 7±0.5 71.5±0.3 71.5±0.3 φ1.6 5 +10 .6 φ101.2 Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-049E :109-049H Resin filter kits Model:109-1002F13(13PPI) ,109-1002F20(20PPI) :109-1002F30(30PPI) ,109-1002F40(40PPI) Inlet side, Outlet side 10.5±0.5 85.5±1 +1 5 0 105 88 85.5±1 +1.5 −0.5 φ75 4-φ4.3±0.3 71.5±0.3 71.5±0.3 4.3±0.3 φ1.6 φ1.6 φ101.2 4-φ10±0.5 4-2±0.5 ■ Air Flow - Static Pressure Characteristics S speed H speed (inch H2O)(Pa) (inch H2O)(Pa) 600 800 1.5 600 12V 500 10.8V 400 300 1.0 200 0.5 0 2.0 1.5 1 0 2 50 3 100 4 150 5 200(CFM) 10.8V 1.0 200 0.5 0 (m3/min) 12V 400 300 100 0 13.2V 500 100 0 1 0 2 50 3 100 4 150 → 風量 → Air Flow → 風量 → Air Flow 9CR0812S801 9CR0812H801 5 (m3/min) 200(CFM) 80mm 2.0 13.2V → Static Pressure → 静圧 → Static Pressure → 静圧 2.5 196
9CR0812P8S03 价格&库存
很抱歉,暂时无法提供与“9CR0812P8S03”相匹配的价格&库存,您可以联系我们找货
