9WS0812H401
9WS0812H401
    SANYODENKI
    FAN80X25MM12VDCIP54TACH
9WS0812H401 数据手册
Splash Proof Fan IP54 80×80×25 mm ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air Splash Proof Fan 80 mm sq. at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 547. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Sensor Yellow ・ Mass ……………………………………………… 120 g ・ Ingress protection …………………………… IP54 ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 9WS0812H401 9WS0812F401 9WS0812M401 9WS0824H401 9WS0824F401 9WS0824M401 [V] 12 10.2 to 13.8 24 20.4 to 27.6 Rated speed Max. airflow Max. static pressure [A] [W] [min-1] [m³/min] [CFM] [Pa] 0.16 0.13 0.1 0.09 0.07 0.05 1.92 1.56 1.2 2.16 1.68 1.2 3100 2700 2200 3100 2700 2200 0.94 0.83 0.65 0.94 0.83 0.65 33.2 29.3 23.0 33.2 29.3 23.0 45.1 34.3 23.5 45.1 34.3 23.5 SPL [inchH²O] Operating temperature Expected life [dB (A)] [˚C] [h] 32 28 23 32 28 23 -20 to +70 40000/60˚C 0.181 0.138 0.094 0.181 0.138 0.094 The following sensor and control options are available for selection. Available for all models. Without sensor Differs according to the model. Refer to the table on p. 581. Lock sensor ■ Airflow - Static Pressure Characteristics 9WS0812H401 9WS0812F401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.15 50 13.8 V 40 12 V 30 0.10 0.05 0 10.2 V 20 10 0 0.5 0 10 20 1.0 30 Airflow 風量 40 1.5 (m3/min) 50 (CFM) 0.15 (inch H2O) (Pa) 50 0.20 13.8 V 40 Static静圧 pressure Static静圧 pressure 0.20 0.20 12 V 30 10.2 V 0.10 20 0.05 0 With pulse sensor Operating voltage range (inch H2O) (Pa) 60 Static静圧 pressure 0.25 9WS0812M401 With pulse sensor 10 0 0.5 0 10 20 1.0 30 風量 Airflow (m3/min) 40 (CFM) 0.15 50 40 13.8 V 30 12 V 0.10 20 0.05 0 10.2 V 10 0 0 10 0.5 20 1.0 30 Airflow 風量 (m3/min) 40 DC San Ace 80WS 9WS type (CFM) 285 ■ Airflow - Static Pressure Characteristics 9WS0824H401 9WS0824F401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.15 50 27.6 V 40 24 V 30 0.10 0.05 0 20.4 V 20 10 0 0.5 0 10 20 30 Airflow 風量 40 50 ■ Dimensions (unit: mm) 0.20 27.6 V 40 24 V 30 20.4 V 0.10 20 0.05 0 1.5 (m3/min) 1.0 0.15 (inch H2O) (Pa) 50 10 0 0.5 0 (CFM) Static静圧 pressure Static静圧 pressure 0.20 0.20 With pulse sensor Operating voltage range (inch H2O) (Pa) 60 Static静圧 pressure 0.25 9WS0824M401 With pulse sensor 10 20 1.0 30 風量 Airflow 0.15 40 27.6 V 30 24 V 0.10 20 0.05 (m3/min) 40 50 (CFM) 0 20.4 V 10 0 0 10 0.5 20 1.0 30 Airflow 風量 (m3/min) 40 (CFM) (With ribs) +30 300 0 71.5±0.3 80±0.5 4-ø4.3±0.3 Mounting 取付用穴hole (10) Lead wire リード線 AWG24 UL 1007 71.5±0.3 (4) (4) 25±0.5 80±0.5 回転方向 Rotating direction Airflow direction 風吹出方向 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 71.5±0.3 4-ø4.5 0 78.5 71.5±0.3 ø9 78.5 ■ Options Finger guards Model no.: 109-049E, 109-049H, 109-049C 286 page: p. 532 Resin finger guards Model no.: 109-1002G page: p. 539
9WS0812H401 价格&库存
很抱歉,暂时无法提供与“9WS0812H401”相匹配的价格&库存,您可以联系我们找货
